JMCFAN Samba Member
Joined: May 10, 2020 Posts: 46 Location: Corrales, NM
Posted: Sat Oct 23, 2021 3:15 pm Post subject: Ignition Switch wiring... |
Finishing up my Rebel harness install... so awesome... question on ignition switch...
Switch has...
Bat
IGN
Sol
Harness has
Ignition Switch power
Ignition Switch Start
Ignition Switch Ignition
Coil...
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 851 Location: South Florida
Posted: Sat Oct 23, 2021 3:33 pm Post subject: Re: Ignition Switch wiring... |
JMCFAN wrote: |
... Switch has...
Bat
IGN
Sol
Harness has
Coil...
Connect Bat to Ignition Switch power and on to +12v (battery positive).
Connect IGN to Ignition Switch Ignition and on to + terminal on ignition coil.
Connect Sol to Ignition Switch Start and on to starter solenoid male spade terminal.
Makes sense? |
JMCFAN Samba Member
Posted: Sat Oct 23, 2021 3:56 pm Post subject: Re: Ignition Switch wiring... |
MrGoodtunes wrote: |
JMCFAN wrote: |
... Switch has...
Bat
IGN
Sol
Harness has
Coil...
Makes sense? |
Sorry....not really.. the "and on" is confusing me a bit.... |
Posted: Sat Oct 23, 2021 4:26 pm Post subject: Re: Ignition Switch wiring... |
[quote="JMCFAN"... the "and on" is confusing ...[/quote]
Sorry. Let me try it this way:
(1) Harness wire Ignition Switch power - Connect one end of that wire to Bat on ignition switch, and the other end to +12v (i.e. positive battery terminal, or a fuse that's always +12v when fuse is not blown).
(2) Harness wire Ignition Switch Start - Connect one end of that wire to Sol on ignition switch, and the other end to male spade terminal on starter solenoid.
(3) Harness wire Ignition Switch Ignition - Connect one end of that wire to IGN on ignition switch, and the other end to + terminal on ignition coil. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Oct 23, 2021 5:08 pm Post subject: Re: Ignition Switch wiring... |
On ignition switch...
BAT is source of 12 volts (battery).
IGN is to + side of coil (and any other devices that power is controlled by ignition switch).
SOL is to terminal 50 of starter solenoid.
Sort of like graphic below....
_________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
JMCFAN Samba Member
Posted: Sat Oct 23, 2021 5:09 pm Post subject: Re: Ignition Switch wiring... |
[quote="JMCFAN"... the "and on" is confusing ... |
(3) Harness wire Ignition Switch Ignition - Connect one end of that wire to IGN on ignition switch, and the other end to + terminal on ignition coil.[/quote]
Ok Thanks! will ohm them out since the harness is one piece. Just have 4 wires and 3 spades on the switch |
