Plastic clips for fuel gauge cable
sfcharr
sfcharr is offline
PostPosted: Fri Jul 07, 2006 9:35 am    Post subject: Plastic clips for fuel gauge cable Reply with quote
I have a 67 vert that needs a couple of the clips that hold the cable for the fuel gage in the trunk. Anyone know what I'm talking about? Know where I can find some replacements
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Fri Jul 07, 2006 2:20 pm    Post subject: Reply with quote
You might check with Wolfsburg West or BFY obsolete. I have found all sorts of clips at Ace Hardware. Yours I believe were clear/white plastic.
dieselbuggy
dieselbuggy is offline
PostPosted: Sat Nov 27, 2021 8:01 pm    Post subject: Re: Plastic clips for fuel gage cable Reply with quote
I am also looking for these clips for my 67. Already looked in the VW parts manual dated august 1972 and dd not find them listed. Does anyone know what the part number is?
thomas.
thomas. is offline
PostPosted: Sun Nov 28, 2021 7:44 am    Post subject: Re: Plastic clips for fuel gauge cable Reply with quote
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111201261
dieselbuggy
PostPosted: Sun Nov 28, 2021 2:49 pm    Post subject: Re: Plastic clips for fuel gauge cable Reply with quote
Thanks for the info, but those are for the fuel line. Here's is some pics of the cable clips. The hole in the luggage area is smaller and the clip holding the cable is also smaller. 3 are used, you can see a hole to the right of the radio to secure it there as well
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Sun Nov 28, 2021 4:14 pm    Post subject: Re: Plastic clips for fuel gauge cable Reply with quote
Look at part # 211 843 663
https://www.thesamba.com/vw/forum/viewtopic.php?p=9161406
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
dieselbuggy
PostPosted: Sun Nov 28, 2021 5:09 pm    Post subject: Re: Plastic clips for fuel gauge cable Reply with quote
That's it!!! Found in the 1968-1972 Bus parts manual. Used for holding inner siding door rod (pull rod guide). Thank You
VOLKSWAGNUT
PostPosted: Mon Nov 29, 2021 7:53 am    Post subject: Re: Plastic clips for fuel gauge cable Reply with quote
HOLD ON !! Speak to the hand Laughing
I think the true cable clip part number is 311 971 939. It is NLA BUT the rod clip may fill the slot.
Let us know if the Type 2 rod clip fits . It was the only clip I found a few years ago that has the near same look for another member.
aka Ken {o\!/o}
dieselbuggy
PostPosted: Mon Nov 29, 2021 9:08 am    Post subject: Re: Plastic clips for fuel gauge cable Reply with quote
Will get some on my next parts order and let you know. Found out those clips are also used on 80-85 Vanagons.
