Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Sat Jan 15, 2022 1:43 pm Post subject: Steering Wheel nut |
Anyone put loctite on the shaft to keep that steering wheel nut secure?
_________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76947 Location: Sneaking up behind you
Posted: Sat Jan 15, 2022 2:52 pm Post subject: Re: Steering Wheel nut |
It's a tapper fit. _________________ Glenn
Member #1009
#BlueSquare |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat Jan 15, 2022 3:00 pm Post subject: Re: Steering Wheel nut |
Glenn wrote: |
It's a tapper fit. |
It is? News to me!
My latest piles steering wheel nut is loose. I can thread the nut all the way down to the end of the threads.
And, No locktite needed. Just make sure that the wavy washer is not flattened. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Glenn Mr. 010
Posted: Sat Jan 15, 2022 3:02 pm Post subject: Re: Steering Wheel nut |
67rustavenger wrote: |
Glenn wrote: |
It is? News to me! |
Ever take one off? You have to leave the nut on, a few turns, so when you break it loose it doesn't smack you in the face. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jan 15, 2022 3:14 pm Post subject: Re: Steering Wheel nut |
Glenn wrote: |
Glenn wrote: |
Ever take one off? You have to leave the nut on, a few turns, so when you break it loose it doesn't smack you in the face. |
So you're talking about the splined shaft. Not the nut.
The splines are straight too! The wheel gets stuck on the splines. But to my knowledge. They too are not tapered.
Yes I have taken many VW steering wheels off. And no I haven't need emergency dental work afterward. _________________ I have learned over the years.
Buy Once, Cry Once!
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Sat Jan 15, 2022 5:01 pm Post subject: Re: Steering Wheel nut |
Like @67rustavenger, I've also never noticed any taper. If it does exist (which seems logical), then I think it would be in the splines on the steering shaft. They get thicker along the raised longitudinal lines as you go forward, and narrower on the low cut slots that run between, as well as not as deeply cut as you go forward. |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Jan 15, 2022 5:36 pm Post subject: Re: Steering Wheel nut |
Zylinderkopf wrote: |
No, I never have and wouldn't recommend it either. That big wavy washer is a form of fastener locking devise.
Torque the nut to spec and away you go! _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sun Jan 16, 2022 6:55 am Post subject: Re: Steering Wheel nut |
I give a few taps with a pneumatic impact gun and it stays tight. Trying to hold the steering wheel with one hand and operate a ratchet in the other at the same time will not get the nut the right torque _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
