Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Sun Jan 16, 2022 1:52 pm Post subject: Horn ring assembly |
I took apart the steering wheel from my '66 to fix one of the M3.5 threads that got stripped. Would someone be willing to post a picture or write a description of how the screws, lock washers, springs and fiber washers go on both the front and the back of the wheel? The horn ring and the cancel ring.
Thanks. It's been 10 years since I took it apart. |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sun Jan 16, 2022 6:06 pm Post subject: Re: Horn ring assembly |
A Gallery search using the words 'horn ring' got this...
Hope it helps, _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Sigurd Samba Member
Posted: Mon Jan 17, 2022 4:58 am Post subject: Re: Horn ring assembly |
Yes! Thanks. Where do the lock washers go, under the springs? |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Mon Jan 17, 2022 8:49 am Post subject: Re: Horn ring assembly |
How about this one...:
_________________ Andy T.
Sigurd Samba Member
Posted: Mon Jan 17, 2022 11:11 am Post subject: Re: Horn ring assembly |
glutamodo wrote: |
Picture doesn't show up. |
Michael Ambrozik Samba Member
Joined: October 17, 2020 Posts: 631 Location: San Jose, CA
Posted: Mon Jan 17, 2022 11:29 am Post subject: Re: Horn ring assembly |
No lock washers |
Posted: Mon Jan 17, 2022 11:49 am Post subject: Re: Horn ring assembly |
Sigurd wrote: |
It is hosted on a free open FTP server. It is NOT an https secure site, and if I was going to guess, your browser security settings block it. But this version of that image has been at that URL for just over 10 years now. _________________ Andy T.
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2006 Location: Texas
Posted: Tue Jan 18, 2022 1:22 pm Post subject: Re: Horn ring assembly |
Sigurd wrote: |
glutamodo wrote: |
Click on the little broken picture just to the left of the word "Image" - or at least that works for me... _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
DesertG Samba Member
Posted: Wed Nov 29, 2023 6:21 pm Post subject: Re: Horn ring assembly |
How do you hold all these little screws, washers and springs in place and position it all so you can get a screwdriver on it, before the springs fall off.
_________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
Sigurd Samba Member
Posted: Wed Nov 29, 2023 7:46 pm Post subject: Re: Horn ring assembly |
Very carefully. |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Sigurd Samba Member
Posted: Thu Nov 30, 2023 10:18 am Post subject: Re: Horn ring assembly |
Yep. I had to buy the kit too. Not cheap. Likely to never use it again. |
wdfifteen Samba Member
Posted: Thu Nov 30, 2023 10:37 am Post subject: Re: Horn ring assembly |
DesertG wrote: |
How do you hold all these little screws, washers and springs in place and position it all so you can get a screwdriver on it, before the springs fall off. |
I use a drop of silicon glue/sealer to hold the contact plate to the steering wheel, then glue the plastic washers in place with a tiny drop of super glue. After that, the rest is easy. Be careful not to use so much you can't ever get it all apart. |
