How do you brew your coffee in the camper? |
Coffee Press |
51% |
[ 139 ] |
Instant ground |
11% |
[ 31 ] |
Stovetop espresso maker |
16% |
[ 44 ] |
Dripper |
17% |
[ 48 ] |
Cold brew |
0% |
[ 1 ] |
Drive-thru, if available |
2% |
[ 8 ] |
Total Votes : 271 |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Sun Dec 05, 2021 10:13 am Post subject: Re: How do you brew coffee in the camper? |
DuncanS wrote: |
Exactly, an insulated beer stein. |
Exactly, except for:
Much smaller
The lid has to flip WAY back out of your face. Because you sip at it with the cup 'almost level'. Nobody quaffs 190° liquids.
A locking feature that seals the lid.....bueno!
But that's not "brewing".
Has anyone tried this Soul Hand USB Burr grinder/brewer? _________________
....KTMs, GasGas, SPOT mtb |
R David Bishop Samba Member
Joined: January 21, 2018 Posts: 1 Location: Cerro Tome NM
Posted: Mon Dec 06, 2021 11:48 am Post subject: Re: How do you brew coffee in the camper? |
Conical funnel into a thermos |
DuncanS Samba Member
Posted: Thu Dec 16, 2021 5:00 pm Post subject: Re: How do you brew coffee in the camper? |
Sodo wrote: |
DuncanS wrote: |
Very nice work. I just love ingenious solutions to problems which don't really exist......well, for most people, that is. For us crazed nut jobs |
Like the problem of driving a 30-year-old vehicle 1,000 miles home....
only the few, the proud, the (whatever) understand.
Along those lines, does anyone know of an insulated coffee cup that has a thumb-operated lid?
If I'm gonna grind beans just before brewing....the next '....need' is to smell the coffee from the exposed liquid surface.
Sucking on my sippy cup just doesn't satisfy (in comparison).
The other details...
I like to walk around the camp with my coffee mug.
I always find 'something' to do with my other hand and thus need the lid to seal (somewhat).
Often it takes a little time of course, so insulation is good.
And because I'll always end up carrying something in the other hand, I want to operate the lid with my thumb.
Kind of like a beer-stein. Which are ok for "quaffing" but not for my coffee (or tea) camping/strolling ritual. I'd use it at home too, walking around the garden in the morning.
There are thumb-operated sippy cups but haven't found one that retracts the entire lid. |
We went through a bunch o' suggestions following this quote. My Viking mug showed up, but it's too fat for my cup holder and may be 16 oz. At some point I'll fit it with a thumb operated lid anyway just because I have it.
However, the other day I was wandering around Target because my T3 carpenter friend was driving and that's where he wanted to go. While waiting for him I came across these.
They are both sippy cups, but if a fella were to Dremel the tops open you would have a close approximation of what both Sodo and I want. Push button spring loaded tops, so hitting the button and you would have a wide open mouth to them. Blue one might have a problem with the lid locking system in that grinding out the top might run into that mechanism requiring a smaller opening than we want. The purple looks better on that score.
Graphics could be fixed. And a handle added if you want a mug.
Duncan |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2559 Location: Philly, mang
Posted: Thu Dec 16, 2021 8:37 pm Post subject: Re: How do you brew coffee in the camper? |
DuncanS wrote: |
this mug obsession... it will take you down a dark road my friend. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Posted: Fri Dec 17, 2021 5:52 am Post subject: Re: How do you brew coffee in the camper? |
No, I take mine with cream, but no sugar please.
Duncan |
Posted: Mon Jan 17, 2022 8:56 am Post subject: Re: How do you brew coffee in the camper? |
i have been using Starbucks micro ground instant coffee for years. it is great when backpacking, just heat water and stir in the packet. i have been doing this while camping in the Westy and while i enjoy the ease of making a cuppa with no clean up, i've grown tired of the selection of coffees.
i have picked up an Aeropress and Porlex mini grinder for use in the Westy. while it adds needed action from me (weighing and grinding the coffee) the ability to bring select coffees is more than worth the added effort.
tldr; i'm tired of limited coffee options and with an Aeropress and burr grinder i will be able to tailor the coffee to the camping trip. _________________ 1991 Vanagon GL Camper
Bonesberg55 Samba Member
Posted: Mon Jan 17, 2022 9:16 am Post subject: Re: How do you brew coffee in the camper? |
Assuming you buy good quality Arabica beans, the best method is boiling water poured over the grounds using a cone-type filter such as Melitta makes. You cannot extract the full flavor of the bean if the water is not hot enough. Also, a coarser grind will keep you from getting the bitter oil taste that comes from grinding it too fine. As a rule, preground coffee is too fine. Buy whole bean and grind it yourself. |
Posted: Mon Jan 17, 2022 11:44 am Post subject: Re: How do you brew coffee in the camper? |
Threw it out. Didn't fit in the oversized cup holder in the car and the "wrought iron" and "wood" are plastic. Fell on the ground and the handle snapped off $30 down the drain.
I love Priorty Zero. Went from 26,273 on the list to Number Zero.
This is a final. I just have to buy another 73/135ths drill to replace the now missing one in the index.
Duncan |
Posted: Mon Jan 17, 2022 12:19 pm Post subject: Re: How do you brew coffee in the camper? |
you have the most unique dash i've seen. _________________ 1991 Vanagon GL Camper
Posted: Mon Jan 17, 2022 12:47 pm Post subject: Re: How do you brew coffee in the camper? |
Hmmmm Unique. Sort of unique? Slightly unique? Most unique? |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
11BC2 Samba Member
Joined: August 27, 2017 Posts: 495 Location: Cool, California
Posted: Tue Oct 10, 2023 3:55 pm Post subject: Re: How do you brew coffee in the camper? |
Being a former Grunt, I prefer Ranger Coffee.
Simply apply a pinch of your favorite coffee grounds between your cheek and gum! |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Tue Oct 10, 2023 6:50 pm Post subject: Re: How do you brew coffee in the camper? |
My Kcup coffee maker. Works well enough for me...
BLACKSMITH FAMILY Portable Travel Coffee Maker Press, Camping Coffee Press, Travel K Cup Coffee Maker - Instantly Makes Delicious Coffee, Compatible with K Cups and Ground Coffee, 4~12 OZ One Shot
https://www.amazon.com/BLACKSMITH-FAMILY-Portable-...5&th=1 |
danielheff Samba Member
Joined: January 22, 2016 Posts: 136 Location: San Diego, CA
Posted: Wed Oct 11, 2023 8:58 pm Post subject: Re: How do you brew coffee in the camper? |
As a self diagnosed coffee snob, but also owner of a van with limited space, I started bringing instant coffee on our camping trips. I used to bring freshly roasted beans, a grinder, scale, v60 cone, a glass server, and a gooseneck kettle on every trip and it did make amazing coffee. This is my daily setup at home as well. But we did a 1 month trip in the van this summer and brought craft instant coffee from Verve and the convenience and quality was very worth it. It tasted nothing like nescafe or other terrible instant coffees but was much more like the quality coffee I'm used to drinking.
Worth a try if you're curious.
https://www.vervecoffee.com/collections/shop?q=instant _________________ '70 Squareback 1835cc
'85 Vanagon GL Camper, EJ22, Peloquin Diff, Burley rear disc brakes, SC big front brakes, Espar D2L, 250ah Lifepo4
'85.5 944 NA |
khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Thu Oct 12, 2023 4:47 pm Post subject: Re: How do you brew coffee in the camper? |
Not to put too fine a point on it, but I prefer skunk butt to *any* kind of coffee. But, that's me _________________ '86 Westy FAS GenV Turbo (Marvin) |
brickster Samba Member
Joined: January 05, 2004 Posts: 512 Location: CO, USA
Posted: Thu Oct 12, 2023 5:34 pm Post subject: Re: How do you brew coffee in the camper? |
khughes wrote: |
Not to put too fine a point on it, but I prefer skunk butt to *any* kind of coffee. But, that's me |
So you would love Kopi Iuwak.
https://en.wikipedia.org/wiki/Kopi_luwak
For the majority of our weekend trips in Busta, we bring pre-brewed and heat up two servings each morning. For longer trips I use the Clever Dripper for tasty coffee and easy cleanups. |
Squarebob Spongepants Samba Member
Joined: October 02, 2023 Posts: 6 Location: California
Posted: Thu Oct 12, 2023 7:11 pm Post subject: Re: How do you brew coffee in the camper? |
JetBoil coffee press. After 40 years of camping and trying every conceivable way to brew coffee this is the absolutely best we’ve found. Compact and boils enough water for two decent size cups in 2 minutes.
Jetboil Flash Java Kit Camping and Backpacking Stove Cooking System with Silicone French Press Coffee Maker https://a.co/d/2lWtyx1 |
Posted: Thu Oct 12, 2023 7:23 pm Post subject: Re: How do you brew coffee in the camper? |
brickster wrote: |
khughes wrote: |
LOL, nope talking skunk, not cat. And I'm talking actual butt, not bean-from-butt! _________________ '86 Westy FAS GenV Turbo (Marvin) |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Oct 13, 2023 7:05 am Post subject: Re: How do you brew coffee in the camper? |
danielheff wrote: |
https://www.vervecoffee.com/collections/shop?q=instant |
Just ordered a bag of the 1950; hope it arrives before our camping trip next weekend!
I'm thinking I'll just make my wife a cup and hand it to her without telling her that it's instant-I think if she knew there'd be preconceived notions.
Though as I'm typing this message, I remember that some of the friends I will be camping with always bring one of those big "church style" coffee makers to share large batches of coffee! Ha ha, that's ok, I'll still give this a try. _________________ Dave Cook
1973 Wild Westerner
My Thing |
