cdorety Samba Member
Posted: Sun Jan 23, 2022 1:22 pm Post subject: Re: Alternator wiring |
Max Welton wrote: |
cdorety wrote: |
What is the black wire which comes out of the back of my indicator/fuel gauge? |
Isn't that a +12v? I can't remember. Flip that over and it goes to the indicator light bases, right?
Max |
I think you are right. +12v
I have replaced the black wire with a red one to keep things color coded with the new harness.
now..... do I wire them to a 'switched' power or to 'always on' power. or does it matter.
Next up is the hazard flasher, then the engine stuff. Then tail lights and I should be done!
Still waiting on a couple parts to arrive.
Thanks again |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
ibldrc Samba Member
Joined: September 23, 2015 Posts: 156 Location: Savannah, GA
Posted: Tue Jan 25, 2022 6:41 am Post subject: Re: Alternator wiring |
cdorety wrote: |
I have replaced the black wire with a red one to keep things color coded with the new harness. |
My experience with the aircooled VW wiring is
Red= always hot,
Black= switched hot, and
Brown = ground.
If I'm right, and you want it to remain color coded, you should leave it black, because these lights need to be switched hot (Black), or else your gen and oil light will stay on when you turn off your key. _________________ '64 1500 S
'65 Variant S
'66 1600TL
'67 Squareback
2003 Jetta "Variant" TDI
2008 Passat Wagon 2.0
1500 Build thread
http://www.thesamba.com/vw/forum/viewtopic.php?p=7904818&highlight=#7904818 |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Tue Jan 25, 2022 6:58 am Post subject: Re: Alternator wiring |
ibldrc wrote: |
cdorety wrote: |
Red= always hot,
Brown = ground.
If I'm right, and you want it to remain color coded, you should leave it black, because these lights need to be switched hot (Black), or else your gen and oil light will stay on when you turn off your key. |
This is correct. |
vwfye Samba Member
doc73 Samba Member
Posted: Mon Dec 26, 2022 11:24 am Post subject: Re: Alternator wiring |
I'm running the same style alternator. My problem is getting the light to come on at the gauge. So if the switched wire from the coil goes to one of the terminals on the back of the alternator, should the other terminal have power? Currently mine does not. I know the bulb at the gauge works. In fact the only way I get the light at the gauge to work is when I directly wire it to the coil but only if that black +12v wire on the gauge is disconnected from the fuse panel. Forgive me if i read over some part of how this is supposed to be wired correctly. _________________ Speed Leaving Without Warning . . .
66 Bug
66 fastback (sunroof) |
doc73 Samba Member
Posted: Mon Dec 26, 2022 2:36 pm Post subject: Re: Alternator wiring |
When everything is wired correctly, when should the warning/gauge light come on? _________________ Speed Leaving Without Warning . . .
66 Bug
Bobnotch Samba Member
Posted: Mon Dec 26, 2022 3:12 pm Post subject: Re: Alternator wiring |
doc73 wrote: |
When everything is wired correctly, when should the warning/gauge light come on? |
With the key on, and the engine off. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
doc73 Samba Member
Posted: Mon Dec 26, 2022 6:34 pm Post subject: Re: Alternator wiring |
Okay I have all wires correctly in place according to this thread. Via a test light I have no power at the L terminal when the S terminal is powered via the coil. Is this an indicator that some thing internally is bad between the S and L terminals? _________________ Speed Leaving Without Warning . . .
66 Bug
