jAndrew Samba Member
Joined: October 11, 2020 Posts: 306 Location: Atlanta, Georgia
Posted: Tue Jan 18, 2022 4:05 pm Post subject: Re: Further idle troubleshooting |
Vanagon Nut wrote: |
Ok so with all hoses installed, if either the T hose or other longer hose connected to ISV are closed, the idle is 950?
jAndrew wrote: |
Now, with the breather hose back in place and the other hose closed, as well and just the bottom where the T hose, it idles a bit lower at around 950. |
Yes, and quite steady. _________________ '89 Syncro Doka |
Vanagon Nut Samba Member
Posted: Tue Jan 18, 2022 8:57 pm Post subject: Re: Further idle troubleshooting |
Ok, good.
Well, maybe someone more knowledgable than me can comment but to me, it sure seems like something in the idle control system has a fault.
But assuming the duty cycle test shows that the current draw is out of spec, afaik, that doesn't really point to one specific part.
The ICU can be opened up. Sometimes, a failure of a component on that unit is obvious.
I found that mine was held pretty tight to the socket so take your time removing it; the contacts in the socket are a specific design that really grips the male contacts.
In terms of taking it apart, what I'd do is use a thin semi wide plastic tool to separate the case from brown board part. Just work your way around. Once you have the case loose, the printed circuit boards should slide out.
Neil.
ICU socket
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Posted: Wed Jan 19, 2022 5:30 am Post subject: Re: Further idle troubleshooting |
Ok, good.
Neil.
ICU socket
Thanks Neil, I appreciate you, and others, for taking the time to help out with this. Hopefully some day I will have the experience to pay it forward.
I inspected that socket some months ago and there was no signs of anything obvious. It was remarkably clean. I will have another go and do some of the testing in the manual. _________________ '89 Syncro Doka |
Posted: Wed Jan 19, 2022 8:54 am Post subject: Re: Further idle troubleshooting |
You're welcome Andrew.
My money is on a bad ICU. That said...
I'm sure this was mentioned but if your Syncro has power steering, if the "hot" PS switch wire has shorted to ground for any length of time, that could've damaged wires which *might* include wires to/from ICU socket.
VE7TBN |
Posted: Wed Jan 19, 2022 9:31 am Post subject: Re: Further idle troubleshooting |
Neil. |
No power steering. _________________ '89 Syncro Doka |
Posted: Wed Jan 19, 2022 9:41 am Post subject: Re: Further idle troubleshooting |
From another post by Gauche1968:
"Assuming the OP has Digijet, he has a different component. The Digital Idle Stabilizers' job on Digijet is to constantly alter timing at idle on the fly to keep idle from falling below 800 RPM. Typical failure mode is the van wont run at all, because the ignition signal is not getting through the failed component. You test for this by unplugging both connections and snapping them together. If the van starts and runs the idle stabilizer was bad (Of course, there could have also been a wiring problem that unplugging and plugging back in temporarily cured)."
I will play around with the ICU a while later. _________________ '89 Syncro Doka |
Posted: Wed Jan 19, 2022 3:19 pm Post subject: Re: Further idle troubleshooting |
Ahhh, right, ok.
I now see J 87 DIS unit in the 2.1 Digijet diagram at "engine compartment left" as well as an N 41 TCI also at "engine compartment left". However, the same set of diagrams do show an idle speed stabilization unit at "engine compartment right".
Apologies if I kept your focus on the wrong part!
Neil.
jAndrew wrote: |
I will play around with the ICU a while later. |
VE7TBN |
bajabones Samba Member
Joined: April 17, 2019 Posts: 134 Location: Tacoma, WA
Posted: Wed Jan 19, 2022 6:02 pm Post subject: Re: Further idle troubleshooting |
I have the same rig & motor
I went through all tests & troubleshooting
Changed all the parts
The things that fixed it were
The fuel filter & intake manifold gasket’s & boots and the special NGK plugs
Runs perfect _________________ 1990 Syncro Doka
2.1 DJ
Triple Knob
Solid shaft |
slo356 Samba Member
Joined: February 18, 2002 Posts: 365 Location: Central Calif Coast
Posted: Wed Jan 19, 2022 11:10 pm Post subject: Re: Further idle troubleshooting |
This wandering idle issue is so common with so many different solutions, I would like to see a poll on what-solved-what? How many people found timing? How many found the ICU? How many found vacuum leaks? Where?...etc. Of course there are a great deal of variables here but I think a poll could be worded in a way that would capture at least solution trends.
A poll could then be converted into an organized mathematical flow chart which might lead to quicker solutions for many.
Maybe share poll results with vendors which "could" help with stocking necessary parts.
There is a great deal of accumulated real world experience here in the Forum and capturing it and then converting results to data would be a useful effort. _________________ '65 T1 Sedan
'87 T3 Syncro
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Thu Jan 20, 2022 5:54 am Post subject: Re: Further idle troubleshooting |
Ahhh, right, ok.
Neil.
jAndrew wrote: |
This is some odd mix VW made using the Digijet injection with the Digifant style Idle stabilizer.
To confuse things more, no catalytic convertor and no 02 sensor.
I'm of zero help but watching with interest and learning.
Ghia
Vanagon
Beetle
Posted: Thu Jan 20, 2022 9:41 am Post subject: Re: Further idle troubleshooting |
From my non expert level point of view, comparing 1985 1.9 Digijet in Bentley vs 2.1 Digijet diagrams, though there's differences in wire colours, the wire assignments of 2.1 Digijet N41 J87 and 1985 Digijet 'transistor ignition control unit' and hall gen, *appear* to be the same.
I have only found the wiring diagrams for 2.1 Digijet so don't know if the Pro Training manual shows this but were it me, since it seems the ISV or ICU may have a fault, I'd fully disable the ISV ICU system then test N41 J87 parts and maybe check engine timing. i.e. an known good engine w/o PS and/or AC should idle and run fine without the ISV ICU system.
Neil.
I now see J 87 DIS unit in the 2.1 Digijet diagram at "engine compartment left" as well as an N 41 TCI also at "engine compartment left". However, the same set of diagrams do show an idle speed stabilization unit at "engine compartment right". |
jAndrew wrote: |
"Assuming the OP has Digijet, he has a different component. The Digital Idle Stabilizers' job on Digijet is to constantly alter timing at idle on the fly to keep idle from falling below 800 RPM. |
VE7TBN |
