Envious Samba Member
Joined: January 08, 2003 Posts: 1821 Location: Toronto, Ontario, Canada
Posted: Mon Nov 22, 2021 8:28 pm Post subject: 53 Zwitter dual circuit MC upgrade |
Can anybody recommend a dual circuit master cylinder for a 53 running drums on all 4 corners? _________________ 71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225 |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Nov 23, 2021 2:02 pm Post subject: Re: 53 Zwitter dual circuit MC upgrade |
I can't - always ran the single on my 11/52 - Z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Tue Nov 23, 2021 2:33 pm Post subject: Re: 53 Zwitter dual circuit MC upgrade |
ZENVWDRIVER wrote: |
I can't - always ran the single on my 11/52 - Z |
What prevented you from running a dual circuit MC? _________________ 71 Type 1302 Custom
64 Type 151
64 Porsche 356c
52 BSA C11G
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
Posted: Wed Dec 01, 2021 3:19 am Post subject: Re: 53 Zwitter dual circuit MC upgrade |
Mine is quad circuit...
A cable for each drum! _________________ Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build. |
Posted: Wed Dec 01, 2021 10:16 am Post subject: Re: 53 Zwitter dual circuit MC upgrade |
Envious wrote: |
What prevented you from running a dual circuit MC? |
dual circuit is more expensive, a stock-single just bolts right in and I guess i'm not paranoid about brake failure - a good German single circuit lasted over 20 years and when it began leaking, I replaced it - z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
cory464 Samba Member
Joined: November 25, 2010 Posts: 659 Location: kokomo in
Posted: Thu Dec 02, 2021 5:52 am Post subject: Re: 53 Zwitter dual circuit MC upgrade |
does a later dual circuit master not bolt in? i assumed it would. it is worth it to go dual circuit. brake lines will fail, especially on cars not driven frequently. its cheap insurance. |
splitjunkie Samba Member
Posted: Thu Dec 02, 2021 9:31 am Post subject: Re: 53 Zwitter dual circuit MC upgrade |
You just need a '67 -'77 beetle MC.
https://www.wolfsburgwest.com/wolfsburg_new/brakes/bug_brake/master_cylinder.cfm
It will bolt in. The biggest challenge is the fluid reservoir. Most people use a dual reservoir but this requires you to pull the drivers side wheel to add fluid because the cap is directly on the reservoir.
It is absolutely worth it. If a single fails, you lose all of your brakes. With a double you will have either your fronts or rears depending on what failed. Sometimes a MC will fail catastrophically, sometimes it is a gradual failure. It's a roll of the dice. _________________ Chris
Posted: Thu Dec 02, 2021 10:20 am Post subject: Re: 53 Zwitter dual circuit MC upgrade |
splitjunkie wrote: |
A Volvo 240 reservoir will mount on a '67 and later brazilian VW dual circuit master cylinder. A Rabbit version is required for a german ATE VW master cylinder.
[/img] |
It is absolutely worth it. If a single fails, you lose all of your brakes. With a double you will have either your fronts or rears depending on what failed. Sometimes a MC will fail catastrophically, sometimes it is a gradual failure. It's a roll of the dice. |
"absolutely"? - a single can catastrophically fail (which rarely happens) - guess this just doesn't concern me - if it concerns you - fine - put a double in...
of coarse it will "bolt right in" - that's not what I meant - my poor choice of words - Meant, it will bolt right in, ready to connect, bleed and use, without challenges - most of all, i'm not paranoid, in the possible event brake failure, with use of a single circuit MC -
Also, kind of humorous that you guys balk at others installing non-original parts, like bigger and brighter tail lights - yet a 1967 to '77 MC is okay - Go ahead, use the later MC and I hope you feel safer … COOL- z
… _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Notch_Norway Samba Member
Posted: Thu Dec 02, 2021 12:37 pm Post subject: Re: 53 Zwitter dual circuit MC upgrade |
Im also going dual, but im also switching to 58-64 drums as its wider and therefore gives alot more braking power.
You can buy a mastercylinder with a reservoir on it and use the original one as a dummy. Looks original that way.
Also its alot cheaper to replace a part with the 58-64 drums. |
consvws Samba Member
Joined: April 07, 2009 Posts: 950 Location: Roseburg, OR
Posted: Fri Dec 03, 2021 6:05 am Post subject: Re: 53 Zwitter dual circuit MC upgrade |
If you use a single circuit MC just make sure you get a good quality German one. I've had 2 brand new Trw units that were bad right outta the box, both purchased from WW |
