Cutting tie rods for 4" narrowed beam on bus
jonreed98
jonreed98 is offline
PostPosted: Fri Oct 15, 2021 10:33 am    Post subject: Cutting tie rods for 4" narrowed beam on bus Reply with quote
Hi everyone, I am looking for feedback. Ive seen lots of tie rod posts but cant find anything related to my questions so here it goes. I have a 63 brazilian bus that I just had the beam narrowed 4" and spindles flipped. The stock tie rods (without ends) is about 19". The place who narrowed my beam sent me narrowed ones that are about 17". When I went to install them they were way to long. My wheels had a lot of toe-in. I cut another 2" off each side for a total of 4" on each rod. They seem to fit perfectly and I am able to get a perfect toe with about 1/8" toe-in in the front. Does this sound odd I have to cut the tie rods 4" on each side. Im not sure why this was necessary but it seems to work
jonreed98
PostPosted: Fri Oct 22, 2021 3:47 pm    Post subject: Re: Cutting tie rods for 4" narrowed beam on bus Reply with quote
well I guess it must not be strange since no one has commented
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Tue Oct 26, 2021 10:24 am    Post subject: Re: Cutting tie rods for 4" narrowed beam on bus Reply with quote
Narrowing the tie rods is normal. Now removing the material where your threads are is not recommended. You really have two options when doing this...
1. If you cut the ends off, make sure you have sufficient threads to hold the TRE securely. You can always add threads with a tap.
2. Most people remove from the center and weld them back together. How you do this is up to you. I remove the material from the center and us hex stock turned down to fit into the tie rod, weld them back together and now I have a hex to adjust my tie rods. Plus this adds strength to the tubes welded back together.
If the route you went works, then you are good!
Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club"
Culito
11010101
Culito is offline
PostPosted: Tue Oct 26, 2021 5:04 pm    Post subject: Re: Cutting tie rods for 4" narrowed beam on bus Reply with quote
On my bug, I removed material from the center and used an old section of sway bar inserted into the center. Welded all the way around and plug welded the insert in two places on each side.
Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
patjones
patjones is offline
PostPosted: Tue Oct 26, 2021 9:09 pm    Post subject: Re: Cutting tie rods for 4" narrowed beam on bus Reply with quote
I bought these and they worked great for my 4inch narrowed beam.
https://valleyautowerks-com.3dcartstores.com/New-narrowed-tie-rod-tubes_p_24.html
jonreed98
PostPosted: Thu Nov 04, 2021 2:55 pm    Post subject: Re: Cutting tie rods for 4" narrowed beam on bus Reply with quote
thanks everyone however I wasnt asking about how to cut the tie rods, I know how to do that, I trimmed the right hand threaded end and retapped it. Im not a big fan of cutting in half a perfectly solid tie rod when cutting the end and rethreading is how it was orginally made. My question was............I had a 4" narrowed beam however cutting 2" of the tie rods didnt work, I had to cut 4" off each side. This seemed weird to me since I only shortened it a total of 4" .
BarryL Premium Member
BarryL is offline
PostPosted: Thu Nov 04, 2021 6:28 pm    Post subject: Re: Cutting tie rods for 4" narrowed beam on bus Reply with quote
Since you had the originals to compare to it does seem ultra weird.
2+2 X 2 = 8 no matter how you slice it (pun intended). When the spindles are flipped does the hole end up in the same linear axis plane?
jonreed98
PostPosted: Sat Nov 13, 2021 7:42 pm    Post subject: Re: Cutting tie rods for 4" narrowed beam on bus Reply with quote
I agree its weird. Im not sure that there is any difference on tie rods length when the spindles are flipped but for sure my bean was narrowed 4" and I had to cut 4" off each tie rod to get the correct geometry . Oh well, It works and the front is aligned so I guess Ill chuck it up a mystery haha
campingbox Premium Member
campingbox is offline
PostPosted: Sun Nov 14, 2021 10:09 am    Post subject: Re: Cutting tie rods for 4" narrowed beam on bus Reply with quote
Imagine it like a triangle.
Hypotenuse = tierod with ends
Opposite side = spindles
Adjacent side = beam
You can do basic geometry to calculate how the hypotenuse will change if you modify either of the sides. In this case he’s modified both sides. The tierods needs to be 2” + shorter than a stock one.
I think the baywindow tiered centers may slightly longer than the split ones. Since they are adjustable, this isn’t always a problem. I expect different manufacturers may have slightly different length.
As far as the best way to modify the tierods, it probably depends on the manufacturer and the type of material they used. If it’s a solid bar I think it’s best to drill and tap the ends deeper. If it’s a tube or probably depends on how the threads on the end were created and whether there is enough material to cut a tap deeper. Sometimes tubes and crimped down or opened up during the threading process and running a standard tap deeper could weaken the ends.
ach60 Premium Member
ach60 is offline
PostPosted: Tue Nov 16, 2021 2:16 am    Post subject: Re: Cutting tie rods for 4" narrowed beam on bus Reply with quote
https://en.wikipedia.org/wiki/Ackermann_steering_geometry
I think this may help, but it also makes me wonder about all the changes we do to VWs, and how they may get us killed.
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
