Que pasa Doc Samba Member
Joined: October 23, 2021 Posts: 5 Location: Baja California Sur, MX
Posted: Sat Oct 23, 2021 4:21 am Post subject: Late model bus 3 rib trans whines |
I purchased a rebuilt 3 rib transaxle from JCS in California. I have it installed in a class 9 baja race vehicle. There is a loud high whining noise while driving it in 4th gear. I know very little about these transaxles. I do know that this noise is not good and am a bit pissed that I spent $2k for it.
I would like to know what possible problems might cause this. |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Sat Oct 23, 2021 5:56 am Post subject: Re: Late model bus 3 rib trans whines |
do you know if it got straight cut 4th gear put in it ? that will make that noise. _________________ where its cold and snowy |
Posted: Sat Oct 23, 2021 10:01 am Post subject: Re: Late model bus 3 rib trans whines |
Unfortunately I know very little about the rebuild, but it is easy enough for me to call for that info.
Just in case though, what else might it be? I wonder if the R&P were not set up right...an outer axle bearing assembly from China was used...I don't know. And as of yet the builder has yet to respond.
I have been to Alaska fishing...not in the cold months obviously. Originally from Seattle.
Thanks for your suggestion. |
SGKent Samba Member
Posted: Sat Oct 23, 2021 10:05 am Post subject: Re: Late model bus 3 rib trans whines |
get a hold of the transmission builder and ask them what to do, or spend $2000 on the tooling to rebuild it yourself. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Oct 23, 2021 10:10 am Post subject: Re: Late model bus 3 rib trans whines |
the R/P would make noise in all gears if it was wrong. you said just in 4th so its right there. if this trany is setup for racing it could have a straight cut gear for strength I ran them in my race car and they are noisy. or they could have not put a matched gear set in and that can be noisy it wount hurt anything but the noise. _________________ where its cold and snowy |
Posted: Sat Oct 23, 2021 10:13 am Post subject: Re: Late model bus 3 rib trans whines |
Two grand is what the rebuilt trans cost me!
It's under warranty, but I am 1,000 miles away from the shop that built it.
I am patiently waiting for the builder to respond... |
Posted: Sat Oct 23, 2021 10:23 am Post subject: Re: Late model bus 3 rib trans whines |
The trans is for a desert baja race Buggy. Either way, your responses have alleviated most of my frustrations, aggravation and worries. For that I am thankful.
Sadly, I have been involved with VW restorations since the late 60's but transaxles have always been farmed out to those who have the equipment and experience. This is the first time ever having this kind of problem. My luck.
Thanks again! |
Posted: Sat Oct 23, 2021 10:47 am Post subject: Re: Late model bus 3 rib trans whines |
Here in Alaska Iam the only trany builder for vw's have been for over 30 years. _________________ where its cold and snowy |
Posted: Sat Oct 23, 2021 11:33 am Post subject: Re: Late model bus 3 rib trans whines |
Your long time expertise gives me even more confidence that I am now able to relax and be more tranquil.
The air cooled motor is very reliable when compared to the water cooled engines up North and to be #1, as you are, ensures a comfortable living I'm sure.
I do appreciate your time and expertise.
If ever you tire of the cold...come south. The Baja 1000 is coming up and I am involved with a chase rig for a friend of a friend. Nov. 15th to the 23rd.
I believe I can wrap this thread up now.
Gracias |
Posted: Sat Oct 23, 2021 2:55 pm Post subject: Re: Late model bus 3 rib trans whines |
I do tire of cold after 50 years or it and Iam setting up my 70 westy to do some snowbirding (as we call it) and go to place where they only snort snow. _________________ where its cold and snowy |
SGKent Samba Member
Posted: Sat Oct 23, 2021 3:08 pm Post subject: Re: Late model bus 3 rib trans whines |
bigbore wrote: |
I do tire of cold after 50 years or it and Iam setting up my 70 westy to do some snowbirding (as we call it) and go to place where they only snort snow. |
glad to see you are up and about. Missed you. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Oct 23, 2021 3:17 pm Post subject: Re: Late model bus 3 rib trans whines |
Hi Steve
ya still here tired but here lots of medical problems but still here. _________________ where its cold and snowy |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Sat Oct 23, 2021 4:59 pm Post subject: Re: Late model bus 3 rib trans whines |
Hi Mike _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
dogmeat Samba Member
Posted: Sat Oct 23, 2021 5:15 pm Post subject: Re: Late model bus 3 rib trans whines |
Hi Friar!!!
you still go by that? |
Posted: Sat Oct 23, 2021 5:17 pm Post subject: Re: Late model bus 3 rib trans whines |
Hi Friar!!!
'ol Beezerboy here |
Posted: Sat Oct 23, 2021 5:32 pm Post subject: Re: Late model bus 3 rib trans whines |
yep still Friar mike still here just been off doing other things like lots of camping and fishing with the bus but now its winter so not as much till next year. Iam doing a couple bigger engines for my 70 and 71 a 1776 and a 1904 but I have one more possibility in the wings for a transplant. Hi aeromech.
https://www.youtube.com/watch?v=q67LNGP3Dn0&t=131s _________________ where its cold and snowy |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1084 Location: wherever my baywindow takes me.
Posted: Mon Oct 25, 2021 12:18 pm Post subject: Re: Late model bus 3 rib trans whines |
Que pasa Doc wrote: |
Do you know what gear ratio was installed for 3rd and 4th? Aftermarket gear sets are not exactly the quietest, new out of the box. You just maybe have a noisy aftermarket 4th gear. Best you talk to your builder first to find out what was used. |
