Newmanthetiedyebus Samba Member
Joined: October 07, 2021 Posts: 7 Location: Ft Wayne Indiana
Posted: Sat Dec 04, 2021 3:38 pm Post subject: 1971 1700 bay window. What is line under bottom right air duct? |
I will try to add pic. Having trouble. It looks like a vacuum line that goes into the bottom right air duct. I don’t see anywhere to attach it. Any help would be appreciated. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Dec 04, 2021 3:49 pm Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? |
There's a few air ducts located on the RH side of a bus, maybe a little more description?, or better yet here's how to post pictures: https://www.thesamba.com/vw/forum/viewtopic.php?t=6
Did you ever solve your coil problem?, it's polite to post a resolution (or update) to the problem in the thread it was discussed in. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Sun Dec 05, 2021 12:19 am Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? |
here is a photo of a typical 1971. From the gallery.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Sun Dec 05, 2021 5:20 am Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? |
Could be a nonstock vacuum operated hot air door. I’m guessing it’s not a vacuum line. _________________ .ssS! |
Posted: Sun Dec 05, 2021 10:03 am Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? |
Newmanthetiedyebus wrote: |
1971 1700 bay window |
72 model built in late 71?, could be the fuel pump drain hose. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Sun Dec 05, 2021 11:13 am Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? |
Part of the tank vent/evap system? |
Posted: Mon Dec 06, 2021 8:53 am Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? |
I uploaded a pic. Its a line of some sort that goes into the tin under the valve cover on the passenger side. The manual calls it the bottom right air duct. That might be causing some confusion. It has a finished hole in the forward part of the tin where the line fits nicely. It was in there when I took the tin off. But I don’t think it connects to anything. At least I couldn’t find anything to connect it to??
Posted: Mon Dec 06, 2021 8:55 am Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? |
Fuel pump drain/vent, it just sticks into the hole in the sled tin. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Dec 08, 2021 9:06 am Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? |
Thanks everyone for the comments. Nothing is leaking out of it and performance isn’t affected at all so going to go with vent/drain. And busdaddy yes I fixed the coil issue. Sorry I didn’t give an update. I replaced the coil, points, and condenser and he runs great. Still haven’t got
lights converted to led. It’s a long term project I will continue to play around with. |
Posted: Wed Dec 08, 2021 9:12 am Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? |
Man, am I senile. I would have sworn my last carbed By ,a 1972, had the fuel pump in the left side near Number 3 _________________ .ssS! |
P24p1 Samba Member
Joined: August 20, 2020 Posts: 363 Location: Canada, Quebec
Posted: Thu Dec 09, 2021 8:13 am Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? |
Oh my a thermostat! Quick someone take a picture and record it, those things are going extinct! _________________ 1973 Westfalia named Angie
What rust?
Rev it - don't lug it! |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
P24p1 Samba Member
Posted: Thu Dec 09, 2021 12:21 pm Post subject: Re: 1971 1700 bay window. What is line under bottom right air duct? |
vwwestyman wrote: |
P24p1 wrote: |
Oh my a thermostat! Quick someone take a picture and record it, those things are going extinct! |
...I mean, the picture is right there... |
That's a very good point _________________ 1973 Westfalia named Angie
What rust?
