jbannon Samba Member
Posted: Mon Aug 30, 2021 4:09 am Post subject: Mann Industrial Air Filters |
I was hoping some of you could help me with the following questions regarding Mann Industrial Air Filters:
- Is it acceptable / advisable / kosher to use Mann Industrial Air Filters with dual carb set ups on vintage speed 36hp motors?
- Does anyone have links to a DIY article on how to restore these filters? I looked on The Samba but could not find anything.
- Has anyone modified these filters to accept modern filtration instead of the horse hair / fiber that was originally used? Are there any other worthwhile modifications to make them perform better? Essentially I want the vintage look but adequate breathing.
Thanks. |
Joined: June 24, 2015 Posts: 718 Location: Rialto. CA
Posted: Mon Sep 06, 2021 3:09 am Post subject: Re: Mann Industrial Air Filters |
Do you have a pic or link of your Air filters you want to use ... |
Posted: Mon Sep 06, 2021 3:20 am Post subject: Re: Mann Industrial Air Filters |
Thanks for replying. Here are some pictures.
Posted: Mon Sep 06, 2021 9:39 am Post subject: Re: Mann Industrial Air Filters |
No ..no one that I know or seen have replacement insert filters for these ... I believe you can just clean them ...I seen guys soak these with a degreaser soap/water ..and let to dry ...also seen guys soda blast them and soaked /dry ... |
Posted: Mon Sep 06, 2021 9:44 am Post subject: Re: Mann Industrial Air Filters |
Thanks! |
hutmo Samba Member
Joined: February 05, 2002 Posts: 37 Location: Pittsburgh, PA
Posted: Sat Sep 11, 2021 7:47 am Post subject: Re: Mann Industrial Air Filters |
turn them over and soak in gasoline.
After mine dry i spray the fiber with K&N air filter oil.
Best regards,
HUTMO _________________ What if the Hokey Pokey really is what it is all about?
Samba Member #1115
Joined Feb 6, 2002 |
Posted: Sat Sep 11, 2021 7:52 am Post subject: Re: Mann Industrial Air Filters |
Thank you for the reply. Did your restore your filters (paint, etc) after you cleaned them? Any suggestions on dealing with the filter material?
Thanks again. |
72MUST Samba Member
Posted: Fri Nov 26, 2021 4:54 am Post subject: Re: Mann Industrial Air Filters |
Cool looking filters , what would their original application have been ? Any Mann part number or similar ? What diameter is it where it fits carb ? |
Posted: Fri Nov 26, 2021 3:03 pm Post subject: Re: Mann Industrial Air Filters |
72MUST wrote: |
These filters where used on many vw engines these were made for dusty areas ..lots of ww2 vws used these type of air filters ...even vws after the war vw guys used these ...these will fit any vw carb from the 26 vfis ,28pci. 28 pict, solex 32pbic |
72MUST Samba Member
Posted: Fri Nov 26, 2021 4:27 pm Post subject: Re: Mann Industrial Air Filters |
Thanks for info , is there something similar , even from a non VW that would fit Kadrons ? |
Posted: Fri Nov 26, 2021 4:49 pm Post subject: Re: Mann Industrial Air Filters |
72MUST wrote: |
No these won't fit Kadrons...I don't think I have seen anything similar.... |
Iowa Mark Samba Member
Posted: Fri Nov 26, 2021 6:14 pm Post subject: Re: Mann Industrial Air Filters |
Not Mann filters, but like Kadrons, my type 3 carbs have a center stud mounting. I stared with some cheap 4" filters and then found at a resterant supply store some stainless drop-in holders that came in several sizes that can be made into air cleaner covers.
