ZENiC Samba Member
Posted: Sat Jan 22, 2022 3:03 pm Post subject: Anyone know what this is |
I have a 93. Got a new engine put in recently. I was checking something in the engine bay and saw this capped off hard line I don't remember. anyone know what it is?
subdewd Samba Member
Posted: Sat Jan 22, 2022 5:12 pm Post subject: Re: Anyone know what this is |
Test port for egr |
Zeitgeist 13 Samba Member
Posted: Sat Jan 22, 2022 7:05 pm Post subject: Re: Anyone know what this is |
It's hard to tell but it appears that your vacuum line is disconnected from the port on the firewall between the two heater hoses. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
BatesEV Samba Member
Joined: October 01, 2019 Posts: 182 Location: Los Angeles
Posted: Sun Jan 23, 2022 4:59 am Post subject: Re: Anyone know what this is |
It’s the port to test for the CO. When tuning the mixture this is where you sample the exhaust gas at. The 3 wire intake air sensor has a potentiometer in it that is adjustable to set the CO. From corrado folks they say a good ohm reading start point is about 500.
FYI 93 don’t have an egr. Only the 95 ACU did. |
ZENiC Samba Member
Posted: Sun Jan 23, 2022 4:02 pm Post subject: Re: Anyone know what this is |
So am I safe to say the new motor is from 95+ then? |
Posted: Mon Jan 24, 2022 4:58 am Post subject: Re: Anyone know what this is |
No cause the 95 didn’t have it, and that is in the cast iron exhaust manifold. The manifolds are different but interchangeable. I upgraded to the later model one myself.
If you want to know on the front of the block AAF(93 engine) or ACU(95 engine) will be stamped in the block. |
Posted: Mon Jan 24, 2022 5:15 am Post subject: Re: Anyone know what this is |
My 95 has it. It's on the newer manifold. It broke off on mine so I welded the opening closed. It's an acu |
ZENiC Samba Member
Posted: Mon Jan 24, 2022 5:26 pm Post subject: Re: Anyone know what this is |
BatesEV wrote: |
Unlikely, I'm gonna find the stamp. I don't really care when the engine is from, I'm not a huge fan of unbolted hard lines with caps on them. |
