BIGdaddy1102 Samba Member
Joined: May 20, 2008 Posts: 194 Location: Bellingham WA
Posted: Thu Jun 05, 2008 9:46 pm Post subject: How do I remove the spedometer in a 74? |
title pleease. |
GreaseC Samba Member
Joined: May 26, 2008 Posts: 78 Location: Washington St.
realbugfanatic Samba Member
Joined: May 03, 2006 Posts: 484 Location: SW Michigan
Posted: Fri Jun 06, 2008 3:36 am Post subject: |
If it's a standard, follow the previous directions per GreaseC's link.
If it's a Super, you push it out the front. It has a ribbed rubber ring around the outside & you have to unhook the speedo cable first. It's been posted on here before, but the Reader's Digest version is:
1) Unhook your battery - terminal. Do this in case you accidentally cross some wires when removing your speedo.
2) Take off the trim panel that runs below the speedo across the top of the steering column. A couple trim pieces pry off of the ends & now just remove the screws.
3) Use this newly found access hole to reach in & unscrew your speedo cable. You CAN do this without step 2, but it's darn near impossible for anyone that has hands larger than a 5 yr old!
4) Through this same hole get your left hand up behind the speedo & push it out towards you while trying to wiggle it & pull on the face with your right hand. Be careful not to unhook any wires or you'll be posting a 'where does this wire go' topic - been there. |
minimeadow Samba Member
Joined: February 06, 2021 Posts: 42 Location: Georgia
Posted: Sun Dec 05, 2021 4:06 pm Post subject: Re: How do I remove the spedometer in a 74? |
Just did this on my '73 Super - I was able to reach the spedometer cable and unscrew it from underneath the dash, so try that as well. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11739 Location: Redding, CA
Posted: Mon Dec 06, 2021 12:04 am Post subject: Re: How do I remove the spedometer in a 74? |
If it’s a 1973-on curved windshield, you simply remove the dash plate, then stick your hand in and unscrew the speedometer cable.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3987 Location: Antioch, California, a block from the hood
