kingkarmann Samba Member
Posted: Thu Oct 14, 2021 4:14 pm Post subject: Re: Introducing Joan! |
I feel I’ve become good friends with Lisa Meier “theghiagirl”.
As we were exchanging info about Joan, Lisa pointed out a defect.
It seems a piece of the Karmann Ghia script was missing..
I have to chuckle because as I was discussing my home made “speed nuts” for the script Lisa pointed out the damage to the “G”.
I didn’t see it initially and had to compare it to Sophia’s.
Sure enough the Ghia part lost the “swish”.
These emblems are so delicate. It’s common for them break. Got a replacement installed.
In preparation for a potential concours show next June I also installed an upper pulley tin that had gone missing.
Little details make the difference 😎
Replacement
Original
_________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Marcdeb Samba Member
Posted: Sat Oct 16, 2021 5:50 am Post subject: Re: Introducing Joan! |
Marcdeb wrote: |
Curious, why do I see some engine seals laying above the tin like this one, and others where the seal is under the tins? |
Good question. The seal in Sophia is totally different from Joan's. I am not really sure why. I wonder which one would be more "correct" for a 67
Mike Gerson
Braukuche Samba Member
Posted: Sat Oct 16, 2021 9:45 am Post subject: Re: Introducing Joan! |
Seals changed at a certain point, I’m pretty sure 67 took the early flat style but not sure when the change occurred. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
wheel607 Samba Member
Posted: Sat Oct 16, 2021 10:32 pm Post subject: Re: Introducing Joan! |
I believe that is the "only" seal available today. It is also I believe installed properly as it is an over and under seal, meaning it has two surfaces that look identical to go over the top and under the bottom. But boy, has that Ghia emblem sure changed.....the old looks MUCH better. |
Posted: Mon Oct 18, 2021 8:29 am Post subject: Re: Introducing Joan! |
wheel607 wrote: |
Unfortunately the "old" one is damaged. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Posted: Mon Nov 01, 2021 4:15 pm Post subject: Re: Introducing Joan! |
Somewhere someone mentioned I needed to ditch the blue “screamer” coil. Not exactly sure why the blue one is referred to as a screamer.
Anyhow, a black coil with a proper bracket and logo looks more appealing IMO.
Now I have a spare😎
Mike Gerson
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Mon Nov 01, 2021 4:40 pm Post subject: Re: Introducing Joan! |
When you A/B it like that, the blue one looks really inappropriate.
Nice improvement! _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Tue Nov 02, 2021 6:46 am Post subject: Re: Introducing Joan! |
Looks much better with the correct coil/bracket setup IMO. The Blue coils were called Screamers back in the day as you could buy a ignition setup with an 009, cool? Blue sparkplug wires and the ...Blue Screamer coil. It was required equipment in the 90s, most of the Screaming was the owner complaining that it actually ran better before the change. |
Posted: Tue Nov 02, 2021 6:53 am Post subject: Re: Introducing Joan! |
Big Bill wrote: |
I have an affinity for blue as Sophia is painted a shade of the color.
It's interesting you mentioned blue wires.
In 2006 I thought Sophia had the coolest engine bay
Mike Gerson
Posted: Wed Nov 17, 2021 3:51 pm Post subject: Re: Introducing Joan! |
Joan is going to experience winter again after many years living large on the west coast.
Going to slam her and install Earlies over the holiday!!
Not😜
Planning on doing some maintenance items.
Replace the Solex 34 PICT3 with the correct Solex PICT1
The seals for the front inner fender splash plates were never installed an earllier restoration. I have a set ready to go.
Transmission fluid change.
Full detail inside, outside and underside.
She will get the full spa treatment just like Sophia.
Not a lot to do as she is in terrific condition for getting ready to turn 55!
Mike Gerson
Trylon Samba Member
Posted: Wed Nov 17, 2021 4:00 pm Post subject: Re: Introducing Joan! |
A well-deserved rest. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Sun Dec 05, 2021 4:57 pm Post subject: Re: Introducing Joan! |
I’ve been spending some time learning all about “stock”.
What I’ve learned is that although Joan is nearly perfect there are just a few details I want to address over the winter.
I have a small oil leak. I believe it originates at the distributor. I pulled it finding a rock hard seal. While the distributor is out I’m planning to refresh it providing I can locate a rebuild kit that doesn’t cost both arms & legs.
A Solex 30 PICT-3 was installed in place of what should have been a Solex 30 PICT-1
Armed with this knowledge I started to search for the PICT-1.
I found a nice core to ship to Tim at Volksbitz. Seems he’s the Solex savant.
I wish I had talked to him before buying the core. Seems that there are different versions of the PICT-1 and the core I bought was wrong. I’m sending The wrong core and Joan’s PICT-3 for credit on a rebuilt unit from Tim.
The crank pulley didn’t look right to me but after some further investigation it’s the correct one for this motor.
I’m a bit into the rabbit hole now but it will give me something to tinker with over the winter.
I need to stay busy!
Mike Gerson
Posted: Sun Dec 05, 2021 6:49 pm Post subject: Re: Introducing Joan! |
Just noticed the original VW stamped fuel pump, nice!
30 PICT 1 is considered THE best stock carb. Simple and bullet proof. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Tue Dec 07, 2021 10:16 am Post subject: Re: Introducing Joan! |
Braukuche wrote: |
30 PICT 1 is considered THE best stock carb. Simple and bullet proof. |
Thanks for that.
I am really hoping to refurbish the original distributor over the winter
It's the 113.905.205k
I have the correct replacement points & condenser.
My hang up is the Bosch rebuild kit
I believe the kit # is 1237010007
Must be rare or NLA as the couple I have found on the classifieds are north of $100.
I have already reached out to Glenn. No luck.
Any suggestions or leads would be appreciated _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3914 Location: In Molinya Orbit
Posted: Tue Dec 07, 2021 5:35 pm Post subject: Re: Introducing Joan! |
sputnick60 wrote: |
kingkarmann wrote: |
Any suggestions or leads would be appreciated |
Have you tried Vic's Bhan in Australia http://www.vicsbahn.com/aboutus.html
He has a stash of rare parts. I've found he is very helpful
Nicholas |
Thank you for the lead! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Wed Dec 08, 2021 7:23 am Post subject: Re: Introducing Joan! |
I found this really informative thread
https://www.thesamba.com/vw/forum/viewtopic.php?t=606129&highlight=distributor+rebuild
After reading and studying the pics I felt confident I could disassemble the distributor.
My concern was not having washers & shims if mine were worn.
I was pleasantly surprised to find minimal wear. I did find old grease and grime internally.
I cleaned, polished & lubricated everything and reassembled.
No side play, no discernible end play.
New Bosch condenser, nos Bosch points and shaft seal were installed. Trying to keep a bit of patina on the parts.
Vacuum can works and holds vacuum. The advance plate moves much more smoothly. I did notice this distributor does not have a felt plug. Is it missing or does this model not need it?
The Rebuilt Solex should be arriving after the first of the year.
As I understand it Tim’s rebuilds look like jewelry 😎
Mike Gerson
Posted: Tue Dec 14, 2021 3:23 pm Post subject: Re: Introducing Joan! |
Just received my very own lifetime supply of Bosch Distributor Grease.
I understand it’s pricey due to the addition of rendered Unicorn 🙄
Anyhow, I hope Joan appreciates the effort. I’ll share a bit with Sophia so she won’t feel left out.
Mike Gerson
