madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Dec 28, 2021 4:03 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Thanks,it now resides in Mt.Home Arkansas swapped it for my white bug _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
vwfye Samba Member
Posted: Sat Jan 01, 2022 7:48 pm Post subject: Re: Can I jump this thing? I'm kidding... |
So, everything on this project is awaiting deliveries. Can't build trans without the pinion and gears. Can't build the shifting without the 2 speed shift system and can't rebuild the front wheels until the last of the bearings arrive. All are in the post, none are here. _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
vwfye Samba Member
Posted: Wed Jan 12, 2022 2:17 pm Post subject: Re: Can I jump this thing? I'm kidding... |
FTC 2 speed stuffs arrived. Still awaiting the r/p combo before we can assemble the transmission. Rear wheels and tires are here, so I hope to get the tires mounted this week... every so slowly... progress! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Jan 13, 2022 9:14 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Training paddles
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Sun Jan 16, 2022 7:14 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Where will you race? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
vwfye Samba Member
Posted: Sun Jan 16, 2022 7:16 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Albany and Riddle might open the track back up. _________________ 64 No'back Speedster "Pearl"
Posted: Sun Jan 16, 2022 7:49 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Wow. Did not realize, know that there were sand tracks east of the Pacific Ocean. Or even AT the Pacific Ocean _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
vwfye Samba Member
Posted: Sun Jan 16, 2022 7:51 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Oregon Offroad Racing Association is in Riddle and trying to revive _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Jan 23, 2022 1:04 am Post subject: Re: Can I jump this thing? I'm kidding... |
New front wheel bearings and wheels installed.
vwfye Samba Member
Posted: Mon Feb 07, 2022 4:41 pm Post subject: Re: Can I jump this thing? I'm kidding... |
More mock up
vwfye Samba Member
Posted: Sat Feb 12, 2022 12:51 pm Post subject: Re: Can I jump this thing? I'm kidding... |
I finally have the engine plate! That's better.
vwfye Samba Member
Posted: Sun Feb 13, 2022 9:06 pm Post subject: Re: Can I jump this thing? I'm kidding... |
I know I should have test fitted me much sooner, but hey...
Also, the difference in footprint of 30psi and 8psi.
vwfye Samba Member
Posted: Sun Feb 20, 2022 10:26 am Post subject: Re: Can I jump this thing? I'm kidding... |
I want to remove the entire drivetrain as a unit, so we nutzerted the bell housing and now the 4 bolts unscrew from the perches, 2 bolts on the engine mounting plates and brake calipers unbolt and the entire rear end can be rolled away for service. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Feb 20, 2022 2:55 pm Post subject: Re: Can I jump this thing? I'm kidding... |
New front rubber and tubes ordered for the the spoked wheels... needs to be closer to OG. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Feb 27, 2022 11:38 pm Post subject: Re: Can I jump this thing? I'm kidding... |
These old wheels were covered is rust spots on the spoke sides and covered in flaking rust on the tire side. Rustoleum Rust Desolver and 30 minutes wait did pretty good!
vwfye Samba Member
Posted: Tue Mar 01, 2022 9:28 pm Post subject: Re:Can I jump this thing? I'm kidding... |
Old school cool. Well, at least to me!!!
The wheels are OG as are the timing rings. _________________ 64 No'back Speedster "Pearl"
Dusty1 Samba Member
Posted: Fri Mar 04, 2022 12:07 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Dale M. wrote: |
Many years ago (sort of pre monster truck era) local group sponsored mud bog runs.... Fellow had a VW rail very similar to one pictured here only difference was small wide tires on front, he wound it up dumped clutch and made it to end of pit in seconds, made the "big" trucks look really bad (as in terrible)....
Secret was he was so light and had enough power he just sort of skipped across top of mud.... |
Which is why they changed the rules. Next season you had to have full time 4WD.
vwfye wrote: |
I remember a vw hydraulically driven 4wd got outlawed for that and indoors it could flat out run, throw a lever and reverse the system to slam on the brakes. |
Which is how the VW and VW style buggies made it into the following season. That instigated more rules changes. To put it simply, if you don't have a monster motor 4WD don't bother takin' it off the trailer at a "sanctioned event".
County fairs have somewhat loose rules. Still, show up with your old school light n' quick VW, you will be the focus of dirty looks from the locals.
The Europeans have more of a sense of humor. They have mud bog motorcycles. |
vwfye Samba Member
Posted: Tue Mar 15, 2022 10:41 am Post subject: Re: Can I jump this thing? I'm kidding... |
The gentleman I bought the frame from has an BBC v8 with NOS sand drag car. He told me that his car will run about 0.3 faster than what this car ran in the 80s. Power to weight... always the issue. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Mar 20, 2022 9:33 pm Post subject: Re: Can I jump this thing? I'm kidding... |
Had to bend some sheet metal from damage somewhere in the past. I wish t3 pans were this easy!
BTW, there is less than 150lbs of drag rail in these photos. The engine/trans/rear tires weigh more than what is picture plus my fat butt! Crazy!!!
vwfye Samba Member
Posted: Mon Mar 21, 2022 8:58 pm Post subject: Re: Can I jump this thing? I'm kidding... |
4 hours of trans set up today. Stopped after setting preload and getting initial r/p lash to work from. Much learning today as well as some progress.
Photos loaded in reverse order.
