gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Tue Dec 07, 2021 12:51 pm Post subject: GT 113 gears |
After years of only making parts for Syncro Vanagons, we decided to make a few sets of 1st/2nd gears for early 113 transaxles.
These gears feature a tooth profile copied directly from Formula 1 racing gears. This tooth design puts all wear where it belongs .. centered on the tooth flank.
Mainshaft detail
2nd gear Idler
GT 113 Hub
These 113 mainshafts are available (in various ratio combinations) through Rancho and other trans shops utilizing GT VW gears.
For the heck of it, we've also made a few 091/1 and 094 gear sets which also feature F1 tooth profiles:
094 5-spd Set
_________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Tue Dec 07, 2021 1:49 pm Post subject: Re: GT 113 gears |
Insta boner _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Tue Dec 07, 2021 5:38 pm Post subject: Re: GT 113 gears |
Fantastic work! I suppose the material for the shaft and the gears is comparable to that on OEM parts? |
gears Samba Member
Posted: Tue Dec 07, 2021 7:07 pm Post subject: Re: GT 113 gears |
Thanks Rome .. GT gears & shafts are German vacuum-processed steel, with specialized heat-treatment, shot-peened & REM-polished. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
