djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Sat Dec 04, 2021 6:29 am Post subject: Re: brass exhaust nuts |
SyncroHead wrote: |
djkeev wrote: |
FYI ...... Stainless and Ferrous don't play well together.
Especially in high heat situations.
So many people think stainless is God's answer to a seized nuts....... it isn't and stainless can create more problems than it solves....... but it sure feels good to use them!
Stainless is weak and galls easily.
Dave |
I suppose I'm lucky or probably has to do with the mild southern California weather, but my experience with stainless has always been good. Started using in about 2003 for exhaust hardware (nuts, bolts, washers) and have never had an issue unfastening them. My engine got all studs removed and bolts used for exhaust in 2012 and took them off in 2020 easily. Also, there are many types of stainless, so I may have the lucky variety, but I don't know what it is.
Jim Davis |
Well........ when you don't have any corrosion with exposed ferrous steel....... you certainly won't have corrosion with stainless, no matter what grade it is.
Do watch out for stainless galling and locking up though! You don't need corrosion for this fun!
Ghia
Vanagon
Beetle
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4799 Location: Bemidji, MN
Posted: Wed Dec 08, 2021 7:22 am Post subject: Re: brass exhaust nuts |
DanHoug wrote: |
jlrftype7 wrote: |
The exhaust nut order arrived- they are only copper plated steel, the usual. FYI Dan, and anyone else wondering about those from FCP |
so.... after you ordered i found "18301737774 CRP COPPER NUT,10MM" 100 count for $4.83 with free delivery on Amazon. WTF??! so i HAD to order them. exact same CRP part number. enroute but not delivered. i won't return these regardless of authenticity or solid copper as i can always use 10mm nuts. but i would be tempted to return your order if indeed mine comes as the advertised product, of which i'm always dubious with Amazon.
my Amazon nut arrived.... yes, singular! once again, what was advertised on Amazon, a 100 pack of nuts weighing 2.23lbs, was not what was delivered..... one friggin' nut.
i've opened a case but am not hopeful because Amazon is running everything thru the seller. only $5 loss, not a big deal but am pushing them on the principle.
aaaand the nut is magnetic, too. _________________ -dan
www.thefixitworkshop.com |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Wed Dec 08, 2021 8:18 am Post subject: Re: brass exhaust nuts |
I too would push Amazon, but then I don't buy through them.
Buy local, bring a magnet. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Wed Dec 08, 2021 8:20 am Post subject: Re: brass exhaust nuts |
DanHoug wrote: |
in the broadcast world where time is money and crap happens 1500 feet up in the air, hot dipped galvanized hardware is the standard, stainless is not. out in the elements 24/7 plus high voltage lightning strikes and 100kW of RF flowing thru everything, it's a nasty environment.
In the U.S. Navy test hot dipped galvanized metal stood up better then any of alloy to the salt water environment. When the testing was all done and math calculated it was expected the galvanized hardware would last at least 99 yrs. _________________ This free advice is worth exactly what you paid for it.
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Wed Dec 08, 2021 8:48 am Post subject: Re: brass exhaust nuts |
DanHoug wrote: |
i've opened a case but am not hopeful because Amazon is running everything thru the seller. |
Keep on top of it. Amazon will step in if Seller doesn't solve - they just want the Seller to deal with stuff first.
I've had a 12v compressor fridge I wanted to return, Amazon contact said contact seller, did that, seller didn't reply, Amazon refunded and said to keep fridge. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
11BC2 Samba Member
Joined: August 27, 2017 Posts: 495 Location: Cool, California
Posted: Wed Dec 08, 2021 9:11 am Post subject: Re: brass exhaust nuts |
Steve M. wrote: |
DanHoug wrote: |
In the U.S. Navy test hot dipped galvanized metal stood up better then any of alloy to the salt water environment. When the testing was all done and math calculated it was expected the galvanized hardware would last at least 99 yrs. |
One thing missing is the effect that elevated temperature has on accelerating corrosion; higher temps add energy to a chemical reaction of corrosion. |
11BC2 Samba Member
Posted: Wed Dec 08, 2021 9:16 am Post subject: Re: brass exhaust nuts |
the joker wrote: |
link us in for the best source to purchase some , want to go stainless ex this year, want to add those. |
https://www.belmetric.com/ is my go to place for various fasteners. |
Posted: Wed Dec 08, 2021 9:57 am Post subject: Re: brass exhaust nuts |
vanis13 wrote: |
seller will refund my $5.18... hopefully i get to keep the nut! said they were "out of the product" and cannot fullfil my order. i can live with that, allowing them a graceful if not truthful way out. _________________ -dan
jlrftype7 Samba Member
Posted: Wed Dec 08, 2021 5:31 pm Post subject: Re: brass exhaust nuts |
DanHoug wrote: |
vanis13 wrote: |
seller will refund my $5.18... hopefully i get to keep the nut! said they were "out of the product" and cannot fullfil my order. i can live with that, allowing them a graceful if not truthful way out. |
Good Lord, ONE NUT….
Better than an empty box, I guess… _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Mon Dec 13, 2021 9:46 am Post subject: Re: brass exhaust nuts |
I don't remember where I purchased these copper-coated STEEL nuts, but the package may be familiar to someone:
_________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Mon Dec 13, 2021 9:53 am Post subject: Re: brass exhaust nuts |
DanHoug wrote: |
vanis13 wrote: |
Check McMaster-Carr
https://www.mcmaster.com/nuts/metric-brass-hex-nuts/
Not sure if they have acorn nuts. _________________ This free advice is worth exactly what you paid for it.
Crankey Samba Member
Posted: Mon Dec 13, 2021 10:00 am Post subject: Re: brass exhaust nuts |
Hope the brass cap nuts work out. Seems like a good idea. |
Posted: Mon Dec 13, 2021 10:06 am Post subject: Re: brass exhaust nuts |
gears wrote: |
They look like the same nuts available through Van Cafe. _________________ This free advice is worth exactly what you paid for it.
1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
Posted: Mon Dec 13, 2021 12:50 pm Post subject: Re: brass exhaust nuts |
Any local Autohaus will have these in stock in their "go-to" blue Winsor boxes.
BK _________________ 1991 tin top GL
Some BMWs. |
tjet Samba Member
Posted: Tue Dec 14, 2021 7:36 am Post subject: Re: brass exhaust nuts |
I installed ARP s/s studs & BMW copper nuts. Note, the ARP studs are very expensive, but I had a bad experience with rusted out exhaust hardware on my the original syncro engine. My only option was to replace the engine (or cut the exhaust and remove the heads to drill out all the studs & bolts). It needed a fresh engine anyway, and I never want to have an issue with the harware again.
Chinaclipper Samba Member
Joined: October 03, 2019 Posts: 637 Location: Somewhere in the great Midwest
Posted: Fri Apr 21, 2023 11:16 am Post subject: Re: brass exhaust nuts |
Steve M. wrote: |
gears wrote: |
They look like the same nuts available through Van Cafe. |
I got mine at Amazon---
12 for $10
_________________ China Clippers Official 1971 Super Beetle Project!
https://www.thesamba.com/vw/forum/viewtopic.php?t=728089&highlight= |
Van den Broke Samba Member
Joined: May 20, 2012 Posts: 158 Location: Victoria, Canada
Posted: Sat Apr 22, 2023 8:05 pm Post subject: Re: brass exhaust nuts |
[/quote]
In the U.S. Navy test hot dipped galvanized metal stood up better then any of alloy to the salt water environment. When the testing was all done and math calculated it was expected the galvanized hardware would last at least 99 yrs.[/quote]
Weird, it sure doesn't hold up that well in the Canadian Navy (where I work).
My 1969 Corolla used stainless studs and brass nuts. Some '60s US cars also used brass nuts, but plain steel studs. So brass nuts certainly are proven.
Copper plated steel fasteners would appear to be pretty useless in outdoor use, since the copper is a less reactive metal than iron. That means the iron in the steel will preferentially corrode to protect the copper. |
logans5vw Samba Member
Posted: Sun Apr 23, 2023 9:53 am Post subject: Re: brass acorn exhaust nuts |
I'm about to install new heads and an exhaust sys (non SS) but don't know yet if new studs will be used. So reading the great posts it looks like the acorn brass nuts would be the best fasteners for this? or will the copper nuts be sufficient? I don't use my westy in the winter. |
Posted: Sun Apr 23, 2023 10:32 am Post subject: Re: brass acorn exhaust nuts |
the copper coated nuts are crap, i would buy hardware store stainless nuts and use them with lots of anti-sieze before i'd use copper coated again. they are just flash coated steel nuts with a rilly rilly thin layer of copper for color more than corrosion resistance.
but which ever you use, after the final torque down onto the header, add more nuts to cover the exposed threads of the stud. _________________ -dan
