Jonasand Samba Member
Joined: September 07, 2016 Posts: 239 Location: Sweden
Posted: Thu Jan 20, 2022 1:07 pm Post subject: Priming oil pump before assembly, whats the procedure? |
Hi!
I'd like to know what you guys do with your oil pump before assembly, say that you have cleaned all the parts with carb cleaner and everything is dry... what do you use for lubing it up before assembly?
I'm thinking that maybe its good to do a light touch of engine oil and then pack with assembly lube? Or would the oil cause the assembly lube to break down therefore making it wiser to go with pure assembly lube and no oil?
And would rotating the engine (after oil pump is back in case) pump out the assembly lube from the pump?
If so then perhaps it is better to wait with putting the pump back in till you know its time to rock n roll?
Any wise words on this from the experts?
Thanks _________________ 79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters |
Brian Samba Moderator
Posted: Thu Jan 20, 2022 1:08 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
I pack it full of Vaseline. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
SGKent Samba Member
Posted: Thu Jan 20, 2022 1:26 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
as soon as you spin it whatever is in there gets pushed out and new oil will be pulled in. On late T4 cases there is a loop where excess oil gets pushed back into the oil pickup. Any air and the pump cavitates. On a late case you leave the oil filter off, put a pan under it and spin it for a second no plugs until it dumps oil. Then put the filter on, try again and see if you get pressure. If so then put plugs in and start it.
On T1 engines and early T4 engines you crank it with the plugs out until it gets pressure. If so then put plugs in and start it.
Some people use vaseline, others like me use a thick oil with the red assembly lube in it. Don't use grease because it can clog oil passages. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jan 20, 2022 1:47 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
Is it a bad idea then to put the oil pump (with the assembly lube) in the case before the cylinders are installed... I mean would the pressure from turning the motor over by hand (for example when installing cylinders and pistons) cause the assembly lube to move out of the pump causing it to not prime as well?
Or am I overthinking this?
Perhaps there is still enough gooey stuff in the pump when it is time to actually start the engine, even though the pump has been turned by hand a few times during assembly of the rest of the engine? _________________ 79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters |
SGKent Samba Member
Posted: Thu Jan 20, 2022 2:47 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
The assembly lube and oil is really sticky so it won't all drain out. You can also pour some into the oil pressure hole and it will drain down a bit to the pump. Just remember that if it is a late T4 case then you have to spin it with the filter off etc until it gets oil coming out. Make sure when you bolt the case halves together that you also seal up that extra inlet. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jan 20, 2022 3:39 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
Where is this oil pressure hole situated?
I’ve got a GE engine case, so thats a late type 4 _________________ 79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters |
SGKent Samba Member
Posted: Thu Jan 20, 2022 4:35 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
Posted: Thu Jan 20, 2022 6:43 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
One trick you can do is before installing the engine, fill the crankcase with the specified amount of oil and then rock it towards the oil pump to about 30° from the horizontal and then turn the engine over a few turns by hand. This would make the oil pump awash with oil so it would prime easily. |
Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Thu Jan 20, 2022 7:22 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
Jonasand wrote: |
Perhaps there is still enough gooey stuff in the pump when it is time to actually start the engine, even though the pump has been turned by hand a few times during assembly of the rest of the engine? |
My last couple builds, I just cranked over with plugs out, filter was prefilled with oil before installing, and cranked for about 20 secs. put the plugs in and started right up. oil light went out almost instantly at start up. no matter what you put in there, you will inevitably push out during final assy and hand rotating the engine around, or during pre-charging of oil system. during assy of pump, i just flood the gears with break in oil. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson |
SGKent Samba Member
Posted: Thu Jan 20, 2022 7:40 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
Jetfxr69 wrote: |
Jonasand wrote: |
My last couple builds, I just cranked over with plugs out, filter was prefilled with oil before installing, and cranked for about 20 secs. put the plugs in and started right up. oil light went out almost instantly at start up. no matter what you put in there, you will inevitably push out during final assy and hand rotating the engine around, or during pre-charging of oil system. during assy of pump, i just flood the gears with break in oil. |
doesn't always work on the late cases due to that oil feed back loop pickup port. Early cases yes because the air gets blown out into the case, but on a late case the air goes round and round unless you give it an easy path out. I learned that the hard way on the first one of those late cases I built. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Brian wrote: |
I pack it full of Vaseline. |
No comment _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Jan 21, 2022 3:05 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
SGKent wrote: |
doesn't always work on the late cases due to that oil feed back loop pickup port. Early cases yes because the air gets blown out into the case, but on a late case the air goes round and round unless you give it an easy path out. I learned that the hard way on the first one of those late cases I built. |
I have a GE engine with hydraulic lifters... does that mean I have a single relief case and if so...would the "air circulating in the oil pump" - problem be an issue in a GE Hydraulic engine? Or is this only a problem with Single relief, solid lifter engines?
Reason I ask is that I read this thread;
https://www.thesamba.com/vw/forum/viewtopic.php?t=656043&highlight=
In above thread @airshooled says that perhaps the hydraulic lifters could act as a control valve.
@WildThings Would leaning the motor 30 degrees and turning over (as per your suggestions) make the air inside the pump escape? Or is the only way to unscrew the oil filter...
@SGKent Your suggestion of spinning the motor with the oil filter off... Do you do this prior to installing the engine or do you do it with the engine inside? Sorry if this is a stupid question... _________________ 79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters |
Posted: Fri Jan 21, 2022 3:21 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
With the engine steeply tilted and the pump at or below the oil level it should prime easily.
When trying to get a pump to prime on any rig, I will often loosen the filter so it will not put backpressure on the pump. Prefilling the filter can be a detriment when trying to prime a pump.
I have found pouring oil into the port for the oil pressure switch to be effective. I use a plastic Coleman funnel with a fine mesh screen that will actually screw into the port and dump in a fair amount of oil. If nothing else this give you full oil galleys and oil to the bearings. |
SGKent Samba Member
Posted: Fri Jan 21, 2022 5:05 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
late cases have an issue where they often take time to build oil pressure when they sit. No one really knows why, and there are lots of theories. The one that seems to make the most sense is that on the late case, any oil that gets pumped by the pump is pushed back to the oil pump pickup when it goes thru the single pressure relief. Once air gets into the pump, it foams up and the pump doesn't pump properly. If you crank the engine, let it sit for 5 seconds or so, crank again, let it sit for 5 seconds or so, then about the 3rd time it will get normal pressure. The first GD engine I built, I did not seal that passage really well, and could not get oil pressure on the engine while just cranking it. I pulled the sender off the hose (I have a dual sender) aimed it at a can, cranked it and had oil instantly almost. Put the sender back on and the engine had oil pressure perfectly like every one of the thousands of engines I have built. Let it sit for a week and I have to go thru the 5 second thing. The new case I have does not do this but I sealed that passage really well. Considering the number of late cases that have lifters that get air in them, I think it is all together possible this loop is the cause. Before that, the engine dumped any overflow out into the case. So if there was air in oil system up high it had no way of getting back to the pump inlet. Late cases it does. So I don't know if I have confused you or answered your question. If you ask why did VW do that loop, the only thing I can figure out is that any oil that bypasses from over pressure goes back thru the oil cooler over and over until it is used. That would help control oil thickness on the oil going to the hydraulic lifters, and hence control the lifter bleed down rate. Solid lifters didn't need that control. Earlier cases you are dumping cooled over pressure oil back to the case to help with sump temperature. Late case you are cooling the oil over and over before it is used regardless of the sump temperature. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Jan 22, 2022 1:59 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
Thanks for the info Steve, not confused, well maybe, but this problem is good to know about.
For me that would be two problems then;
1. Below normal oil pressure if the engine has sat for a while
2. Air getting into my hydraulic lifters
I'm guessing you have a oil pressure gauge with where you can get more numerical readings. I just have an oil pressure light, the one with the oilcan symbol.
Will the regular gauge be enough to warn me about this scenario that you speak of?
What harm can this lower then normal oil pressure do?
Is there anything else I could do to mitigate this problem without sealing that passage?
Would using synthetic oil do anything?
I have heard this its good for hydraulics. Perhaps different oils are different with regards to how they behave when air gets into them? Just taking wild guesses here... _________________ 79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters |
Posted: Sat Jan 22, 2022 2:45 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
stick the pump in the hole, fill engine with oil, and crank till light goes out. then put in plugs and let ‘er rip. its NOT rocket science for christ’s sake. unless your engine is made of porcelain, it will be fine.
i work on jet aircraft and dont know shit, my advice to you is to take a train. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
SGKent Samba Member
Posted: Sat Jan 22, 2022 3:33 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
If the light doesn't go out for 20 -25 seconds when a bus with a late engine case has been sitting, it probably means air has gotten into the oil pump via that passage VW added, and it is foaming the oil so no pressure results. Crank or let it run for max of 4 - 5 seconds if the light is on. Wait 7 or 8 seconds and do it again. Usually the 2nd or 3rd time the light will go off. Waiting 8 - 12 seconds for oil pressure is far more desirable than 20 - 25 seconds. If you drive the bus every day you'll never see this issue. It takes 4 to 5 days of sitting for it to appear. Has been reported many times here on the forum and there are many people who propose different fixes.
As to hydraulic valve lifter clatter on start up, VW said in a tech bulletin to instruct the client to ignore it and wait until it goes away after driving a short while. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Jan 23, 2022 2:33 pm Post subject: Re: Priming oil pump before assembly, whats the procedure? |
Thank for clarifying! I’ll try to remember this when the time comes to start her up... hopefully soon... _________________ 79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters |
