Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Tue Oct 26, 2021 4:12 am Post subject: Re: Engine Sitting Low |
2 things don't look right. First, your perimeter seal does not appear to have the "J"-shaped portion into which the edges of the engine tin fit. Looks like that section of the seal is either missing entirely or was cut off cleanly along that white horizontal line.
Next, hard to see in this shot due to not enough light shining onto the front of the engine, but the seal that fits into the channel on the underside of the firewall looks completely out of position. You can also see the top edge of the front engine cross-tin which is usually farther forward. Gives the impression as if the engine is still too far rearward and not sitting against the transmission, but that's not the situation based on your other photos.
73Otto Samba Member
Posted: Tue Oct 26, 2021 5:27 am Post subject: Re: Engine Sitting Low |
Rome wrote: |
Next, hard to see in this shot due to not enough light shining onto the front of the engine, but the seal that fits into the channel on the underside of the firewall looks completely out of position. You can also see the top edge of the front engine cross-tin which is usually farther forward. Gives the impression as if the engine is still too far rearward and not sitting against the transmission, but that's not the situation based on your other photos. |
The J shape loops back up to the white line you are referring to. If you peel it back at the white line the channel is there down.
The front engine cross tin appears to be out of position in the photo but the firewall seal is just jammed behind the tin at the moment. I have since run a flathead under the seal to guide it up and over the front engine tin. I can post a photo of that if you wish. |
THINGONER Samba Member
Joined: April 13, 2008 Posts: 674 Location: riverside ca
Posted: Tue Oct 26, 2021 8:20 am Post subject: Re: Engine Sitting Low |
Is the seal upside down? Or maybe backwards is a better description. |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Tue Oct 26, 2021 8:45 am Post subject: Re: Engine Sitting Low |
SB001...maybe its just an optical illusion but it looks to me like your lower pully is rough from rust and has worn the sides of the belt prematurely causing it to sit lower in the groove than normal and allowing the edges of the top of it to curl up...i use an air die grinder with a plastic encapsulated wire wheel to clean them up...thats why jimbo thinks its the wrong size and too tight... sorry to hijack...but to the OP...most of the seals currently available fit like crap...try another brand
73Otto Samba Member
Posted: Tue Oct 26, 2021 8:52 am Post subject: Re: Engine Sitting Low |
THINGONER wrote: |
No, the orientation is correct. The J is facing the way it would need to in order to hook under the engine tins. |
73Otto Samba Member
Posted: Mon Nov 01, 2021 4:17 am Post subject: Re: Engine Sitting Low |
For anyone following the thread with a similar issue, it ended up being the new seal I put in. Was able to insert the rear engine tin into the J channel and pull the seal down into place before bolting the tin down. Then work it around to the other side tins from above and below with a flathead screw driver and some elbow grease.
Looks nice now. |
sb001 Samba Member
Posted: Mon Nov 01, 2021 6:11 am Post subject: Re: Engine Sitting Low |
73Otto wrote: |
Looks nice now. |
Thanks for that tip- I'll have to try that on mine. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Mon Nov 01, 2021 8:03 am Post subject: Re: Engine Sitting Low |
73Otto wrote: |
Looks nice now. |
Glad that you got it! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
73Otto Samba Member
Posted: Mon Nov 01, 2021 8:23 am Post subject: Re: Engine Sitting Low |
Thanks Jimbo.
sb001 wrote: |
Thanks for that tip- I'll have to try that on mine. |
Hopefully it works out for you as well. |
