id plate installing
axel struwe
axel struwe is offline
PostPosted: Fri Oct 22, 2021 4:25 am    Post subject: id plate installing Reply with quote
hi folks,
is there a fabric photo from the 1950‘ from the production line in wolfsburg, where you can see the the pressing maschine for the steel rived of the id plates?
Any?
Axel
peter schepens
peter schepens is offline
PostPosted: Fri Oct 22, 2021 9:40 am    Post subject: Re: id plate installing Reply with quote
Axel, I have no such source... never seen one.
Sorry.. I also want to know it.
Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html
finster
finster is offline
PostPosted: Fri Oct 22, 2021 10:19 am    Post subject: Re: id plate installing Reply with quote
there's a photo of the guy stamping the body numbers but don't recall seeing one of the id plate installation. photos show it fitted before the marriage of body to chassis...I would think before the tank is fitted so there's access to both sides.
virtanen
virtanen is offline
PostPosted: Fri Oct 22, 2021 10:40 pm    Post subject: Re: id plate installing Reply with quote
If you look the original rivets, you can see the heads are flat on the top. Means there were a large heavy flat iron block as a support against all the heads at the same time, and the opposite sides were hammered, maybe manually. The heavy block might have support to the tray shelf under.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
axel struwe
PostPosted: Fri Oct 22, 2021 11:56 pm    Post subject: Re: id plate installing Reply with quote
So, what kind of rivet they used? I have seen them in clear silver as on your pic and also black steel ones. I have some 3x6 black steel rivets, but they are so extrem strong, you can‘t hammered them by hand on a new painted car with a 10kg hammer. But they also use no alluminium rivets. So i ask my self, if they use a spezial build vw tool (not a hammer) to bend the rivets. I actualy use alluminium rivets.
virtanen
virtanen is offline
PostPosted: Sat Oct 23, 2021 1:48 am    Post subject: Re: id plate installing Reply with quote
I have steel rivets which maching the originals. Maybe I will make a test riveting to see how they act.
Mika
New projects
finster
finster is offline
PostPosted: Sat Oct 23, 2021 4:07 am    Post subject: Re: id plate installing Reply with quote
surely on an assembly line they would be using a rivet gun, not a hammer...
virtanen
virtanen is offline
PostPosted: Sat Oct 23, 2021 4:19 am    Post subject: Re: id plate installing Reply with quote
My test plate and new rivets.
My heavy block which was easy to get a perfect support on table, you can't do it with a car like this.
Hammered, not needed a very heavy hammer.
The upper rivets are originals, lowers new:
Matching well to the original:
Original opposite side of my April 1951 unrestored car. I will clean it better to see the riveting better.
Mika
New projects
axel struwe
PostPosted: Sat Oct 23, 2021 7:19 am    Post subject: Re: id plate installing Reply with quote
Thanks Mika!
So i need your rivets… Laughing
You have the correct type.
virtanen
virtanen is offline
PostPosted: Sat Oct 23, 2021 7:43 am    Post subject: Re: id plate installing Reply with quote
Now cleaner better to see how the original hammering look.
Mika
New projects
virtanen
virtanen is offline
PostPosted: Sat Oct 23, 2021 7:45 am    Post subject: Re: id plate installing Reply with quote
Rivets have round head, and it flatten when hammering the opposite side when heavy block of iron is located on the heads.
Mika
New projects
