Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Thu Nov 25, 2021 9:05 am Post subject: Re: New Project - 1974 Ghia |
Not sure if it applies to your year, but you can see the black mat that was supplied with the reproduction rubber I got from the guy who makes them:
_________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
itjustbugsme2 Samba Member
Joined: October 18, 2014 Posts: 246 Location: USA / Ohio
Posted: Thu Nov 25, 2021 9:12 am Post subject: Re: New Project - 1974 Ghia |
Sounds (or doesn't sound-?) Great; went to the site and looks good. I'm going to see if Summit has it since I am about 30 minutes from their main shop - HDQ. Let me ask you your opinion, even if I use the deadening material; "You see any problem, concerns with coating the pans with the "Rubberized Product" I mentioned; I'm simply looking for opinions. Thanks. |
Posted: Fri Jan 07, 2022 12:20 pm Post subject: Re: New Project - 1974 Ghia |
OK; here's the deal. Ghia is still at the Tech shop having the new wiring harness installed - Tech had some other projects and I told Rich I wasn't in a hurry to get the Ghia back home (Winter in Ohio - tough to get her in the back garage) so it is sitting in his nice and warm shop - BUT - when I do get the Ghia, my next step is to start on the interior (no interior, headliner, door panels in it now). I know I can easily order the entire kit online but since it is a Clean Slate I started to think, why not do a cool, custom look. Make the door panels myself and work on the headliner. I have been seeing where a lot of Hot Rod or Custom guys use Headliner Board - has anybody ever had experience with Headliner Board or any flexible board for a headliner? |
Posted: Thu Apr 14, 2022 6:25 am Post subject: Re: New Project - 1974 Ghia |
OK; Ghia is getting there; harness almost complete; once done I'll be inserting all the gauges and switches; Told my tech no rush and I was simply pleased he stored it in his shop over the Ohio winter; it's been a tuff one. Anyway question, request for the group: While doing the work (wiring) tech found (you never know what you'll find on a 48 year old vehicle that had "many hands" on it) that the one front turn signal "bulb insert" was repaired using aluminum foil....so now the question is: 1. Can't track down the bulb insert section alone, any suggestions as to where one might find one. 2. Anyone ever do a repair or replacement on the insert itself. Look forward to the replies. Note: I'll try to get some pics which may better understand the problem and post them. Thanks. |
c21darrel Samba Member
Posted: Thu Apr 14, 2022 11:18 am Post subject: Re: New Project - 1974 Ghia |
Yes; I looked through the Samba Classifieds, didn't find any bulb insert or turn signal completes, thanks for the reply |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Thu Apr 28, 2022 10:54 am Post subject: Re: New Project - 1974 Ghia |
Ghia coming along. As for the turn signal bulb inserts; I'll probably grab any type of insert and wire them in, shouldn't be too difficult. As for the Ghia, it's coming along - Tech is doing a great job with the new harness and fixing any other concern he runs across.
Posted: Tue Jul 05, 2022 6:20 am Post subject: Re: New Project - 1974 Ghia |
OK, been some time but I'm back. Got the Ghia about two weeks ago back from the Techs shop, harness installed, all breaks replaces, a bunch of little hoses and clamps replace with correct ones, and a number of little items corrected, and put back on. She sat all winter but was warm and cozy.
Now the interior, gauges installation begins.
Finally got the Ghia in the back garage to start the interior work.
Took me a week to get everything out to make room - the trick was to get everything out that was crowding up the space, get it back in without getting rid of anything, and make more space, sort of like a "Magic Trick"; just got far too much sh&t, sorry, stuff!
Took so long because:
- Wife's cataract surgery, prep, etc.
- Consulting work got a little busy.
- + - I really messed up my back, pain, can't stand up straight, and instead of resting, I'm up on the roof clearing gutters, hauling stuff in and out of the garage, building a ceiling hanging shelf to put the sh%t , oops sorry, stuff back in the garage, then under the Ghia, jacking it up, then attempting to shoehorn it in the garage. Not something one should do with a bad back!
Oh well, she's in, let the work begin. |
kingkarmann Samba Member
Posted: Tue Jul 05, 2022 8:31 am Post subject: Re: New Project - 1974 Ghia |
itjustbugsme2 wrote: |
Now that's a garage I can relate too!
Sorry about your setbacks but looks like your making great progress _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Braukuche Samba Member
Posted: Tue Jul 05, 2022 11:12 am Post subject: Re: New Project - 1974 Ghia |
kingkarmann wrote: |
Sorry about your setbacks but looks like your making great progress |
Looks a lot like my car cave, too. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Marcdeb Samba Member
Posted: Tue Jul 05, 2022 3:32 pm Post subject: Re: New Project - 1974 Ghia |
Glad your making good progress. Your car looks well worth the work. I can totally relate to your garage space. It can be tough staying organized in this hobby. Even tougher when my memory doesn't want to cooperate. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Posted: Tue Jul 05, 2022 6:01 pm Post subject: Re: New Project - 1974 Ghia |
Yea; the space is a concern but I made half the back shop a "Man Cave" and left this section for any cars, MCs, or whatever; not big enough. Oh well, it will work, for now, had a number of cars back there: MGB, Older 60s Bug, Ford Maverick, little tight but do-able.
Check out my other post questioning rebuilding, and repairing the clock, if you have any knowledge, or suggestions I would appreciate it.
Later; |
