esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Mon Sep 27, 2021 7:45 pm Post subject: Re: Has anyone had trouble setting up Kadrons? |
Clatter wrote: |
It's easy enough to check what size they are once you get them in-hand. |
True, but for the money spent the customer shouldn't have to measure them. It just adds another step to trouble shooting. "Well hey, that jet might be too big or too small, or maybe they aren't the same size. But we don't know what's right or wrong because we don't know what they were supposed to be"
I ordered some carbs from Blackline a few years ago. Came back with a build sheet listing every jet, throttle plate settings, and the float height. Aircooled.net drops a note in the box listing the jets when you pay him to set them up for you.
I realize I'm way O/T so I'll retreat to the corner. _________________ modok wrote:
Bug53 Samba Member
Joined: February 22, 2021 Posts: 704 Location: Pawcatuck, CT.
Posted: Mon Sep 27, 2021 8:35 pm Post subject: Re: Has anyone had trouble setting up Kadrons? |
esde wrote: |
Clatter wrote: |
I realize I'm way O/T so I'll retreat to the corner. |
We should start a separate thread on commercial shop carburetor builds and harvest all the data we can. LOL!
Once I get back to my air cooled girl and measure the mains I will report back. |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Bug53 Samba Member
Posted: Tue Sep 28, 2021 7:09 pm Post subject: Re: Has anyone had trouble setting up Kadrons? |
Update.
Just prior to packing them up for the return trip back to Cali. I measured all the mains. So this is what we have. 61 Idles, 130 mains, H150-2 air correction. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
unclebilly Samba Member
Posted: Wed Sep 29, 2021 9:11 pm Post subject: Re: Has anyone had trouble setting up Kadrons? |
I have Kadrons on my Baja.
Make sure you loctite your air cleaner wing nuts on, one of my air cleaner lids came off and my engine injested dirt.
The kadron being right beside my tire didn’t help anything. |
modok Samba Member
Posted: Wed Sep 29, 2021 9:25 pm Post subject: Re: Has anyone had trouble setting up Kadrons? |
Could happen to anybody.
I use locknuts
having to safety wire your wingnuts is just ironic, and having to loctite your wingnuts is no fun, so we invent the safety wingnut.
The final evolution..... of the wingnut that looks like you could turn it with your fingers but you actually can't.
lets get a wrench
And for maximum pleasure.... ratcheting wrench! |
oprn Samba Member
Joined: November 13, 2016 Posts: 12708 Location: Western Canada
Posted: Thu Sep 30, 2021 4:44 am Post subject: Re: Has anyone had trouble setting up Kadrons? |
unclebilly wrote: |
Common problem. My Buggy came to me in that condition, the right air cleaner was rattling around loose. The right side of the engine was burning oil badly otherwise I would still be running that 1600 DP.
Every Kadron buyer should be told up front this is a problem. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Bug53 Samba Member
Posted: Wed Oct 20, 2021 1:08 am Post subject: Re: Has anyone had trouble setting up Kadrons? |
is a 132 main jet in Kadrons for my 1600 unthinkable ? |
modok Samba Member
Posted: Wed Oct 20, 2021 1:34 am Post subject: Re: Has anyone had trouble setting up Kadrons? |
130 is normal IMO |
Bug53 Samba Member
Posted: Wed Oct 20, 2021 10:30 am Post subject: Re: Has anyone had trouble setting up Kadrons? |
modok wrote: |
130 is normal IMO |
That's my opinion too but i went down to 127 and the cruise / light throttle popping was worse.
I think 132 is too rich but I may try |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7212 Location: Videbaek Denmark
Posted: Wed Oct 20, 2021 11:35 am Post subject: Re: Has anyone had trouble setting up Kadrons? |
Bug53 wrote: |
modok wrote: |
130 is normal IMO |
That´s a clear indication that something else is off or wrong. You DO NOT cruise on the main circuit unless your cruise speed is above 50-60 mph dependant on the entire set up. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Bug53 Samba Member
Posted: Wed Oct 20, 2021 5:53 pm Post subject: Re: Has anyone had trouble setting up Kadrons? |
Absolutely correct. It did nothing measurable for the condition.
Cranking up the accelerator pumps did a measurable improvement prior to this which makes no sense. The the results were good.
How far in are some of the other Kadron acc. Pump adjusters on other cars?
Kaddie Shack gave me the carbs back with the plastic nuts barely touching.
I slowly turned mine in one turn at a time. Now they have a little more than 1/8” of thread showing.
I know I need to measure the actual output but one turn at a time “seat of the pants” tuning is to satisfy curiosities. |
Bug53 Samba Member
Posted: Wed Oct 20, 2021 8:59 pm Post subject: Re: Has anyone had trouble setting up Kadrons? |
Lingwendil wrote: |
I ended up needing to turn them in so far that I needed spacers to get adequate squirt from them. I used the tips that screw onto the plug wire end of some spark plugs. Before that I wasn't able to tighten the adjustment nuts in enough. |
Wow!
Were these the Brazilian shit I have or an OG set? |
Bug53 Samba Member
Posted: Thu Oct 21, 2021 4:31 am Post subject: Re: Has anyone had trouble setting up Kadrons? |
As far as Jetting I am basically at sea level. S0 my 130/60 setup as delivered from KS should do the trick? I think 55 would be better but that what KS seems to believe will work. |
Posted: Thu Oct 21, 2021 8:01 am Post subject: Re: Has anyone had trouble setting up Kadrons? |
Bug53 wrote: |
Lingwendil wrote: |
Wow!
Brasilian is OG, if I'm not mistaken
That's where they all came from originally. Anything else is basically an Empi knockoff. My set are fairly old, but have had a couple items replaced, If I'mnot mistaken the rebuild kits in them don't behave the same as far as the diphragms in the accelerator pumps, so sometimes you need to shim the adjustment nut for more stroke.
Got the tip from the Kadron manual by Frank Camper-
I'm sending you a PM too,if you don't mind _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
