Support to rear apron removable
susscrofa
susscrofa is offline
PostPosted: Mon Jan 17, 2022 4:07 pm    Post subject: Support to rear apron removable Reply with quote
Hi, somebody can share with me a picture(s) of the support than some put (from one rear corner to another), when do you made the rear apron removable; is to take an idea to make one. Thank you.
bomberbob
bomberbob is offline
PostPosted: Tue Jan 18, 2022 11:37 am    Post subject: Re: Support to rear apron removable Reply with quote
What support are you asking about? I have my rear apron removed right now, awaiting an engine pull when warmer weather arrives. I can post photos if that would help.
1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa
susscrofa
PostPosted: Tue Jan 18, 2022 11:53 am    Post subject: Re: Support to rear apron removable Reply with quote
Hi bomberbob, Yes, please send me pictures of your job.
Normally I see that many made the rear apron removable; in some magazine, I see that the owner of the car put a kind of pipe from one corner of the car to the other corner (where the rear apron was normally in place, to avoid close the corners of the "chassis".
Thank you for respond my issue.
bomberbob
PostPosted: Tue Jan 18, 2022 12:12 pm    Post subject: Re: Support to rear apron removable Reply with quote
I did nothing like that with mine. When I put my apron in and slide the plastic in, and then tightened the fender bolts and put everything together, I saw no need. It felt pretty solid. Some may think that when the apron is welded in, that it is stronger and is more rigid than a removable piece. They are probably correct. However mine felt pretty sturdy so I moved on to the next problem.
I can still post photos, but I did nothing to add reinforcement on mine.
Marion, Iowa
susscrofa
PostPosted: Tue Jan 18, 2022 12:37 pm    Post subject: Re: Support to rear apron removable Reply with quote
bomberbob, thank you very much.
RandyV
RandyV is offline
PostPosted: Sat Jan 22, 2022 11:24 pm    Post subject: Re: Support to rear apron removable Reply with quote
bomberbob,
Yes, if you could please post pics of your setup, that would be great!!
Thanks!
susscrofa
PostPosted: Mon Jan 24, 2022 2:45 pm    Post subject: Re: Support to rear apron removable Reply with quote
After a deep search I find this two images in Internet.
Mike Fisher
Mike Fisher is offline
PostPosted: Mon Jan 24, 2022 3:14 pm    Post subject: Re: Support to rear apron removable Reply with quote
Your extra cross bar won’t prevent your apron from getting damaged.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
susscrofa
PostPosted: Mon Jan 24, 2022 3:39 pm    Post subject: Re: Support to rear apron removable Reply with quote
Hi Mike, I only want a better stabilization of the rear "chassis" points. I know that do not give me a better protection in the zone.
Thank you for your comment.
