sb001 Samba Member
Posted: Sat Nov 06, 2021 12:21 pm Post subject: Re: 1968 autostick - correct equipment? |
glutamodo wrote: |
once upon a time all angled pumps used the short pushrod but that changed in the aftermarket. |
It did?
Learn something new every day on here. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
crankbait09 Samba Member
Joined: October 10, 2016 Posts: 1304 Location: Cincinnati, Ohio
Posted: Sat Nov 13, 2021 12:48 pm Post subject: Re: 1968 autostick - correct equipment? |
back to the fuel pump....Got the new one in today. Turns out the base of the new pump is slightly thinner than the old pump I had. The mechanical lever at the bottom of the fuel pump is actually further up into the body on the older pump. Those two differences make the existing rod too long. I definitely have the right fuel pump, the one for an alternator set up. So that means I need to buy the smaller rod, correct? (the existing rod is 107mm)
_________________ 1963 Ragtop |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Sat Nov 13, 2021 1:44 pm Post subject: Re: 1968 autostick - correct equipment? |
crankbait09 wrote: |
See how the lever in the recess of the angled fuel pump extends lower? You need the 100mm length fuel pump pushrod for that.
I have read that some folks have shortened a 107/108mm pushrod and used that.... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Nov 13, 2021 1:51 pm Post subject: Re: 1968 autostick - correct equipment? |
that's easy enough. thank you _________________ 1963 Ragtop |
Posted: Mon Nov 29, 2021 3:35 pm Post subject: Re: 1968 autostick - correct equipment? |
can anyone confirm the fuel line size (braided hoses) that are used for an autostick / early 70s beetle?? If I am not mistaken, it should be 5mm I.D., right? When I received this, I had three different sizes of hoses, assumed it should have all the same I.D.
Also, the oil fill tube. I am seeing conflicting information. Can anyone tell me is the oil fill tube for this car should have the straight tube that passes down through the tin, or if it should have the end that has bends in it after it passes through the tin. I am seeing oil tubes in the classifieds that both say that they are for this engine, but obviously look different. _________________ 1963 Ragtop |
volkenstein Samba Member
Joined: June 26, 2005 Posts: 858 Location: The Land of Oz
Posted: Tue Nov 30, 2021 9:27 pm Post subject: Re: 1968 autostick - correct equipment? |
crankbait,
Sounds about right. The fuel line spec didn't change much if it fed a carb.
You need to purchase a BREATHER assembly that will fit YOUR tinware. I hope whatever you get is a fully assembled Gen/Alt stand + breather that fits correctly. The gland nut holding the two together can be a major PITA to extract.
HTH
Volkenstein _________________ 71 RHD AS Super - "Klaus"...
Wisdom of youth, energy of old age... |
