NoBudgetVWGarage Samba Member
Joined: November 27, 2008 Posts: 755 Location: Quartz Hill,CA
Posted: Fri Oct 22, 2021 7:59 am Post subject: Wide 5 Drawing |
Does anyone happen to have a drawing (DWG or PDF) of the wide 5 stud pattern? Been searching for a few weeks now and cant seem to find one. Appreciate any help. _________________ 1969 Transporter
1968 Ghia
1959 Ghia Hot VW Drag Car |
BYeaton Samba Member
Joined: November 27, 2007 Posts: 362 Location: El Segundo
Posted: Fri Oct 22, 2021 8:32 am Post subject: Re: Wide 5 Drawing |
I assume you mean a technical drawing? I don't think that would be too difficult to create. What are you needing it for? |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1056 Location: St. Louis
Posted: Fri Oct 22, 2021 8:49 am Post subject: Re: Wide 5 Drawing |
like this? I just did this in 2 minutes in SolidWorks. 5 on 205mm right? The holes can be whatever they need to be: 14mm thread, press in stud reamed hole, etc. I just threw 14mm in there referencing the common thread diameter.
_________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous.
I want to build a few adapters for wheel balancing purposes. Mainly for my Bus buddies. I want to bolt one to my spare just to keep it handy on the road. _________________ 1969 Transporter
1968 Ghia
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2078 Location: Bulli Klinik, Colorado Springs
Posted: Fri Oct 22, 2021 8:53 am Post subject: Re: Wide 5 Drawing |
That’s a GREAT idea to have an onboard adapter for road trips. I think we only have one tire shop left in town that can balance a wide 5 wheel. And I’m in the second biggest city in CO. The tire shop owner is a VW fan. Rex Tire. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
RWK Samba Member
Posted: Fri Oct 22, 2021 9:44 am Post subject: Re: Wide 5 Drawing |
I have made some adapters and have some for sale.
PM me. The one with large center hole is the one I rent/loan out, both ave 14mm lug bolt holes.
Otherwise here is the coordinate multiplier from center, all you need, best way to do it.
Obviously use the "5 hole"
_________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Fri Oct 22, 2021 9:49 am Post subject: Re: Wide 5 Drawing |
@jimmyhoffa - Thank You. I was able to draw it up on AutoCad with the information provided. Thanks!
The common 4 to 5 lug adapter is drilled for 12mm. I tried using it to balance a tire but the center is not uniform causing the tire to not be center on the balancer.
This one will accommodate the 14mm Bus lug nut. _________________ 1969 Transporter
1968 Ghia
RWK Samba Member
Posted: Fri Oct 22, 2021 10:50 am Post subject: Re: Wide 5 Drawing |
Also most modern D.R.Os and all CNC have bolt circle patterns built into the control. _________________ 73 Type 181
63 Type 113
BFB Samba Member
Posted: Fri Oct 22, 2021 3:33 pm Post subject: Re: Wide 5 Drawing |
I use an old tire shop that still bubble balances tires. wide 5's fit just fine on those and I'm also convinced the bubble balancer does a better job than modern spin balancers. at the very least the bubble doesn't need calibrated, get neglected, and then becomes inaccurate but the tire guy keeps using it regardless _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Fri Oct 22, 2021 5:34 pm Post subject: Re: Wide 5 Drawing |
When I was running the Waterjet machine at my last job I made up 4 adapters and one with just a hole in the middle, I made them out of 1/2" aluminum...
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
