Confusing Ignition shorting
mykidsbug
mykidsbug is offline
PostPosted: Fri Oct 22, 2021 6:58 am    Post subject: Confusing Ignition shorting Reply with quote
So, 5mo ago I got an ignition switch from WW. It worked just fine. during that time, i switch from a 1600 to 1776. I got my Bug back from the shop 6week ago. during that time i turned the bug on 4 times but on the 4th time, i moved the Bug from the garage to the front of my house. Later that evening i went to turn it on, nothing. I turned the switch about 6 times and nothing. not a click or anything. so i decided to wait until morning. the next day it cut on and i returned it to the garage. When i turned it off, i waited to turn it on again, nothing again. i called the mechanic and he stopped by and looked at it, he said its the ignition switch. He did a bypass and it started then said, yeah, its the switch. I returned the switch to WW, they were great!! No hard questions, they switched it out and sent a new one. The switch was replaced... Every 3rd day i turned on the Bug. On last friday, it happened again. i went to turn it on and nothing.
I haven't tried since in case it something I'm doing wrong. im waiting on my mechanic. What could be the problem? It's shorting out or what? Any ideas? [/i]
scarabee
scarabee is offline
PostPosted: Fri Oct 22, 2021 7:13 am    Post subject: Re: Confusing Ignition shorting Reply with quote
Apply voltage directly to the spade terminal on your starter solenoid. If the starter swings, there is a potential problem in the circuit from the switch to the starter. Another possibility is that the starter brushes might be short/sticking and the problem could be intermittent.
Because the VW ignition switch is far from the starter, I like to use a relay close to the starter. Somebody here suggested putting the relay under the rear seat, for protection from the elements. The switch operates the relay and the relay, in turn, operates the solenoid. This makes for a longer ignition switch life.
mukluk
mukluk is offline
PostPosted: Fri Oct 22, 2021 9:39 am    Post subject: Re: Confusing Ignition shorting Reply with quote
Since it sounds like absolutely nothing happens when you switch it on, no warning lights or anything ("I turned the switch about 6 times and nothing. not a click or anything."), you may have a loose connection or degraded wire running between the fuse block and the ignition switch at terminal 30.
Cusser
Cusser is offline
PostPosted: Fri Oct 22, 2021 11:32 am    Post subject: Re: Confusing Ignition shorting Reply with quote
Make sure that your reverse light wiring - if you have that - is NOT attached to the negative terminal of the coil.
mykidsbug
PostPosted: Sat Oct 23, 2021 10:08 pm    Post subject: Re: Confusing Ignition shorting Reply with quote
My bad, when I said nothing, I meant clicking sound. The lights came on, there was power but, no start.
mykidsbug
PostPosted: Sat Oct 23, 2021 10:11 pm    Post subject: Re: Confusing Ignition shorting Reply with quote
[quote="Cusser"]Make sure that your reverse light wiring - if you have that - is NOT attached to the negative terminal of the coil.[/quote
No reverse lights.. ]
mykidsbug
PostPosted: Sat Oct 23, 2021 10:28 pm    Post subject: Re: Confusing Ignition shorting Reply with quote
I had 35 honey-do’s, no time to check on the bug..
Cusser
Cusser is offline
PostPosted: Sun Oct 24, 2021 8:05 am    Post subject: Re: Confusing Ignition shorting Reply with quote
Yes, your "bad", you led folks astray.
If your electrical connections are all clean and tight, sure sounds like a weak 6 volt battery. I'd like to know voltage across the battery terminals WHILE it's making the clicking sound, and failing to spin the engine.
An old 6V battery can be a candidate for a hard start relay.
mykidsbug
PostPosted: Sun Oct 24, 2021 10:17 pm    Post subject: Re: Confusing Ignition shorting Reply with quote
So, I got a chance to turn on the bug, guess what? Shocked
It turned on every time Confused My mechanic stopped by to see why it wasn’t starting. But like I said, every time. The only thing he said is maybe I need to sand / clean my post for a better connection. I know I need a newer fuse box.
For now, it’s starting Laughing I’ll let you know next week if it’s still working…
Next project, YouTube Chris Vallon for new style fuse box… With my luck, the bug will stop working somehow…
Thanks For Your Help… Embarassed Laughing Cool
Cusser
Cusser is offline
PostPosted: Mon Oct 25, 2021 9:37 am    Post subject: Re: Confusing Ignition shorting Reply with quote
2 months ago, with my 1988 Mazda truck, I'd return after a week and the engine would not crank, so wouldn't start, when I turned the key. Then sometimes it would start, and then continue to start.
I had 2 months remaining on a free 3-year battery replacement from Walmart (Johnson Controls batteries like Interstate, Autozone, O'Reilly, Costco) so I swapped in a brand-new battery. No difference.
Mazda trucks of that era are known to have electrical part of ignition switch go bad (I replaced mine about 1995) so I tested that, and EVERY time I turned the key, I'd get 12 volts at the small terminal on the starter solenoid.
Next, I took off ALL the battery cable connections and cleaned them with steel wool, including ALL the ground connections of the negative cable.
So since then: no failures to crank the engine/start. So this stuff can be tricky !!!
ashman40
ashman40 is offline
PostPosted: Mon Oct 25, 2021 4:28 pm    Post subject: Re: Confusing Ignition shorting Reply with quote
Grab a VM and test the voltage at the #30 terminal of the ignition switch while you have someone crank the engine. Then test the voltage on the #50 terminal of the ignition switch. The voltage readings should be the same.
Go to the #50 wire junction below the left rear seat. This is the junction just before the wires exits at the rear of the center tunnel. Test the #50 wire voltage here. It should be very close to the measurement you took at the ignition switch. If you lost more than 0.5v it means excessive resistance in the wires, connections, junctions. Clean your connections to improve the voltage reading.
AshMan40
mykidsbug
PostPosted: Mon Oct 25, 2021 10:20 pm    Post subject: Re: Confusing Ignition shorting Reply with quote
👆🏼 That’s where I need to be…
ashman40… I don’t have one but, harbor or Walmart in a day or two. 12hr shifts…. lol…
mykidsbug
PostPosted: Mon Nov 01, 2021 11:29 pm    Post subject: Re: Confusing Ignition shorting Reply with quote
Saturday i turned the bug on, No problem. Sunday when i turned it on, the starter made a winding sound as if the battery was dying.. I tried it again, and no sound and no start. the lights were on, it just didn't start.
So, I got the VM. I wanted to test the battery first.
The Battery was 12.47
With the key in the on position:
The 15/50 post was 12.47
The 30 post was "0" and just continuity.
The 50 post was "0" and just continuity.
When engaged on the ignition switch, just continuity. I thought the voltage would go up to 12.47, but no.
Thoughts?
ashman40
ashman40 is offline
PostPosted: Tue Nov 02, 2021 9:30 am    Post subject: Re: Confusing Ignition shorting Reply with quote
This sounds like a starter solenoid problem; insufficient current to the starter or a grounding problem.
A bit low (12.6v is 100% state of charge), but unless you have a bad battery there should be enough charge to crank the engine. Once you get the engine cranking reliably, test the battery voltage WHILE the starter is cranking the engine. You should expect a voltage drop, but less than 10.0v at the battery while cranking is too low and may indicate a bad battery. The battery cannot handle the load of the starter.
This doesn't sound correct. The #30 wire is the INPUT to the ignition switch. It provides the constant 12v from the battery and should always have a 12v reading. The #15 and #50 terminals are only powered when the key is turned to ON/RUN and START.
Your VM needs to be set to read DC Voltage (not AC Voltage). If it is not an auto-ranging meter you need to select a range above the expected voltages. For most meters this will be 20v so you can measure voltages in the 12v-15v range.
Ground the black COM probe and use the red probe (connected to the correct port if you have multiple ports) to test for voltage.
Not sure what you mean by "just continuity"? Continuity testing is different from voltage testing. While voltage testing can be done anywhere along a circuit, continuity testing confirms current flow between two points in a circuit. The former is done w/ the battery connected, the later is usually done w/ the circuit disconnected to isolate the segment you are testing.
How are you testing continuity? Depending on your multi meter this is done with the meter set to read Ohms or there may be a specific continuity mode w/ beep sounds.
AshMan40
