cdm Samba Member
Posted: Fri Dec 03, 2021 5:27 am Post subject: 73 Super Beetle Clunk from Hell |
The clunking from the rear started suddenly a couple weeks ago. Cutting to the chase; I replaced all rear wheel bearings and installed new CV's both sides. Had to do this anyway as they had never been serviced. The clunking persists.
Put the car level on jack stands and found the following; No clunk in reverse. just perceptible clunk in 1st, worse in 2nd, markedly worse in 3rd and horrible in 4th. Sound appears to be coming from passenger side. When that wheel rotation is stopped while in gear the clunk disappears. If I stop the driver side wheel rotation the cluck persists.
Another observation, I notice the engine mount on the passenger side is shot and the engine is listing that way about a half inch. A possible source of noise?
Thought I would query the knowledge base here before ripping out the tranny. Any ideas appreciated. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31268 Location: Hot Arizona
Posted: Fri Dec 03, 2021 8:25 am Post subject: Re: 73 Super Beetle Clunk from Hell |
cdm wrote: |
Only the engine needs to be removed to replace the rear transmission mounts. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
vamram Samba Member
Posted: Fri Dec 03, 2021 9:15 am Post subject: Re: 73 Super Beetle Clunk from Hell |
The bad transmission mounts will end up causing other damage unless you fix them. That torque travels somewhere when the motor is able to twist like that. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
Posted: Fri Dec 03, 2021 9:26 am Post subject: Re: 73 Super Beetle Clunk from Hell |
Check the front tranny mount, too, while the engine is out.
It can be replaced, with some trouble, with the tranny still installed. |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2233 Location: Medford, OR
Posted: Fri Dec 03, 2021 1:16 pm Post subject: Re: 73 Super Beetle Clunk from Hell |
I had an irritating clunk, and, after replacing both cv axels,it turned out to be the shock sliding in the lower shock mount. Added spacer/bushings and no more clunk.
And yeah, check that others stuff too. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
