Bug53 Samba Member
Joined: February 22, 2021 Posts: 704 Location: Pawcatuck, CT.
Posted: Mon Nov 22, 2021 10:30 am Post subject: The circular groove on the face of the oil pump |
The circular groove on the face of the oil pump.
How important is this groove and how adverse is it if gasket sealant is used on that gasket? |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Tue Nov 23, 2021 12:27 pm Post subject: Re: The circular groove on the face of the oil pump |
It facilitates the recirculation of excess oil pressure back thru the pump. I believe it is meant to prevent pressure leaks from occurring at the gasket when the pump is outputting more oil that the engine requires.
It was not meant to be filled in or blocked with sealant.
As for the big question: How much does it matter if it is? I'm not sure, maybe it would start leaking eventually? Maybe it would from the very start? I'd be curious to hear someone's actual results. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Tue Nov 23, 2021 9:06 pm Post subject: Re: The circular groove on the face of the oil pump |
The way VW made the oil pump, it's made to be used with a paper gasket and without any sealant, and the groove is a nice touch that reduces leakage. Notice I said reduce not prevent
Some people would spray some "high tack" sealant on the cover to hold the gasket in place, that's probbly ok.
Some people put a thin film of permatex 3/300/avaition on everything, and that's mostly ok but.....
If putting sealant on the gasket, I would not put the sealant around the boltholes. Just stay 1/4 inch away from them so there won't be any unplanned extrusion when you tighten the bolts.
Now the ideal way to deal with this thing today might be a different story.
I would make the oil pump surface smooth non-directional finish and adhere the gasket to the steel cover with a sealant/adhesive, if you are using a steel cover. Steel cover machined flat but not too smooth. Flanged nuts with 565 sealant. I think that would hold up better and still being "original'
The ideal may be different depending on if you are using a gasket, and if the cover is steel or aluminum, and what kind of sealant to use.
IMO if a heavy aluminum cover is used you don't necessarily need a gasket. |
Bug53 Samba Member
Posted: Wed Nov 24, 2021 1:24 am Post subject: Re: The circular groove on the face of the oil pump |
Mine is a CB performance full flow pump.
It doesn't require any drilling or tapping as it's all done with the pump.
26mm Shadek with the CB machined aluminum cover and inlet/outlet.
Has a gasket which is different than stock. |
modok Samba Member
Posted: Wed Nov 24, 2021 1:34 am Post subject: Re: The circular groove on the face of the oil pump |
I see. Totally different then. Good choice tho.
Careful not to overtighten the fittings it can distort the cover causing a leak.
Full strength loctite makes a fantastic pipe thread sealant, tho it is semi-permanent. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Wed Nov 24, 2021 7:00 am Post subject: Re: The circular groove on the face of the oil pump |
If you look at the face of the oil pump, there is a short groove that connects the main circular groove to the low pressure side of the pump. In theory this would put negative pressure in the groove and prevent leaking around the pump cover.
Maybe they did this to speed up production by omitting the step of applying sealant on the pump? Can't really apply sealant on the cover until ready to install it. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5600 Location: 37.5N 77.1W
Posted: Thu Nov 25, 2021 9:35 am Post subject: Re: The circular groove on the face of the oil pump |
Quote: |
a short groove that connects the main circular groove to the low pressure side of the pump. In theory this would put negative pressure in the groove and prevent leaking around the pump cover. |
somebody just asked me what the short groove was for, now I can answer like I knew all along. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Thu Nov 25, 2021 2:02 pm Post subject: Re: The circular groove on the face of the oil pump |
I do the oil pump and sump cover at the same time.
Here is why:
I put black RTV on my fingers and work it into the sump gaskets and install the sump.
With the residual sealant on my fingers, I rub into the oil pump gaskets. Just barely enough to make them black in color. No real thickness, just carefully messaging residuals into the gasket.
That way nothing squeezes out plugging up the return loop. Yet I still have the dryness that using sealant can bring. |
Bug53 Samba Member
Posted: Thu Nov 25, 2021 2:19 pm Post subject: Re: The circular groove on the face of the oil pump |
I have some modification info to share about the CB performance pump.
The tin behind the pulley needs to be modified or the pulley scrapes.
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Thu Nov 25, 2021 2:23 pm Post subject: Re: The circular groove on the face of the oil pump |
Yeah, you can cut it, but It's preferred to just pound a dent in there with a ball-peen hammer. It sounds tricky but it's not difficult at all. Just take your time. Pound, fit, pound, fit. Make sure the pulley clears the dent and you're golden.
Now you should ideally fill that hole somehow or road grim will get everywhere up through there, in addition to recirculating a bit of hot air back into the engine bay. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76909 Location: Sneaking up behind you
Posted: Thu Nov 25, 2021 3:52 pm Post subject: Re: The circular groove on the face of the oil pump |
Just grind some aluminum off the cover, there's plenty of meat left after. _________________ Glenn
Member #1009
#BlueSquare |
Bug53 Samba Member
Posted: Thu Nov 25, 2021 6:57 pm Post subject: Re: The circular groove on the face of the oil pump |
I originally thought about hammering the tin but didn't want to beat against the aluminum pump. Didn't think of grinding the cover. I probably wouldn't have gone with the grinding route. |
Posted: Thu Nov 25, 2021 8:04 pm Post subject: Re: The circular groove on the face of the oil pump |
Bug53 wrote: |
Best way to do it before you install the pulley and trap that tin in place.
What you did is satisfactory, BUT a dimple would have worked and looked better. Also by cutting a hole there you are allowing hot exhaust gas to get sucked in. Doesn't really matter unless it's a street car sitting in traffic tho. _________________ 1967 Bug ( the daily rod )
Bug53 Samba Member
Posted: Fri Nov 26, 2021 12:14 am Post subject: Re: The circular groove on the face of the oil pump |
evanfrucht wrote: |
Bug53 wrote: |
What you did is satisfactory, BUT a dimple would have worked and looked better. Also by cutting a hole there you are allowing hot exhaust gas to get sucked in. Doesn't really matter unless it's a street car sitting in traffic tho. |
I sealed sealed the small gap with high temp. RTV. |
Bug53 Samba Member
Posted: Fri Nov 26, 2021 12:16 am Post subject: Re: The circular groove on the face of the oil pump |
evanfrucht wrote: |
Bug53 wrote: |
