halbug Samba Member
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Sat Oct 16, 2021 5:37 pm Post subject: Re: Ghia coming home |
Ian Godfrey wrote: |
another BIG milestone, (it just sounds odd in Euro speak 'kilometer stone' ) |
Even the German word for this references "mile": Meilenstein (sounds like my len shtine). |
halbug Samba Member
halbug Samba Member
halbug Samba Member
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Fri Oct 22, 2021 4:42 pm Post subject: Re: Ghia coming home |
Well that looks good, did you have the offset specially made?
Are you using the same wheels front and back?
Nice work |
halbug Samba Member
Posted: Fri Oct 22, 2021 11:34 pm Post subject: Re: Ghia coming home |
Hi Ian, thanks and yes I hade them made. I like that classic smoothies look on a KG Maybe two tone, not sure yet what will go well with the manila yellow and not using white wall tires...
Starting with 195/55-16 I need to see if I can get more under the body in the rear, but I doubt it. Fronts, 195 max but need to check if they will fit.
Body mods, except for some minor fender flare rolling, is no option in my case. _________________ Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
My Berg5: https://www.thesamba.com/vw/forum/viewtopic.php?t=730276&start=0
Rome Samba Member
Posted: Sat Oct 23, 2021 6:48 am Post subject: Re: Ghia coming home |
Quote: |
I like that classic smoothies look on a KG Cool Maybe two tone, nut nut sure yet what will go well with the manila yellow and not using white wall tires... |
How about a stock look from a '64 and '65, using slightly deeper/wider 16" trim rings than the original 15" Lemmerz ones so that they extend deeper down along the outer rim? You can find such rings that are either smooth along their depth, or have a rib for an additional visual break. Here's a shot of Sebastian Gaeta's Manila Yellow original '64 Ghia with the stock 4" black-painted 15" smoothies and the rings. |
halbug Samba Member
halbug Samba Member
Posted: Sat Oct 30, 2021 6:13 pm Post subject: Re: Ghia coming home |
Those brackets are good. the alignment for the sway bar looks much better.
With those master cylinders with the tube sticking out into the foot well, sometimes you need to shorten the tube or increase the inner radius of the tube to stop the push rod binding when the pedal is fully depressed.
Don't make it too short though, as the seal in the master cylinder seals against it.
If you need photo I can send one |
halbug Samba Member
TRS63 Samba Member
Joined: December 17, 2017 Posts: 999 Location: Stuttgart - Germany
halbug Samba Member
TRS63 Samba Member
Tobi/DFL Samba Member
Joined: March 08, 2007 Posts: 3 Location: Wolfsburg, germany
Posted: Mon Nov 08, 2021 3:00 am Post subject: Re: Ghia coming home |
Hi Lars,
I just stumbled upon this thread and what can I say?! Wow, great work! I like your thinking outside the box and I am really looking forward to the progress in your ghia, the gearbox and finally your big engine.
Keep up the great work!
Cheers from Wolfsburg,
Tobi |
halbug Samba Member
halbug Samba Member
Posted: Sat Nov 13, 2021 10:23 am Post subject: Re: Ghia coming home |
Tobi/DFL wrote: |
Hi Lars,
Tobi |
Hi Tobi, great to hear from you!
Your own 2.8 Oxy really inspired me a lot! I have most of the parts together for mine and may start an extra thread on the engine build soon.
The chassis has been taking forever but its coming along now, sorry it will not fit the cal look with the bottom end also lowered
Cheers
Lars _________________ Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
My Berg5: https://www.thesamba.com/vw/forum/viewtopic.php?t=730276&start=0 |
Posted: Sat Nov 13, 2021 7:48 pm Post subject: Re: Ghia coming home |
Lars, the sand bag idea should work, I haven't tried one.
I use a leather bag full of lead shot to 'back it up'. I know some peeps also use steel shot. You'll need a helper to hold it I imagine. I tend to start with a steel hammer then go to the softer hammer.
I made the grease cap on the right this way, then pressed the outer rim flat, then sanded and polished off the peen marks.
it will be interesting to see what other tools are recommended for metal shaping. |
halbug Samba Member
