'59 Karmann Ghia fever
Page: Previous  1, 2, 3 ... 280, 281, 282 ... 356, 357, 358  Next
Braukuche
Braukuche is offline
PostPosted: Tue Nov 30, 2021 8:37 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Start with the easy, open the trunk and remove the two thick red and red/black wires and hot wire it. If the starter works fine the issue is in your ignition switch. If it doesn’t, then If you climb underneath and arc a screw driver across the terminal that the battery cable is bolted to to the solenoid terminal where you starter wire attaches and the starter works fine, your issue is elsewhere.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
Trylon
Trylon is offline
PostPosted: Tue Nov 30, 2021 10:41 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Thanks Brau.
I have yet to acclimate to the wet/cold— the barn is less than appealing at the moment. Will get going soon.
I did go out to ease my mind that the engine turned smoothly and easily with a wrench.
It does and I can feel the compression as well.
Stay tuned…
1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel!
rich caramadre
rich caramadre is offline
PostPosted: Tue Nov 30, 2021 11:11 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Hi Trylon. This is just a shot in the dark. But you set your timing a while back and the car was running great. Any chance that the distributer clamp was not tightened enough and it has turned?
Trylon
Trylon is offline
PostPosted: Tue Nov 30, 2021 11:12 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Will check!
Thanks Rich!
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon
Trylon is offline
PostPosted: Wed Dec 01, 2021 10:05 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
So THAT’S how you hot wire start a car!
Cobbled this together to jump across terminals on starter switch:
Can a life of crime be far behind?
Unfortunately, still same molasses slow starter. So now me thinks we jack ‘er up and check out the starter/solenoid/bushing. Will first jump across terminals as detailed in Muir and see what info we get.
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Wed Dec 01, 2021 12:05 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Do you have a self-supporting/Autostick starter?
If not, it is likely that the starter armature is dragging on the field coil.
Trylon
Trylon is offline
PostPosted: Wed Dec 01, 2021 12:13 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
That might account for the grinding sound.
Here’s what we have:
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon
Trylon is offline
PostPosted: Thu Dec 02, 2021 12:31 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
So seems that it is the starter, right?
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon
Trylon is offline
PostPosted: Thu Dec 02, 2021 3:42 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
So is this what we need?
https://www.thesamba.com/vw/classifieds/detail.php?id=2419869
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Loren
Loren is offline
PostPosted: Thu Dec 02, 2021 4:47 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Looks like you have a 6v starter in the car? You will likely need to replace the starter bushing too since the 12v starter has a different diameter shaft than a 6v starter. Might not be a bad idea to replace the bushing anyway. You will likely need this conversion bushing to use a 12v starter on a split case transmission:
https://airheadparts.com/vw-part/bushing-starter-adaptor-12-volt/
Trylon
Trylon is offline
PostPosted: Thu Dec 02, 2021 5:28 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Thanks Loren! So you can tell by looking that it is six volt?
I thought it was probably 12v — don’t 6volt burn out in a twelve volt system? Is that what happened?
Not sure we have a split case— doesn’t full synchromesh mean a later case?
If it is a 6 volt, then aren’t we just a few pieces away from bringing the whole car back to 6 volt? Coil, generator + VR, light bulbs, battery, anything else?
As you know, I would love it stock!
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
PeteSC
PeteSC is offline
PostPosted: Fri Dec 03, 2021 6:09 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
May want to pump the brakes on snapping up another starter. You have a 36hp engine with a 180mm flywheel. Most 12v starters have the drive gear for a 200mm flywheel.
You'll likely need something like this, if it is your starter that is bad.
https://www.thesamba.com/vw/classifieds/detail.php?id=551031
Trylon
Trylon is offline
PostPosted: Fri Dec 03, 2021 6:54 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Thanks Pete! Back to noob-land for me.
Here’s a pic of the flywheel:
I thought sometimes they are replaced and the bell housing is modified.
Can we tell the size of the flywheel from the pic?
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
PeteSC
PeteSC is offline
PostPosted: Fri Dec 03, 2021 7:26 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Bell housings are opened up for 12v flywheels, true, but that's usually for the install of a later engine. I don't believe you can just bolt a 12v flywheel to a stock 36hp crank; different dowel pin sizes, etc. Also I'm guessing Loren is looking at your current starter and seeing the screw terminal solenoid, which is pointing to it still being a 6v unit.
Neither are my areas of expertise, so I'll defer to another member. But given the work done by the PO I'd be pretty confident that you've just been running 12v through an original, unmodified 6v starter.
Trylon
Trylon is offline
PostPosted: Fri Dec 03, 2021 7:48 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Wow! The PO Strikes Again!
Yep, I saw the screw terminal and decided that what was pushing the 6v theory.
Well, the only thing that was holding me back from bringing our car back to 6 volt was the flywheel. If that’s all set for 6v, let the games begin!
That 12v conversion of the generator seems to be on terminal hold so now we can just end it and get a refurbished 6v generator and VR. The wiring harness is set for 6v and I think my installation and grounding might let the drop in pressure still run the car. So like I said— starter, coil, battery, bulbs. Anything else?
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Samba Curmudgeon
iowegian is offline
PostPosted: Fri Dec 03, 2021 8:57 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Windshield wiper motor------or just roll with Rain-Ex.
Trylon
Trylon is offline
PostPosted: Fri Dec 03, 2021 9:04 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Oh yeah!
I recall changing the motor for 12v. I still have the 6v part so I can simply change it back!
Thanks IO!
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Braukuche
PostPosted: Fri Dec 03, 2021 9:05 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
That’s a super early screw terminal starter. If you are going to go back to 6V then have that one rebuilt. It’s correct for your year and not easy to find, most have push on connectors for the solenoid wire.
Unless the ring gear was changed out it’s a six V flywheel. That makes it easy to convert back. You can sell that Porsche 912 generator and pay for the conversion and have money to spare.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon
Trylon is offline
PostPosted: Fri Dec 03, 2021 9:20 am    Post subject: Re: '59 Karmann Ghia fever Reply with quote
Yes! This sounds like a plan!
So cool to turn a dead starter into a positive experience!
Now, still have to get the starter out. Rusty stud that I am pretty sure we will be sorry if it comes off. Blastered it last night. Getting a better wrench and trying again today. Wish us luck.
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon
Trylon is offline
PostPosted: Fri Dec 03, 2021 1:04 pm    Post subject: Re: '59 Karmann Ghia fever Reply with quote
It’s out!
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Page 281 of 358
