VeloMikey Samba Member
Posted: Tue Oct 26, 2021 11:54 am Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Ok, so I got no feedback on whether or not I can safely drill new holes for the visor dart that doesn’t match up with the existing holes.
I was also concerned that the other visor would not be placed in the same position — hoping it would be close enough.
So, given this, my current thinking is to drill new holes for both visor darts.
They would then be symmetrical and, as a bonus, the holes would be tight enough to hold in the screws!
Fair warning, if our car has four little screws poking out the top, its all your fault. |
Why do you think the holes are different or won't line up? Take a dental pick (Harbor Freight) and start poking around where you think they should be. The drill bit might grab the headliner and do some damage. _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Tue Oct 26, 2021 11:56 am Post subject: Re: '59 Karmann Ghia fever |
VeloMikey wrote: |
Trylon wrote: |
Why do you think the holes are different or won't line up? Take a dental pick (Harbor Freight) and start poking around where you think they should be. The drill bit might grab the headliner and do some damage. |
I just can’t get the visor on the rod far enough. And I’ve pushed it on so hard that I cannot get it off to fix it. Tried silicone, heat, cold, hammer, pulling, pushing, twisting. It just won’t come off. So I am trying to salvage the situation. _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
Trylon Samba Member
Posted: Tue Oct 26, 2021 4:03 pm Post subject: Re: '59 Karmann Ghia fever |
So this engine is supposedly from 1938:
Man that looks familiar. How is it different from what’s in our car? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Braukuche Samba Member
Posted: Tue Oct 26, 2021 6:46 pm Post subject: Re: '59 Karmann Ghia fever |
It’s not much different on the surface but here’s a list
Aluminum case vs magnesium
No accelerator pump on the carb
Air cleaner not oil bath
Fuel pump has no provision for filter
Distributer is mechanical advance only
“D” regulator?
Seamed fan shroud
No breather on the oil fill
25hp stock v 36hp _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Trylon Samba Member
Posted: Wed Oct 27, 2021 8:30 am Post subject: Re: '59 Karmann Ghia fever |
Know of any pictures of a Ghia before sculpting? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
kingkarmann Samba Member
Posted: Wed Oct 27, 2021 8:57 am Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Know of any pictures of a Ghia before sculpting? |
This
_________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Trylon Samba Member
Posted: Wed Oct 27, 2021 9:03 am Post subject: Re: '59 Karmann Ghia fever |
kingkarmann wrote: |
Trylon wrote: |
This
HA! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Wed Oct 27, 2021 9:06 am Post subject: Re: '59 Karmann Ghia fever |
Braukuche wrote: |
“D” regulator?
Seamed fan shroud
25hp stock v 36hp |
Interesting.
Are all these deemed improvements or were there other factors driving the changes?
Is the coil on top of the distributor? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
Posted: Wed Oct 27, 2021 9:27 am Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Braukuche wrote: |
“D” regulator?
Seamed fan shroud
25hp stock v 36hp |
Interesting.
Is the coil on top of the distributor? |
Nope that's a flat top Bosch distributor, I have one on my Ghia. _________________ John.
Trylon Samba Member
Posted: Wed Oct 27, 2021 9:32 am Post subject: Re: '59 Karmann Ghia fever |
John Moxon wrote: |
Trylon wrote: |
Braukuche wrote: |
“D” regulator?
Seamed fan shroud
25hp stock v 36hp |
Interesting.
Nope that's a flat top Bosch distributor, I have one on my Ghia. |
So where the heck is the coil? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
PeteSC Samba Member
Posted: Wed Oct 27, 2021 10:13 am Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
John Moxon wrote: |
Trylon wrote: |
Braukuche wrote: |
“D” regulator?
Seamed fan shroud
25hp stock v 36hp |
Interesting.
So where the heck is the coil? |
See the two wires just behind the distributor that run through the fan shroud? |
Posted: Wed Oct 27, 2021 10:36 am Post subject: Re: '59 Karmann Ghia fever |
PeteSC wrote: |
Trylon wrote: |
John Moxon wrote: |
Trylon wrote: |
Braukuche wrote: |
“D” regulator?
Seamed fan shroud
25hp stock v 36hp |
Interesting.
...behind the fanshroud.
Posted: Wed Oct 27, 2021 12:14 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Braukuche wrote: |
“D” regulator?
Seamed fan shroud
25hp stock v 36hp |
Interesting.
Improvements coupled with cheaper production costs. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon Samba Member
Posted: Wed Oct 27, 2021 1:17 pm Post subject: Re: '59 Karmann Ghia fever |
So, what we are running is 1930’s technology with improvements.
Perhaps this is the reason the guy in the MGA behind me at Lime Rock said our car was:
“A beautiful piece of s——.”
The guy in front of us in the Austin-Healy said:
“This is the most beautiful car here.”
At least they both agreed it was a looker.
Here they are discussing it:
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Marcdeb Samba Member
Trylon Samba Member
Posted: Wed Oct 27, 2021 2:08 pm Post subject: Re: '59 Karmann Ghia fever |
Marcdeb wrote: |
Wow, he's got some nerve? Why is it some people just have a need to rain on someone else's parade. |
He was a fun guy— I liked him and told him I would share his view on The Samba.
He was a little taken aback.
He presented his comment as though it was something upon which all could agree. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Wed Oct 27, 2021 7:50 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
A guy calling another car a Piece of shit who drives an MGA can and should be disregarded. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon Samba Member
Posted: Wed Oct 27, 2021 7:59 pm Post subject: Re: '59 Karmann Ghia fever |
Didn’t mean to cause a ruckus — I thought it was funny.
On another note, I warned him that I would be slow up hill but he later told me I was speedy.
Do I detect a slight revision of opinion? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
