Maltboy! Samba Member
Joined: June 17, 2006 Posts: 137 Location: Santa Fe, Texas
Posted: Wed Dec 01, 2021 11:36 am Post subject: Wiper blade adapters for 7mm J hook found - thanks 60ragtop! |
Does anyone know who makes wiper blades or blade adapters to fit 7mm wide J-hook arms? It looks like everything is 9mm. I couldn't find any good answers on the forum.
UPDATE - Bosch doesn't make adapters for 7mm J hook arms anymore.
DOES ANYONE HAVE A SET THEY'D BE WILLING TO PART WITH?
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Dec 01, 2021 11:59 am Post subject: Re: Wiper blades for 7mm J-hook arms |
Bosch micro edge- should have the right adapter included
just enter your year for proper fit
https://www.autohausaz.com/pn/BS-3397118800 _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Wed Dec 01, 2021 1:03 pm Post subject: Re: Wiper blades for 7mm J-hook arms |
I have a set of the 40715 micro-edge blades. They say they will work but they are for a 9mm wide hook or a 7mm bayonet, but not a 7mm hook. They are factory arms with the VW logo, different lengths with L/R markings.
BUGGED11111 Samba Member
Joined: February 03, 2006 Posts: 1819 Location: Oregon
Posted: Wed Dec 01, 2021 1:31 pm Post subject: Re: Wiper blades for 7mm J-hook arms |
A couple years ago I bought a couple sets of Bosch micro edge Unlike ye ole days they didn't come with the correct adapter for bugs. I've been re-using the old ones. |
Posted: Wed Dec 01, 2021 1:52 pm Post subject: Re: Wiper blades for 7mm J-hook arms |
I called Bosch Automotive CS. Great service and nice folks! The bad news is that Bosch no longer makes blades that will fit factory 7mm J hooks. The AutohausAZ application guide is incorrect, as are a few others. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Wed Dec 01, 2021 2:04 pm Post subject: Re: Need wiper blade adapters for 7mm J hook arms |
what size blades to you need?
I just installed Trico 11" on my 70 bug and they have all the right adopters included.
I have extra adapters I've been hording for years. _________________ Rick
tasb wrote: |
sb001 wrote: |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
It's getting darn near impossible for ANY make to get just the rubbers.
I suspect a lawsuit filed by someone who fouled up the installation resulted in a "never again" solution of only selling the whole assembly. Dealers especially. I have been able to find them online, though even that is getting harder. My last Toyota set came from Japan. |
Posted: Wed Dec 01, 2021 2:10 pm Post subject: Re: Need wiper blade adapters for 7mm J hook arms |
60ragtop wrote: |
I have extra adapters I've been hording for years. |
As long as they will go on a 7mm J-hook arm they should work. Check out the pics above. The SB uses 15" blades because of the curved windshield, but the adapter should work for any length blade, right? |
Cusser Samba Member
Posted: Wed Dec 01, 2021 2:35 pm Post subject: Re: Need wiper blade adapters for 7mm J hook arms |
1. Re-purchasing wiper blade assemblies each time seems like a terrible waste, ecologically speaking.
2. My 1971 Convertible ("flat" windshield Super) takes 10" wiper blades. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Dec 01, 2021 2:55 pm Post subject: Re: Need wiper blade adapters for 7mm J hook arms |
Cusser wrote: |
2. My 1971 Convertible ("flat" windshield Super) takes 10" wiper blades. |
I agree 100%. Unfortunately the old ones were all bent up. The "adapters" were permanently riveted to the blades, so I have to replace those too. They may have been factory.
It looks like all the flat window bugs take 10". These are 15" because of the curved windshield. |
Cusser Samba Member
Posted: Wed Dec 01, 2021 3:30 pm Post subject: Re: Need wiper blade adapters for 7mm J hook arms |
Maltboy! wrote: |
Cusser wrote: |
I believe that the 1968-1977 standard flat windshield sedans take 11 inch wiper blades. I don't know about pre-1968. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Starbucket Samba Member
Posted: Wed Dec 01, 2021 4:27 pm Post subject: Re: Need wiper blade adapters for 7mm J hook arms |
Pelican parts has SWF-Valeo wiper blade inserts 22" $7.75 just cut to size. |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 635 Location: Louisiana
Posted: Wed Dec 01, 2021 5:31 pm Post subject: Re: Need wiper blade adapters for 7mm J hook arms |
If you can find a shorter blade that fits, you may try those.
There are some who run blades shorter than 14" on the CURVED Supers. _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
Posted: Wed Dec 01, 2021 5:40 pm Post subject: Re: Need wiper blade adapters for 7mm J hook arms |
^^^^^^^^^^^^ _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG
vwoldbug Samba Member
Posted: Wed Dec 01, 2021 7:16 pm Post subject: Re: Need wiper blade adapters for 7mm J hook arms |
Maltboy , what year is your car and can you get a picture of what you have . |
Posted: Thu Dec 02, 2021 9:55 am Post subject: Re: Need wiper blade adapters for 7mm J hook arms |
Thanks for all the advice everyone. 60ragtop generously offered to send a couple of adapters that should work. |
Posted: Thu Dec 02, 2021 10:00 am Post subject: Re: Need wiper blade adapters for 7mm J hook arms |
vwoldbug wrote: |
76 SB vert. Do you mean pictures of the old blades? Unfortunately, they're long gone. The j-hook is posted above. |
Tvättbjörn Samba Member
Posted: Sun Dec 05, 2021 10:29 pm Post subject: Re: Wiper blade adapters for 7mm J hook found - thanks 60ragtop! |
Oreilly auto parts has inserts for the old blades. I did buy longer inserts and cut them short after installing them into the old blade frames. Sure it does not help if you ave no old blade. |
