Quazi44 Samba Member
Joined: February 06, 2014 Posts: 1 Location: United States
Posted: Tue Jul 15, 2014 5:47 pm Post subject: how do you replace the quarter pop out window outer seal? |
I have a 69 beetle that I am trying to replace the outer seals on the pop out quarter Windows. Does anyone have a trick to make it easier??? |
LeninCas Samba Member
Joined: February 05, 2013 Posts: 447 Location: Orange County, CA
Posted: Tue Jul 15, 2014 5:53 pm Post subject: |
Poke them in with a flathead and use silicon or WD-40. _________________ one, two, many
one too many |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2407 Location: Gladstone, Ore
Posted: Tue Jul 15, 2014 6:10 pm Post subject: |
Plastic knife with the teeth filed off(scrape them on the sidewalk) and soapy water and patience. _________________ 1972 1302
HPMX 40's & 019 |
j.goodspeed Samba Member
Brian Samba Moderator
jwold Samba Member
Joined: September 30, 2008 Posts: 2088 Location: Portland, OR
Posted: Thu Jul 17, 2014 11:59 pm Post subject: |
Stretch the seal as you put it in. It makes the rubber lip that feeds into the channel thinner and it goes right in. When you release, it returns to it's thicker size and stays put. |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Fri Sep 12, 2014 11:10 am Post subject: |
Be patient and take your time.
-jeffrey _________________ Der Kleiner Kampfwagens |
irun5k Samba Member
Joined: February 21, 2014 Posts: 335 Location: St. Petersburg, FL
Posted: Fri Sep 12, 2014 6:26 pm Post subject: |
Harbor Freight sells a set of plastic panel/trim removers similar to what is shown in the video above. Just a few bucks but lots of utility on just about any weatherstrip/trim/other projects where you'd otherwise be tempted to use something that will jack up your paint. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Mon Jan 17, 2022 7:21 pm Post subject: Re: how do you replace the quarter pop out window outer seal? |
i need help guys.
its REAL hard to get this seal into the frame. And most of the time im just deforming the seal itself.
The seal is 5 plus years old. Was stored in a box of engine parts. but seems ok. No dry rot. I made sure the frame channel is clean.
help?
thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
Posted: Mon Jan 17, 2022 7:23 pm Post subject: Re: how do you replace the quarter pop out window outer seal? |
Lay it in the sun to soften... and lost of silicon. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jan 17, 2022 7:28 pm Post subject: Re: how do you replace the quarter pop out window outer seal? |
Glenn wrote: |
Lay it in the sun to soften... and lost of silicon. |
what sun lol?
I get what you mean tho. Ill give it a go.
'66 RIP
'69 RIP
Glenn Mr. 010
Posted: Mon Jan 17, 2022 7:37 pm Post subject: Re: how do you replace the quarter pop out window outer seal? |
When you get a small section in, try sliding it back and forth to make sure it's fully seated.
Get a cold beer, put on some music and take your time. _________________ Glenn
Member #1009
#BlueSquare |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4407 Location: Stuck in Ohio
Tvättbjörn Samba Member
Posted: Mon Jan 17, 2022 8:39 pm Post subject: Re: how do you replace the quarter pop out window outer seal? |
All seals from the last 15 + years are harder compared to the factory VW version , but they also last a lot longer. All my seals are WCM and none has any cracks after getting sun blasted for 10 years.
With a good lube and the strong narrow plastic bone (2nd from the right in your package) should take no more than 30 min per window.
Make sure your tool has no sharp edges.
1. clean out all the dirt and old seal from the frame with water, brush and soap
2. lube some of the frame and seal
3. place / insert the lower portion of the t-section into the lower part of the frame. Use your plastic tool and push in the upper portion of the T seal into the upper portion of the frame and slide along and repeat. You will be done in no time.
4. you might pull the seal a longer ( except the clued area ) to make it go in easier and just push it back. You will have to do it towards the corners anyway to make them sit good. |
Relyt Samba Member
Posted: Mon Jan 17, 2022 8:58 pm Post subject: Re: how do you replace the quarter pop out window outer seal? |
I used dielectric grease in the channel and on the seal and slowly popped it in with a little plastic tool. It was easy but a bit time consuming. _________________ 69 Beetle - Daily driver
1600 SP (unknown history)
30 PICT 1 w/power circuit (Volkzbitz)
205T (Bill) |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Mon Jan 17, 2022 11:28 pm Post subject: Re: how do you replace the quarter pop out window outer seal? |
I tried lube when I did my pop-outs. It just made the job more difficult.
I used a mouse-trap cheese to press the rubber in. That’s right: go and buy a mouse trap with the little rectangular plastic cheese on its trigger. Remove the cheese from the trap, and use the edge of your yellow treasure to press the rubber in without damaging it (the rubber, that is).
The “trick” is to make the rubber seal smaller, so that it fits easier into the groove. You do this by stretching it about two inches at a time, then pressing in the stretched (smaller) rubber. The rubber won’t slip in your hands, or out of the window groove, because you aren’t using slippery lube, remember? After about six inches, you have to massage the stretched rubber back into its normal shape. So, basically it’s two steps forward, and one step back. If you skip this part, you end up with a lot of stretched seal at the end of this ordeal. Of course, you don’t want that, so stretch a little, press it in the groove, stretch a little more, and repeat; then massage about half of the stretched length back to its original, fat-ass, shape.
Keep doing this until you get toward the end. You’ll still have too much seal, so massage it back into its fat, normal, shape.
The lube just seemed to make the rubber too slippery to handle, and the seal would just slip out of the groove, much easier than it went in.
However, you do want to clean out the groove first with WD-40. Clean it well, then wipe out 99% of the WD-40; then get to stretching, pressing with your cheese tool, then un-stretching … just a little at a time.
Pulling your own teeth is a bit easier, and my method is slow. But it works. When completed, you should end up with a few waves, but they disappear after a week, so don’t worry yourself about it.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
glutamodo The Android
Joined: July 13, 2004 Posts: 26307 Location: Douglas, WY
Posted: Tue Jan 18, 2022 12:14 am Post subject: Re: how do you replace the quarter pop out window outer seal? |
Does Bic still make cheap pens any more? Decades ago now, I installed popout frame seals (admittedly, 64/older style) I used the cap from a cheap Bic pen, the pointy bit, as my tool to press the seal into the channel. And yes it was warm and I think used Windex as lube. _________________ Andy T.
Michael Ambrozik Samba Member
Joined: October 17, 2020 Posts: 631 Location: San Jose, CA
Posted: Tue Jan 18, 2022 9:50 am Post subject: Re: how do you replace the quarter pop out window outer seal? |
If the wife/girlfriend/other will let you bring the work indoors. Place the seal on top of a heater vent to soften and use water with dawn dish soap (about 3 drops per 1/4 cup) in a spray bottle and a plastic trim tool and take your time. |
