skiter8198 Samba Member
Posted: Sun Jan 16, 2022 5:33 pm Post subject: Why does my universal case have one 8mm and one 10mm? |
Why does my universal case have one 8mm and one 10mm hole for the oil cooler? What and how type of oil cooler should I mount on the engine. The engine number is u5078859. Thanks
modok Samba Member
Posted: Sun Jan 16, 2022 6:08 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
Looks normal to me.
Tho I'd think a "universal" case would have a 8mm stud for the oil cooler, is that a 6mm stud? I can't really tell but it looks a bit small. Maybe it is a step stud |
Posted: Sun Jan 16, 2022 7:02 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
Modok, it’s definitely a six MM stud |
KEGZ Samba Member
Joined: October 11, 2021 Posts: 288 Location: Whales Vagina
Posted: Sun Jan 16, 2022 7:06 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
That looks normal. Use the same size seals. |
69aircooled Samba Member
Joined: August 04, 2004 Posts: 241 Location: North Carolina
Posted: Sun Jan 16, 2022 7:26 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
I agree with Modok that it might be a step stud. I had a universal case with what I thought was a 6mm stud and it was a step stud 8mm-6mm.
If it’s a universal case, dual oil relief and you’re wanting an upright Type1 then an offset oil cooler set would be best.
Posted: Sun Jan 16, 2022 7:30 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
Definitely not a step stud, I just pulled a stud out of the case.
modok Samba Member
Posted: Sun Jan 16, 2022 7:32 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
perhaps it is a type-3 case |
Posted: Sun Jan 16, 2022 7:37 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
Wow! Is that the lone stud at the oil cooler mount?
Where is the case number stamped on your case?
Seems like Type 3 cases were stamped on top along the seam and not at the front on the gen stand.
Another thing, a universal case will have a dip stick like beetle/bus and a type 3 case will not. The Type3 will only have the lower hole to the right of the oil pump for the bolt on oil fill/dip stick. |
Posted: Sun Jan 16, 2022 7:43 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
Maybe it is a type 3 case. It is not stamped on the front but it is stamped on the top U5078859. |
Posted: Sun Jan 16, 2022 7:54 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
Yep, no type 1 style dipstick, but it does and a hole on the lower right and the upper left for the oil pump.
Posted: Sun Jan 16, 2022 8:05 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
I should have been more specific, the type3 oil fill/dip stick hole is in the lower right corner of the case sump, maybe an 1” in diameter with 2 studs. Looks like you do have a t3 case there. |
Posted: Sun Jan 16, 2022 8:21 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
I ran a Type3 case in a beetle for about 8 years once. Not the ideal setup, but I had this dip stick setup.
Chuck67 Samba Member
Posted: Sun Jan 16, 2022 8:33 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
Those are normal holes for the oil cooler. The seals are the same size and fit right in. Again totally normal |
Posted: Sun Jan 16, 2022 8:41 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
Cool dipstick adapter! Maybe I will still use the case.
I really thought it was an some type universal case, because it has the holes tapped for a mustache bar. Do type 3 use a mustache bar mount?
Can I still ran a doghouse cooler, I thought it was really weird that one hole was an 8 mm and one was a 10 mm for the oil cooler. Anything else I should know about running a type 3 in a beetle. Thanks for your help! |
Posted: Mon Jan 17, 2022 6:38 am Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
You can use that case though the aftermarket dip stick I used was not exactly ideal. Use a late offset oil cooler and doghouse shroud. Not sure what brand dip stick I used, maybe Empi. Good luck. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Mon Jan 17, 2022 12:37 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
yes, IRS type 3's use a mustache bar and yes that's a type 3 case. the dipstick adapters are the wrong angle, so be prepared to break it and epoxy it in the right place. You also won't have a spot for the oil pressure sender, on a type 3 it's on the oil cooler. Tap the case or use a type 3 cooler in a doghause shroud and make a hole for the sender. Type 3 cases are usually good |
KEGZ Samba Member
Posted: Mon Jan 17, 2022 1:07 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
Do people really use their dipsticks? If I were burning or leaking oil or lost oil pressure I'd know before having to pull the stick. Just curious.. |
Erik G Samba Member
Posted: Mon Jan 17, 2022 1:13 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
KEGZ wrote: |
I'm guessing you don't know much about a type 3 |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Mon Jan 17, 2022 1:30 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
I seem to remember looking down inside a cracked AS series T1 engine case, where the crack was from the gallery to the outside under the oil cooler.
That also was drilled like that with the larger hole to the front of the car.
I used the extra diameter to JB weld in an internal copper sleeve to almost stop the leak.. _________________ Ancient vehicles and vessels
icemanhd Samba Member
Joined: May 07, 2007 Posts: 275 Location: Camano Island, WA
Posted: Mon Jan 17, 2022 1:35 pm Post subject: Re: Why does my universal case have one 8mm and one 10mm? |
All of the dual relief cases have a larger pressure port for the oil cooler than the return port, its one of the easiest ways to see if a case is dual relief without having to flip it over and look for 2 relief springs. U series cases were for type 3s . _________________ 71 Drag Ghia
67 Bug, Hot VWs feature car
68 912
76 912E
87 911 Carrera |
