Vana Guy Samba Member
Posted: Sat Oct 30, 2021 10:10 am Post subject: Re: 14" Tire Options |
I am trying the GT Radial 205/70/14 98.
Full set less than $400 out the door, on the car.
I started out trying 2, which I have tried on the rear and front.
Noticeably smoother on the bumps. Seemed quite enough, no really noticeable road noise. Driving over the raised center line reflectors in the road (my preferred bump/noise test) the GT Radials would make a thump noise, where my old off-brand C rated tires would make a bang. Definitely understeer installed on the front, compared to the off-brand C rated tires I had on the car. But then I thought the C rated tires tended to oversteer. I think the van has more movement in cross winds.
Having 2 more installed, will be a couple days. Will they flat-spot? Will get back here when I have some more info. |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 951 Location: Northern California
Posted: Sat Oct 30, 2021 10:14 am Post subject: Re: 14" Tire Options |
Vana Guy wrote: |
Having 2 more installed, will be a couple days. Will get back here when I have some more info. |
Yep, we are also running these on our Carat. Very satisfied so far. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
Posted: Sat Nov 06, 2021 12:10 pm Post subject: Re: 14" Tire Options |
My tin top has the middle seat removed. It is used for day trips only, maybe 60 miles round trip on mostly country roads. Typical max load is about 300 lbs humanoid, 100 lbs canine and maybe 50 lbs food and beverage. I never travel faster than 60mph.
That being said, I love the GT Radial 205/70/14 98 tires. I now have them on all 4 corners and the transformation is awesome. My tin top now rides like a civilized automobile. Much smoother and much less road noise.
The understeer I mentioned earlier is gone now that all tires are the same. Steering feels very neutral. Cross wind has not yet been tested with tires on all four corners, but will report back. I'm running 40 psi rear and 35 front. Very pleased with the tires indeed. |
Vanagon Nut Samba Member
Posted: Sat Nov 06, 2021 1:00 pm Post subject: Re: 14" Tire Options |
GT Radial 205/70/14 98 led me to this:
Galaxy Commercial All Weather Tire
https://thetirewire.ca/product/galaxy-st205-75r14-road-rider-st-iv-c6-tl/
I assume price is CAD (.ca web site)
Does Load Range / Ply: C6 mean 6 ply load range C ?
If these are ok for a Westy, would 205 width/contact patch make turning manual steering *really* tough when stationary?
Weight: 12 lbs
Rim Diameter: 14"
Speed Index: 100/96L
Sidewall: 7.7
Original Tread Depth: 10
Max. Load Inf. Single: 50
Max. Weight Capacity Single: 1760
Overall Diameter: 26.1
Load Range / Ply: C6 _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9935 Location: Orbiting San Diego
Posted: Sat Nov 06, 2021 2:06 pm Post subject: Re: 14" Tire Options |
Tires with ST at the start of the size are special trailer tires.
Not OK for a Westy, IMHO.
Mark
Vanagon Nut wrote: |
.... led me to this:
Weight: 12 lbs
.....[/b] |
Xevin Samba Member
Posted: Sat Nov 06, 2021 4:44 pm Post subject: Re: 14" Tire Options |
If you are not going to run General Grabbers and want a stockish tire. Why fool around. I do respect people trying different tires for their van. But…. DJKeev with the Yokohama’s and me with the Hankooks already did your homework. DJ has 11k miles on the Yokohama’s and I’ve put about 3k to 4K miles on my Hankooks. We are doing just fine so far in them in various types of terrain. I can’t give opinion on snow yet. As we in Oregon started salting roads. The Van will stay parked in snow. Which lasts for a week in Oregon. Most of the time. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Sat Nov 06, 2021 5:16 pm Post subject: Re: 14" Tire Options |
Ok right on Mark. Thanks. Indeed they're advertised for trailer use but I was thinking of how some (including me) used to use Nexen tires and that those might've been trailer tires but I don't think that's true. They were LT tires:
https://www.thesamba.com/vw/forum/viewtopic.php?p=...o.#5970930
crazyvwvanman wrote: |
Mark
VE7TBN |
moxnix Samba Member
Joined: September 11, 2003 Posts: 667 Location: Mpls Minn.
brickster Samba Member
Joined: January 05, 2004 Posts: 512 Location: CO, USA
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
oasis Samba Member
Posted: Sat Dec 11, 2021 1:02 am Post subject: Re: 14" Tire Options |
djkeev wrote: |
djkeev wrote: |
I had mentioned that my NEXEN's were horrible on mesh decks. They went every which way but straight!
These Yokohama Y 356’s tracked true and straight.
I ordered a 5th for a new spare. I should have gotten five to begin with!
The day brought yet more rain, still surefooted on wet highways.
I am now at 13,000 miles.
Lots of tread left.
No complaints but I am now entering winter so it will be interesting to see how they do on ice and snow.
This is a great update!
When we had our '85, it was not so great in the snow, although I didn't think the Continental or Michelin tires that were available back then were to blame. I'm not sure Sinka will see much snow, but I avoid all bad weather with the Nexen tires on it now ... and they are wearing out alarmingly fast.
I had those exact Yokohama tires on my Thing. It was great the two times I drove it in the snow. We once bought a Christmas tree with 4-6 inches on the volunteer fire department's parking lot (top down so we could haul the tree back home), and we left the parking lot with no problem -- something a Jeep that was there couldn't honestly say. Of course, Thing was lighter than the Jeep and a Vanagon.
I need to buy a set of alloys; then I'm going to get Yokohama tires. Their wear wasn't noticeable on Thing, but glad to see 13k miles on a Vanagon has been a success. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
plummerdesign Samba Member
Posted: Mon Dec 20, 2021 11:33 pm Post subject: Re: 14" Tire Options |
Dave,
The Y356 LT185R14’s…how noisy are they? The tread looks like the Nankang tire. Thinking these might be a fine alternative Westfalia tire, yes?
Jeffery : ) _________________ It is old and green and it makes me grin.
1984 Westfalia 1.9 |
Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 647 Location: California
Posted: Mon Jan 31, 2022 3:53 pm Post subject: Re: 14" Tire Options |
Hi Guys,
So I searched this thread high and low and also looked at a few others.
I have a 1989 Single Cab with a stock diesel motor, no turbo, so it's a slow moving vehicle that will be used mostly around town and used as a truck. I occasionally will take it on some dirt fire roads for camping.
I'm looking to make it look a little more aggressive in terms of its stance. I originally wanted Maxis Bighorns because I know someone who has used these and they look great. Unfortunately, I can't get them here in the USA.
So, I am looking at getting the General Grabbers
https://www.amazon.com/General-Grabber-All-Terrain...amp;sr=8-2
Or the Forceum MT LT tires
https://www.amazon.com/Forceum-Mud-Terrain-Radial-...amp;sr=8-3
Of the Kumo Road Ventures MT KL 71
https://www.amazon.com/27x8-50R14LT-Kumho-Road-Ven...amp;sr=8-1
I'm kinda leaning towards the General Grabbers for all the reasons I read in this thread.
However, I like the look of the Forceum and the Kumho ones too. The price for all three is close, so that is not an issue.
Do any of you have experience with the Forecum or Kumho tires I linked above? I'm leaning towards the Forecum more than the Kumho, but the Generals might be the ones if I can't get any good info about the two others.
Thanks for any help. Here is a picture of the truck.
Posted: Mon Jan 31, 2022 5:33 pm Post subject: Re: 14" Tire Options |
I have no experience with any of those three tires but I can say that since the Forceum has NO real siping that in my experience it will be horrible in the rain or snow or wet grass, despite what they claim. It may look cool but siping is where it is at for traction in adverse weather. Take a look at the treads of the other two and you will see some siping to enhance traction. _________________ Dave O
The Western Syncro build
deadaheadub Samba Member
Joined: April 18, 2004 Posts: 787 Location: New Mexico
Posted: Mon Jan 31, 2022 6:03 pm Post subject: Re: 14" Tire Options |
Your link to the Kumos is actually a duplicate of the link to the General Grabbers. _________________ Grateful daily,
Ryan
______________________________________
Past loves: '65 Bug, '70 Westy poptop, '64 Squareback project, '76 Westy tintop "Loose Lucy", '76 Westy tintop "Sharee"
Current:'84 Westy poptop "Ramblin' Rose- Rosie" w/ 2003 Subaru EJ25 conversion |
Posted: Mon Jan 31, 2022 6:48 pm Post subject: Re: 14" Tire Options |
I fixed the link, thanks for the heads up. |
tomtom50 Samba Member
Posted: Sun Feb 20, 2022 12:26 pm Post subject: Maxxis Bravo 205/70R14 102/100Q, D (8 Ply) Van tire |
Hi, I almost bought the GT Radial Touring VP Plus 205/70 R14 98T XL BSW, $58 each(!!) at Discount tire.
After the 9% derating of a passenger tire they are 18lb shy of the 1521lb Syncro rear GAWR (1653/1.1 = 1503). They probably would have been fine, but instead I bought Maxxis Bravo UE-168 205/70R14 102/100Q, D (8 Ply) from Priority Tire, $108 each.
It is the only commercial rated 205/70R14 tire I found. Several commercial 185R14 options are out there, but 205/70R14 is an inch wider, and that sounds like goodness. Since they are commercial tires there is no de-rating, the full 1874 load rating applies, 23% over the VW requirement.
I thought I'd mention them, because Michelin MXL 205/70R14 were supplied with Vanagons, so it is an OEM size, but it is hard to find that (inch wider) size in a commercial tire. |
