RandyV Samba Member
Joined: November 23, 2019 Posts: 357 Location: So Cal
Posted: Sat Nov 20, 2021 4:04 pm Post subject: Speaker grill to clock/gage procedures..(cuts?)... |
So just to make sure there's no way around it....*IF* one wants to put anything other than the OG speaker in the grill area, (like those clocks/tachs/etc) then that vertical bar must be cut, correct? (Pic from previous pics as I searched but never found a thread solidifying "the deed". It pains me to cut ANYWHERE on my oval but clock/tach may be worth it as I ain't never putting a speaker there again) (My assuption is that the little rust spots at 12 & 6 oclock suggest this one was cut at some point)
TIA |
Dave Samba Elder
Joined: July 11, 2002 Posts: 2693 Location: The Forest Moon of Endor, in the Redwoods
Posted: Sat Nov 20, 2021 5:30 pm Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
yes, that one has been cut _________________ 2003 Samba Chummie Winner- Best Story
"Those that matter, don't mind,
and those that mind, don't matter" |
Dave Samba Elder
Posted: Sat Nov 20, 2021 5:31 pm Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Sat Nov 20, 2021 7:20 pm Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
I'm guessing that no one has documented with a write-up and photos of how to do it. I will probably be doing this in the future when I will probably be installing an original VDO tachometer in the speaker grill (this old tach has a small signal generator that runs off a flex cable attached to the a crankshaft pulley nut with a center drilled hole for the cable.
If/when I do this, I'll try to remember to write it up and take photos of the install process.
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
RandyV Samba Member
Posted: Sat Nov 20, 2021 9:24 pm Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
BulliBill wrote: |
Bill |
If I don't beat you to it! HOWEVER.........I find it surprising that this is readily accepted & not considered the most vehemently forbidden forms of taboo especially considering you're kinda' cutting into the dash's face, front & center.
And, yet many vintage shows I see folks with clocks, gages, multi-gage clusters etc....all of which would have only been accommodated by cutting that center bar........ANATHEMA!!!
Anyway....guess I'll have to cut if I want to put anything there. |
Matts Bug Parts Samba Member
Posted: Sat Nov 20, 2021 11:16 pm Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
Just cut it. Clocks, tachs and gauge clusters are such beautiful accessories! |
olo Samba Member
Joined: February 09, 2008 Posts: 134 Location: australia
Posted: Sun Nov 21, 2021 1:59 am Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
Personally I wouldn’t t cut it too quickly 😁 research other options, do you really need this accessory? |
lardawge Samba Member
Joined: October 05, 2020 Posts: 355 Location: California
Posted: Sun Nov 21, 2021 6:32 am Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
This was installed at the dealer on my 55. It will continue to live with the car. I would not assume that all these cars you are seeing with cutout dashes were done later in life. Some for sure, but not all.
_________________ 11/2/54 L227 Strato Silver Ragtop - Soon to be L41 Black - Build Thread
1/7/55 L275 Light Beige |
Dan22 Samba Member
Joined: August 30, 2019 Posts: 465 Location: Battle Ground, WA
Posted: Sun Nov 21, 2021 8:49 am Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
Hi lardawge,
Would you be able to post a picture of the trunk side of that gauge setup? It would be nice to see how much was cut and how the wiring was laid out.
Cool original look BTW!
For those that do cut the dash, I suppose you could do it carefully and save the metal for some later reweld back in. _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
Posted: Sun Nov 21, 2021 9:42 am Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
Dan22 wrote: |
Hi lardawge,
For those that do cut the dash, I suppose you could do it carefully and save the metal for some later reweld back in. |
It’s not fully wired in at this point. Car is in progress and unsure if I want to restore the gauge cluster. The quotes I have gotten are “We don’t want to work on it” prices.
RandyV Samba Member
Posted: Sun Nov 21, 2021 11:44 am Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
lardawge wrote: |
Dan22 wrote: |
Hi lardawge,
Lardawge,
Love the "We don't want to work on it".....LOL!! (Ain't it funny how that happens sometimes?? Shows me STILL how this world needs to make people hungry for WORK again!!
Anyway......here's a shot of my virgin dash...(You can see my center bar still in tact in this photo. I almost wish somebody made a 2-gage cluster that fit into either side of that bar, leaving it intact. Why are there only 1 & 3 gage clusters gobbling up that poor bar??? (And, yes, I already met 1 oval owner recently who did cut & told me he saved the bar piece just cuz.) ((shrug))
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9955 Location: Huntington Beach, CA
Posted: Sun Nov 21, 2021 12:24 pm Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
Back in 1988 I installed a oil temp, oil pressure and volt gauges in my Bug, under the dash. I copied this in my current 1970 Bug. Like this. Fabricated the faceplate from a “No Smoking” sign, left over from a job that I completed.
Like this....
Super easy. Maybe 3 hours total to fabricate, and paint it. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
RandyV Samba Member
Posted: Sun Nov 21, 2021 1:54 pm Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
VW_Jimbo wrote: |
Like this....
Super easy. Maybe 3 hours total to fabricate, and paint it. |
And that totally works. Around that same time I mounted a couple gages just free air down low. However....a couple differences.......
#1.) That ain't a precious oval (oval owners chant!)
#2.) The oval speaker grill option has been around (vintage?) and is still around to this day and considered acceptable. And ok maybe 40 years ago it was acceptable to cut since I can recall when ovals were just "older" VW's but now every square inch is precious metal. ((shrug))
And I'll add a 3rd consideration.....So we don't use radios the way we used to...(Bluetooth, etc)....and mono is surely unacceptable anymore anyway so what would leaving it just empty with the bar in place ever be worth keeping?? (Except as a vent which mine does well, and the colder the more noticeable) |
splitjunkie Samba Member
Posted: Sun Nov 21, 2021 2:47 pm Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
You don't have to cut so much out for the three gauge panel. Temporarily mount the panel without the gauges, mark the openings with a sharpie. Find the center of each gauge, drill a small pilot hole and use a hole saw just slightly bigger than the gauge housing for the two side gauges. For the center, just cut the bare minimum of what you need to remove of the center bar and leave the rest.
I'm of the mindset that if you are going to cut, at least do a neat and tidy job of it. _________________ Chris
Bub Samba Member
Joined: June 10, 2004 Posts: 1151 Location: Central Washington
Posted: Tue Nov 23, 2021 5:28 pm Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
I *personally* hate the thought of cutting holes in nice original panels. But mostly because historically it was done very savagely with little regard as to alternatives or whether it was really necessary.
But, as far as proper original accessories go, nothing is really sacred.
Consider the Zwitter starter button? That's the best placement they could come up with?
...or generally almost any VW endorsed non-factory gauges. They didn't hesitate to give you instructions on how to punch a new hole anywhere.
So, IMHO if it's something that would have been period installed I'd put it where they would have put it 50 years ago to make it right. But also...think LONG AND HARD before cutting original metal.
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Wed Nov 24, 2021 4:14 am Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
Bub wrote: |
yes think it over at least a hundred times before you start, and make sure that you know what you're doing while you're at it, because once there is a hole in your dash, you better be happy with it.
Other than that, it's just metal.
Zwitter starter button delete...not the biggest deal in the world, just install a Neimann steering column lock that has a starter button on it. Or just move that starter button elsewhere.
My car comes with plenty of gauge real estate
_________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
RandyV Samba Member
Posted: Wed Nov 24, 2021 7:29 am Post subject: Re: Speaker grill to clock/gage procedures..(cuts?)... |
Bub & Tisius,
Ya, starter button.....Odd placing by VW but hey.....it was what it was I guess.
And wow......Tisius....Definitely some gages to be had on that dash.
Post-oval dash models can just swap those left/right speaker grills with plenty of holes for gages (not to mention less rare dash so probably not even as much concern)
Anyway....I'll probably still do it as it's prime real estate for gaging of some sort and just an empty solid grill is authentic, sure, but kind of a waste, imho so why not. (shrug)
I'll definitely cut-short of total needed & file down to get what I really need (especially the upper where seated eyes could see if you went too far) |
