Chris333 Samba Member
Posted: Tue Jun 12, 2018 2:46 pm Post subject: Filling in the gas door (newbie) |
I'm filling in the gas door of my 68', I bought a 67" tank for it.
I'm using matching VW metal for the fill panel.
I've spot welded about every 1/4" all around, jumping around so one area didn't get too hot.
This is from inside the trunk:
My question is: Do I need to end up spot welding the whole line around the patch till it is filled solid?
Thanks! |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Tue Jun 12, 2018 4:31 pm Post subject: Re: Filling in the gas door (newbie) |
Chris333 wrote: |
...My question is: Do I need to end up spot welding the whole line around the patch till it is filled solid?
Thanks! |
The correct answer is yes. You want it to be a seamless sheet of steel once you weld the patch in place and grind and sand the welds flat.
Your best option for grinding the welds flat is to use a cutting disc on your cut-off tool rather than a grinding disk. Use the disc perpendicular to the weld, this will give you a finer finish, generate less heat, and allow you to remove only the weld metal rather than the surrounding metal.
1) Grind the welds with the cut-off disk until they are just proud of the base metal
2) Use a Bandfile or Roloc disks on a die grinder to do the finish work.
Bandfile/mini belt sander
https://www.eastwood.com/eastwood-electric-mini-belt-sander.html
Roloc discs and and tool
https://www.eastwood.com/eastwood-2-surface-prep-tool.html
These are offered as examples. Shop around and read reviews for the option that best fits you.
Cheers,
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Tue Jun 12, 2018 5:02 pm Post subject: Re: Filling in the gas door (newbie) |
If you tack weld that piece in place in maybe 8 places and then start the next tack weld off of the last one it will be continuous. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Thu Jun 21, 2018 8:17 pm Post subject: Re: Filling in the gas door (newbie) |
That’s a big tank. |
jaysurfs Samba Member
Posted: Fri Jan 14, 2022 8:02 pm Post subject: Re: Filling in the gas door (newbie) |
I want to do the same thing on my '68. Did the gas tank fit in just fine? Or was there any differences? Any fasteners adjustments? Thanks 🤙 |
c21darrel Samba Member
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat Jan 15, 2022 1:43 pm Post subject: Re: Filling in the gas door (newbie) |
c21darrel wrote: |
Tank just drops in. You need the early style tank hold downs.
The filler neck vent line. Should be routed, using the nylon clips. Seen on the inner fender well.
Route the vent line using the lower clip then bring it up to the upper clips. Then down to the vent line hole behind the spare tire. As seen in the image above. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Jan 16, 2022 2:45 pm Post subject: Re: Filling in the gas door (newbie) |
c21darrel wrote: |
Tank just drops in. You need the early style tank hold downs. |
Awesome thanks. I found a used newer aftermarket early year tank on craigslist yesterday for $25bucks and swooped it up. 🤙 |
