erdonline Samba Member
Posted: Mon Sep 09, 2013 6:44 am Post subject: 1.9 exhaust bolt size |
Anyone know the size of the bolts and nuts for the muffler bracket and muffler strap on a 1.9? I've got to do the job on both my Vanagons and I'd like to have the hardware ready when I remove/cut off the very rusty ones in place now.
Thanks,Ed _________________ '85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Mon Sep 09, 2013 6:49 am Post subject: |
M8x25
Check out vagcat.com
It is a great reference for details like this......
Good Luck _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
Posted: Mon Sep 09, 2013 9:16 am Post subject: |
Thanks for that reminder. I hadn't used Vagcat in a while, and I just signed up again last week. Some of the pictures are a little blurry, but it's still helpful.
geo_tonz Samba Member
Joined: August 01, 2012 Posts: 1472 Location: Courtenay, BC, CANADA
Posted: Mon Sep 09, 2013 10:30 am Post subject: |
While that GoWesty diagram is helpful for most of the bolts and studs, it leaves out the location I was looking for- the bolts on either end of the muffler strap.
Dwighia Samba Member
Joined: November 26, 2010 Posts: 78 Location: Arlington, VA
Posted: Tue Jan 18, 2022 4:48 pm Post subject: Re: 1.9 exhaust bolt size |
This is obviously for future generations, but I had the same question about bold sizes.
So here is what I'm using to replace the Cat, the Muffler, and the Tail pipe on my '84 Vanagon Camper Auto:
1. Muffler, cat, bolts:
(3 x 8m 1.25mm x40mm + nuts/washers)
(3 x 8m 1.25mm x30mm +nuts/washers)
I believe the difference in length is that some of the bolts also connect to the cross bars supporting the muffler/cat.
2. Tail pipe - these thread directly into the muffler (3 x 8m 1.25 x20mm - no nuts/washers)
Note: I bought "flanged" bolts. Not sure if that matters.
I have no idea why the length of these bolts are slightly different than those proscribed in GoWesty's pdf.
https://www.gowesty.com/files/11.9EXH-HW-KIT%20-%2...%20Kit.pdf
Also, I wasn't able to get copper nuts, so just went with what Advance Auto had in stock.
Hope this is helpful.
Dwight _________________ '71 Ghia Sedan
'68 Ghia Convertible
'84 Vanagon
If you dismantle a VW engine and reassemble it enough times, will you end up with enough extra parts for another engine? |
