Dual Weber woes
vw_bud
vw_bud is offline
PostPosted: Wed Oct 20, 2021 5:25 pm    Post subject: Dual Weber woes Reply with quote
Ok so I have a 72 this with an electronic fuel pump and for some reason the fuel pumps back out of the carbs after it sits the only way to start the car is with ether, and with the key on pump running there is no fuel going into the float bowls and the carbs are newer I dont think the needle valves are sticking
overboost
overboost is offline
PostPosted: Wed Oct 20, 2021 5:33 pm    Post subject: Re: Dual Weber woes Reply with quote
If your electric fuel pump is working correctly, it should fill the float bowls. The only thing stopping it is the float needle and seats.
It sounds like you need to check fuel pressure and take the tops off the Webers and have a look.
The older I get... The faster I was...
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Wed Oct 20, 2021 6:17 pm    Post subject: Re: Dual Weber woes Reply with quote
Correct me if I'm wrong, but shouldn't the fuel pressure be set between 3 & 4 psi, ideally 3.5 with dual Webers using an electric fuel pump?
Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
overboost
PostPosted: Wed Oct 20, 2021 7:02 pm    Post subject: Re: Dual Weber woes Reply with quote
OP didn't specify the pump but assuming it is a Facet pump it will be perfect. He might have a feed issue to the pump or the pump has failed.
vw_bud
vw_bud is offline
PostPosted: Wed Oct 20, 2021 7:28 pm    Post subject: Re: Dual Weber woes Reply with quote
Sorry to be vague on the pump I'm not sure what it is but the owner is having issues with starting it, he has to use ether everytime the car sat for 24 hrs
overboost
PostPosted: Wed Oct 20, 2021 7:35 pm    Post subject: Re: Dual Weber woes Reply with quote
It must be leaking into the manifolds or on the ground. There is no way it can make it back into the tank, the float bowl inlets are above the fuel in the carbs.
I would suggest he lets it sit 24 hours and then pull the tops off the carbs and see if they are empty. Slim chance both carbs are leaking.
vw_bud
vw_bud is offline
PostPosted: Wed Oct 20, 2021 7:47 pm    Post subject: Re: Dual Weber woes Reply with quote
That's the thing there isnt a leak and oil level is perfect and clean
