Stupid wiring question
Hank22
Hank22 is offline
PostPosted: Sat Dec 04, 2021 5:29 pm    Post subject: Stupid wiring question Reply with quote
Ignition to coil + pos. and distributor to coil - negative. is that correct?
I gotta take better notes.
Thanks in advance
Danwvw
Danwvw is offline
PostPosted: Sat Dec 04, 2021 5:36 pm    Post subject: Re: Stupid wiring question Reply with quote
correct! Some coils have a 15 on them for the positive. The coil wire is labeled 15 in the schematics too. It's switched at the ignition and was not fused anywhere. It was also used to run the Automatic Choke on carbs that have them and idle fuel shut off solenoid carbs with them. It was also used for backup lights etc.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Hank22
Hank22 is offline
PostPosted: Sat Dec 04, 2021 5:55 pm    Post subject: Re: Stupid wiring question Reply with quote
Thanks for the quick response!
Hank22
Hank22 is offline
PostPosted: Sun Dec 05, 2021 11:07 am    Post subject: Re: Stupid wiring question Reply with quote
So I am correct in assuming the wire to the distrbutor get connected to The neg on the coil ? Sorry for my ignorance.
Thing #6
Thing #6 is offline
PostPosted: Sun Dec 05, 2021 12:32 pm    Post subject: Re: Stupid wiring question Reply with quote
NEGATIVE ground, YES. Positive ground is the opposite.
REMEMBER:
1, The HOT wire comes from the battery, through the ignition switch.
2, The COLD wire comes from GROUND, through the distributor, distributor plate, points frame and points contact.
3, Some coils have no markings.
4, Coil OUTPUT is always HOT.
Hank22
Hank22 is offline
PostPosted: Sun Dec 05, 2021 5:14 pm    Post subject: Re: Stupid wiring question Reply with quote
Thanks, crystal clear!
