dkoesyncro Samba Member
Posted: Sat Oct 23, 2021 5:04 pm Post subject: Window Channel Rust, any Body experts? |
I'm tackling my leaking window. I knew I was going to find holes and some cancer. I'm actually quite happy that it's less than I thought.
1) the dimpling granite like texture, should I take the time to build this up with weld or use a filler product?
2) would a product like monstaliner make sense for this area?
I will be cutting out the bad and replacing it with donor metal.
Mateo83 Samba Member
Joined: September 14, 2021 Posts: 591 Location: Lodi, CA
Posted: Sat Oct 23, 2021 9:12 pm Post subject: Re: Window Channel Rust, any Body experts? |
I saw a video where a guy put fiberglass body filler product where the smaller pinholes were. |
leecat Samba Member
Joined: September 13, 2012 Posts: 773 Location: Regina
Posted: Sat Oct 23, 2021 10:32 pm Post subject: Re: Window Channel Rust, any Body experts? |
Yeah I'd be tempted to fill that up with Dynaglass instead of cut-and-weld. Far quicker and easier. That stuff is like concrete, sand it down to get close once it's set and then just use filler over it. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32436 Location: Reading Pennsylvania
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2066 Location: Bulli Klinik, Colorado Springs
Posted: Sun Oct 24, 2021 7:22 am Post subject: Re: Window Channel Rust, any Body experts? |
Probe the pinholes with an ice pick. It it goes through, you must replace it. Not an especially difficult repair. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
remraf Samba Member
Posted: Sun Oct 24, 2021 7:40 am Post subject: Re: Window Channel Rust, any Body experts? |
Some of the vendors carry replacement sheet metal for the front window. I've been fixing rusty areas on my van and spot welding in new panels is straight forward. If you just have a small area you can also just cut that area out of the larger piece, saves time vs shaping the metal to fit.
Van Cafe
https://www.vancafe.com/9557260-p/9557260.htm |
Joined: January 01, 2007 Posts: 16803 Location: sticksville, ct.
Posted: Sun Oct 24, 2021 9:01 pm Post subject: Re: Window Channel Rust, any Body experts? |
do it right
cut and weld. any poop you put in there will be back to haunt you x10
skills@eurocarsplus wrote: |
passenger side rear window had an obvious hole. i'm trying to do as little paintwork to the van as possible but this is just unavoidable
window out
old rust out
new panel welded in
didn't bother to do a full play by play... my work here doesn't seem to amuse the vanagon crowd as it does the bay forum so i'm just chipping away as i have time |
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
the joker Samba Member
Posted: Mon Oct 25, 2021 9:13 am Post subject: Re: Window Channel Rust, any Body experts? |
rust bullet treatment, tigerhair, quality auto paint, will give you some time. |
