Reconstruction of the 1937 W30/26
Page: Previous  1, 2, 3 ... 15, 16, 17 ... 27, 28, 29  Next
Jack O'Neill
Jack O'Neill is offline
PostPosted: Sat Sep 25, 2021 1:51 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
I think one of the best parts of this build is that no splits/ovals were harmed. In fact, everything is 100% new metal Smile
Undis
Undis is offline
PostPosted: Sat Sep 25, 2021 4:44 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
originalo wrote:
This one was shot 1937 at a STUTTGART gas station...nice to compare that progressive PORSCHE prototype with a car that was "normal" state of the art at that times.
Thank you very much for the photos of W30 cars. Some of them I had not seen before. Truly appreciated!
Just a comment, if I may, on the first photo you posted. The car in the photo is not of the W30 series but is actually the third of the four cars that were made in 1935. The photo itself is most likely from 1935 because by1936 it already had a facelift with the headlights moved to the front fenders and the cooling slots on the rear lid increased in number and size.
The car has been known as the V1 and had the first all steel construction body. Later it became known as the V3/3. I think that is why it was photographed with the first of the W30 series in front of the Porsche villa in 1937 to showcase the evolution of the all steel construction body.
Here you can see the same car photographed from the rear in 1935.
And here in 1937, about a year after the body modifications, posing together with the first of the W30 cars.
Check out my Facebook page: Volkswagen Prototypes.
mandraks
mandraks is offline
PostPosted: Sat Sep 25, 2021 5:00 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
as i always say: Semaphores make the car!
regards
Uli
Ohio_Style
Ohio_Style is offline
PostPosted: Thu Sep 30, 2021 4:30 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
Thank you for sharing this great build. Can I ask the method used to put the louvers in? Did they make a die and press them in or a different method?
Also, I know the current engine is for mockup, is there information on what the original drivetrain was? Similar to a KDF era car?
Matt Johnson
Slammed Thing
https://www.thesamba.com/vw/forum/viewtopic.php?p=9278729#9278729
Lifted Split Bus Build
https://www.thesamba.com/vw/forum/viewtopic.php?t=738403
View user's profile Send private message Yahoo Messenger Instagram Gallery Classifieds Feedback
Undis
Undis is offline
PostPosted: Fri Oct 01, 2021 10:42 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
For the drivetrain check out my earlier thread https://www.thesamba.com/vw/forum/viewtopic.php?t=343304
It is similar but not the same. The team still has a lot of fabrication ahead of them. The engine was also different in many details so for now they will have to use a KdF era one but who knows what will happen in the future.
I'm about to post more photos. Some will show how the louvers were punched into the sheet-metal.
Undis
Undis is offline
PostPosted: Fri Oct 01, 2021 11:27 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
A little step back in the timeline. Here are more photos of how the louvers were cut into the engine lid. It takes a steady hand to make those cuts!
Undis
Undis is offline
PostPosted: Fri Oct 01, 2021 11:32 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
Channels for the body to engine seal and side shelves inside the engine bay.
Undis
Undis is offline
PostPosted: Fri Oct 01, 2021 11:36 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
The main fire wall panel being installed. Of course another one will be made to sit above this one that will incorporate the rear window glass.
Undis
Undis is offline
PostPosted: Fri Oct 01, 2021 11:53 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
When we look carefully at period photos of the W30 cars you can see the license plate is actually placed (painted) on a raised section of the body. This is a detail entirely missed on the existing replicas. Here are photos of car 14 and car 13 showing this detail. Car 13 of course has been essential in figuring out many of the obscure details. It was sliced in half and presented to interested persons to showcase the all-steel construction of the body. As a result the photos of this half-car show many details normally not visible.
You can really see the profile in this photo
aa390392
aa390392 is offline
PostPosted: Sun Oct 03, 2021 9:56 am    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
At its finest..to see this come together.
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
Two Glove Boxes
Two Glove Boxes is offline
PostPosted: Mon Oct 04, 2021 12:56 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause Applause
Two Glove Boxes
DLK
cyberdyne systems 101
Sambanator
cyberdyne systems 101 is offline
PostPosted: Fri Oct 08, 2021 11:37 am    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
Just perfect! How many of us missed the licence plate surround, if the previous replica builders didn't see it, I'm sure a lot of us didn't either.
Fantastic details, making this as authentic as possible.
When I think of something to say - I'll be the first to know
56' Oval
71' Westy
ferry
ferry is offline
PostPosted: Sun Oct 17, 2021 12:07 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
Thanks for sharing
Amazing to see and respect
Former bmx shop wob61,combat veteran iraq
After several aircooled ,now a 1986 t3 syncro westfalia
Undis
Undis is offline
PostPosted: Wed Oct 20, 2021 11:33 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
Some more photos of the inside of the door showing the window winder mechanism and the Mercedes crank handle.
Undis
Undis is offline
PostPosted: Wed Oct 20, 2021 11:37 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
And some more of the firewall still without the part where the inner window will be.
Undis
Undis is offline
PostPosted: Wed Oct 20, 2021 11:48 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
Those air slots are getting more and more beautiful. Also work has started on the fenders. The team decided to regular Beetle fenders as base to get the shape and then modify the hell out of them to achieve the W30 look. There are extensions being added to the fenders on the inside as the W30 did not have front and rear aprons as on later cars but the fenders extended to the middle of the body.
splitjunkie
splitjunkie is offline
PostPosted: Thu Oct 21, 2021 4:06 am    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
Smart move on the fenders.
You can already see how much more accurate this body is compared to the red and blue ones that VW had made.
Chris
GArBa
GArBa is offline
PostPosted: Thu Oct 21, 2021 6:43 am    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
my exact same impression. the VW-owned repros are clearly too much wide and long.
cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v
Jack O'Neill
PostPosted: Fri Oct 22, 2021 3:43 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
Undis wrote:
I feel weird seeing the front fender before it is properly "converted". Feels like surprising my grandpa in his underwear Smile Anyway, I take they are adjusting one from each side, and then will just "mirror" the other one to the same specs?
Did the restoring team sourced the final headlights? I'm really curious to know where the originals came from, they have such a distinctive look to them!
Undis
Undis is offline
PostPosted: Fri Oct 22, 2021 4:53 pm    Post subject: Re: Reconstruction of the 1937 W30/26 Reply with quote
I'm sure that's what's going to happen. As you can see they have finished the left door and also now working on both left fenders. Once everything looks good they'll repeat it all on the right.
As for the headlights, I don't know for 100% but my guess is those are generic units from Bosch and would not be too difficult to locate. I never understood why the blue one at Autostadt has those weird bulbous headlights as used on some American cars of the time.
Also note how the headlight is gently sunk into the fender at the lower part. Beautiful!
Page 16 of 29
