susscrofa Samba Member
Posted: Mon Jan 17, 2022 4:07 pm Post subject: Support to rear apron removable |
Hi, somebody can share with me a picture(s) of the support than some put (from one rear corner to another), when do you made the rear apron removable; is to take an idea to make one. Thank you. |
bomberbob Samba Member
Posted: Tue Jan 18, 2022 11:37 am Post subject: Re: Support to rear apron removable |
What support are you asking about? I have my rear apron removed right now, awaiting an engine pull when warmer weather arrives. I can post photos if that would help. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
Posted: Tue Jan 18, 2022 11:53 am Post subject: Re: Support to rear apron removable |
Hi bomberbob, Yes, please send me pictures of your job.
Normally I see that many made the rear apron removable; in some magazine, I see that the owner of the car put a kind of pipe from one corner of the car to the other corner (where the rear apron was normally in place, to avoid close the corners of the "chassis".
Thank you for respond my issue. |
Posted: Tue Jan 18, 2022 12:12 pm Post subject: Re: Support to rear apron removable |
I did nothing like that with mine. When I put my apron in and slide the plastic in, and then tightened the fender bolts and put everything together, I saw no need. It felt pretty solid. Some may think that when the apron is welded in, that it is stronger and is more rigid than a removable piece. They are probably correct. However mine felt pretty sturdy so I moved on to the next problem.
I can still post photos, but I did nothing to add reinforcement on mine. _________________ 1968 Beetle (storage)
Marion, Iowa |
Posted: Tue Jan 18, 2022 12:37 pm Post subject: Re: Support to rear apron removable |
bomberbob, thank you very much. |
RandyV Samba Member
Joined: November 23, 2019 Posts: 357 Location: So Cal
Posted: Sat Jan 22, 2022 11:24 pm Post subject: Re: Support to rear apron removable |
bomberbob,
Yes, if you could please post pics of your setup, that would be great!!
Thanks! |
Posted: Mon Jan 24, 2022 2:45 pm Post subject: Re: Support to rear apron removable |
After a deep search I find this two images in Internet. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Mon Jan 24, 2022 3:14 pm Post subject: Re: Support to rear apron removable |
Your extra cross bar won’t prevent your apron from getting damaged. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Mon Jan 24, 2022 3:39 pm Post subject: Re: Support to rear apron removable |
Hi Mike, I only want a better stabilization of the rear "chassis" points. I know that do not give me a better protection in the zone.
Thank you for your comment. |
