fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Fri Nov 26, 2021 2:13 pm Post subject: MSD 8485 distibutor installled photos? |
Does anyone have a photo of an MSD 8485 distributor installed, with cap on? Also anyone have a photo of it installed but with cap off and rotor pointing to #1?
I searched the gallery and saw a couple pictures but these were with cap on only and on a type 4, not a type 1 engine.
I installed my 8485 with the small offset on the shaft towards the crank pulley, but the MSD label faces the front (flywheel end of the engine) and the magnetic pickup is on the right side, just next to my fuel pump block off plate.
I don't think I installed it correctly, and these pictures would be an immense help.
Many thanks in advance!
Ted |
KEGZ Samba Member
Joined: October 11, 2021 Posts: 288 Location: Whales Vagina
Posted: Fri Nov 26, 2021 3:23 pm Post subject: Re: MSD 8485 distibutor installled photos? |
Should check for distributor pinion gear orientation before questioning your distributor install. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Fri Nov 26, 2021 3:37 pm Post subject: Re: MSD 8485 distibutor installled photos? |
It installs like all the other distributors. Push it in and rotate the rotor until the drive engages the driveshaft. Rotate the engine so it at tdc on #1. Rotate the distributor body so that #1 mark is pointed to by the rotor.
Connect the wires 1-4-3-2 clockwise. Start the engine and set the timing. _________________ Glenn
Member #1009
#BlueSquare |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Fri Nov 26, 2021 5:39 pm Post subject: Re: MSD 8485 distibutor installled photos? |
Her ya go. Notice looking down 4 is almost exactly 6 o clock and 3 is almost 9 o clock. That will get you close so you dont have it running shitty when it first fires up
_________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Sat Nov 27, 2021 7:02 am Post subject: Re: MSD 8485 distibutor installled photos? |
Thanks KEGZ, Glenn and jpaull! |
Posted: Sat Nov 27, 2021 10:37 am Post subject: Re: MSD 8485 distibutor installed photos? |
Glenn Mr. 010
Posted: Sat Nov 27, 2021 10:41 am Post subject: Re: MSD 8485 distibutor installled photos? |
Ignore the cap. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Nov 27, 2021 10:43 am Post subject: Re: MSD 8485 distibutor installled photos? |
Thanks Glenn. I caught and removed my last (ignorant) post after comparing my setup more closely to the photos jpaull kindly provided. I should be all set now.
Ted |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3580 Location: viroqua wi.
Posted: Sat Nov 27, 2021 11:51 am Post subject: Re: MSD 8485 distibutor installled photos? |
Turn it like you like it and arrange the plug wires accordingly. |
Posted: Sat Nov 27, 2021 1:00 pm Post subject: Re: MSD 8485 distibutor installled photos? |
bsairhead wrote: |
Hard to go wrong with this approach
thanks
Ted |
