Mateo83 Samba Member
Joined: September 14, 2021 Posts: 607 Location: Lodi, CA
Posted: Mon Dec 06, 2021 3:46 pm Post subject: Sliding door internal Latch |
83 vanagon. I’ve replaced the handle, delrin bushing but still have play / wiggle in the outside handle. I’m pretty sure it’s the internal latch mechanism the handle bolts through. Any suggestions/ rebuilds/ replacement ideas? _________________ 83 Air-cooled 2.0 Tin Top |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Tue Dec 07, 2021 12:31 pm Post subject: Re: Sliding door internal Latch |
scwright99 wrote: |
83 vanagon. I’ve replaced the handle, delrin bushing but still have play / wiggle in the outside handle. I’m pretty sure it’s the internal latch mechanism the handle bolts through. Any suggestions/ rebuilds/ replacement ideas? |
how much wiggle, they all wiggle to some degree. the tolerance on the square shaft insert into the internal latch might be wallowed from a loose handle. do you have both the inner foam gasket and the exterior door seal?
have you read this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=228788 _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Tue Dec 07, 2021 1:15 pm Post subject: Re: Sliding door internal Latch |
If it is of any comfort, my 84 has had play (axial, not crosswise) for the past 30 years.
The Delrin bush does help it sit horizontal if that is where I leave it.
IMO, annoying but 'mostly harmless'. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Tue Dec 07, 2021 4:08 pm Post subject: Re: Sliding door internal Latch |
scwright99 wrote: |
You sure you guys the correct delrin bushing?
Not much more left to move/wiggle... _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Tue Dec 07, 2021 5:07 pm Post subject: Re: Sliding door internal Latch |
theres a seller on ebay, they fit is good. i'm sure the play is in the mechanisim itself. I can see it. _________________ 83 Air-cooled 2.0 Tin Top |
Posted: Tue Dec 07, 2021 10:09 pm Post subject: Re: Sliding door internal Latch |
scwright99 wrote: |
theres a seller on ebay, they fit is good. i'm sure the play is in the mechanisim itself. I can see it. |
Ok, he does have two versions for early and late doors _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Tue Dec 07, 2021 10:48 pm Post subject: Re: Sliding door internal Latch |
Says my year.
81 82 83 1981 1982 1983 gasket lever
You are buying a black Delrin door handle bushing. It fits Volkswagen Vanagon from 1980 to 1984 with the long handle. No longer available from Volkswagen _________________ 83 Air-cooled 2.0 Tin Top |
Posted: Wed Dec 08, 2021 8:51 am Post subject: Re: Sliding door internal Latch |
that should be that (unless they shipped the wrong one)
do you have video of movement? Maybe its a expectations issue? Us Sambtistas can chime in on a video.
Also, have you checked with Delrin seller. Likely he's had others buy and did not solve to satisfaction and he may be privy to other problems/solutions that may cause your issue. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Wed Dec 08, 2021 10:25 am Post subject: Re: Sliding door internal Latch |
I tied to get a video but it says too large or corrupt. _________________ 83 Air-cooled 2.0 Tin Top |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Wed Dec 08, 2021 11:41 am Post subject: Re: Sliding door internal Latch |
you will need to upload it to youtube and link us back here _________________ Brandon
Instagram @joannthevan |
