58ragman Samba Member
Joined: September 29, 2014 Posts: 404 Location: OC to ontario
Posted: Tue Jan 18, 2022 4:40 pm Post subject: anyone got a street 6 rlr clutch howz it doing so far |
in the market for a clutch. wanted to see if anyone can give feedback on a STREET 6 clutch not a race rev 6 set up |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Wed Jan 19, 2022 4:54 am Post subject: Re: anyone got a street 6 rlr clutch howz it doing so far |
whats the diff? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Wed Jan 19, 2022 5:12 am Post subject: Re: anyone got a street 6 rlr clutch howz it doing so far |
clutch discs |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Wed Jan 19, 2022 5:54 am Post subject: Re: anyone got a street 6 rlr clutch howz it doing so far |
Light clutch pedal, consistent and smooth on the street. Clutch disks don't last long if you take it to the strip often. Choose your trade-offs. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
vw_chuck Samba Member
Posted: Wed Jan 19, 2022 8:07 am Post subject: Re: anyone got a street 6 rlr clutch howz it doing so far |
I saw one for sale on here all burned up. Not sure they work as advertised on some peoples cars. |
KEGZ Samba Member
Joined: October 11, 2021 Posts: 288 Location: Whales Vagina
Posted: Wed Jan 19, 2022 9:44 am Post subject: Re: anyone got a street 6 rlr clutch howz it doing so far |
I have it. Not installed yet. However, I was talking to Ron at BUGIN and he said there's are plenty of people running the normal REV6 on the STREET. People with 500HP on tap. |
Posted: Wed Jan 19, 2022 9:58 am Post subject: Re: anyone got a street 6 rlr clutch howz it doing so far |
i wanna make the plunge but cant decide a 700 dollar set up or 1700 dollar set up.the 700 dollar set up consist of flange fly, rlr disc shimmed KEP stage 1 plate,
the 1700 dollar set up consist of the flange fly 2 rlr discs and clutch plate
going on street |
KEGZ Samba Member
Posted: Wed Jan 19, 2022 11:09 am Post subject: Re: anyone got a street 6 rlr clutch howz it doing so far |
58ragman wrote: |
going on street |
I'd call Ron. He's pretty open about it. But I'd say that if you will be 100% street, he did stand firmly behind the street 6 setup. He had me almost regretting picking it up but I figured I'd just be putting it to the test and see it's limitations first hand. I previously had a stg 1 with the black magic and even that held firm once I picked up the correct flywheel. People make the HUGE mistake (including me) of using a chromoly fly with sintered iron. German steel only! |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1852 Location: Grass Pants, Orygun
Posted: Thu Jan 20, 2022 11:06 am Post subject: Re: anyone got a street 6 rlr clutch howz it doing so far |
vw_chuck wrote: |
I bought that one. They always look burnt up. My friend Dean Nilson went 8.60s 1/4 mile in his pro mod bug with his Rev 6 burnt and warped. He said it didn't grab any different with everything resurfaced and fresh so he kept running it. I plan on glass beading the disc and putting it back into service. _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2020lbs with driver
7.76 @ 89.55mph 1/8 mile
12.34 and 108.10 mph 1/4 mile |
Posted: Thu Jan 20, 2022 11:19 am Post subject: Re: anyone got a street 6 rlr clutch howz it doing so far |
KEGZ wrote: |
58ragman wrote: |
going on street |
I have been running a RLR Black Magic Super 7 with a stage 1 for a couple years now with a chromoly Bugpack flywheel and no issues, 215 hp, 2000lb street car on DOT slicks and 7,000 rpm launches. Although the RLR website doesn't say the material their flywheels are made from, they are definitely not German steel. I have machined 4 of his flywheels and would bet they are 4140 or 4340 chromoly. _________________ John Bates
KEGZ Samba Member
Posted: Thu Jan 20, 2022 2:09 pm Post subject: Re: anyone got a street 6 rlr clutch howz it doing so far |
stealth67vw wrote: |
KEGZ wrote: |
58ragman wrote: |
going on street |
I have been running a RLR Black Magic Super 7 with a stage 1 for a couple years now with a chromoly Bugpack flywheel and no issues, 215 hp, 2000lb street car on DOT slicks and 7,000 rpm launches. Although the RLR website doesn't say the material their flywheels are made from, they are definitely not German steel. I have machined 4 of his flywheels and would bet they are 4140 or 4340 chromoly. |
Sure, but that's 215 hp. You can get away with a stage 2 KEP and copperhead disc with that. No wonder you aren't slipping like I was . And I wasn't only slipping at launch, I was slipping under a shitload of boost on the top end. No matter how I shimmed the PP or bead/sand blasted the disc. But don't take my word for it.. call Ron and ask him yourself. He'll tell you the same thing he said to my face. Chrome Vanadium or Kennedy flywheels with the BM only. Also, I only relay information based on first hand experience. /shrug |
Posted: Thu Jan 20, 2022 11:28 pm Post subject: Re: anyone got a street 6 rlr clutch howz it doing so far |
thanks for all the insight and info guys |
