CrRusty Samba Member
Posted: Tue Nov 05, 2019 7:34 am Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
timvw7476, That fuel mileage is respectful. One of the fine tuning for decent fuel mileage is "tuning" the carbs. Do you have any information about the jetting sizes that you are currently using? It appear as if you have it dialed in very well. Thx for any info. R. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Tue Nov 05, 2019 10:38 am Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
Parts wear out in 35 years. Static timing is only used to get an engine to run in order to strobe time it these days.
Don't fax your bank statements, and don't static time your Type 4 for a road trip.
The cool thing about experimenting with timing, is that it's quick, free, and easily reversible. Set it to 28° btdc at maximum advance with the hose(s) off, and let us know where the timing lies at idle. THEN adjust your idle speed to 950-1,000 RPM, unless you have an emissions test that mandates something else.
Tire pressures are NOT 36psi in the front, I'm not sure where that figure came from. Check your door jam, gas flap, or steering column for correct pressures.
www.airschooled.com |
beetleman217 Samba Member
Posted: Tue Nov 05, 2019 3:58 pm Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
I will measure the idle rpm as well as the oil pressure and report back. However, since the symptoms I described appeared as soon as the bus left the shop after the distributor swap, it is likely that they are a direct result of that. As far as I know, the mechanic did not mess with my engine, so common’, what are the chances of an oil sender all of the sudden deciding to go bad? Or any other component for that matter? _________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
Posted: Tue Nov 05, 2019 6:00 pm Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
Everything relating to spark and induction affects everything else. Change the timing and idle airflow changes. Which changes the engines speed and mixture. Set the timing too advanced and the engine runs hotter. Hotter engines equal lower oil pressure. Lower idle speed equals lower oil pressure.
Bottom line, is that someone who does something the same way for 35 years while parts wear out and change spec is not paying attention to all the details and factors that affect the way an engine runs.
A 009 has one internal advance spring, and one free weight, which changes the advance curve significantly from stock. They often time differently at idle vs. static timing them with a test light.
Achtung! A fuel-injected bus should have the vacuum advance taken off the firewall side of the throttle body. The EEC valve on the air cleaner should be T’d into that line. If the EEC valve does not hold a perfect vacuum when sucked on by mouth, the leaky valve will “steal” all your vacuum advance, and you’ll be left with a pretty and expensive distributor that behaves like a worse 009. Please do check for correct vacuum hose routing AND a leaky EEC valve before blaming a low fuel economy on a new distributor.
Until you get a chance to check where your max advance truly is, and adjust the car accordingly, there isn’t really much else discussion to have.
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Thu Dec 31, 2020 12:51 pm Post subject: |
jasonbye wrote: |
73 UK Spec Westfalia Continental
Stock TP 1600
2 Adults, 4 kids, a Westy Trailer and camping kit for us all.
Over 1000 miles, averaging 25.7 (Imperial MPG = 21.4 US)
Using Road Trip on my iPhone, which is superb. I'd recommend it. |
That sounds about right for a 1973 VW 1600 Type 2 Westfalia Continental.
With the Minnow Fish carburettor, I used to get 25.0 +/- 0.5 miles per IMPERIAL gallon touring in mainland Europe with my 1973 VW 1600 Type 2 Westfalia Continental, running with 185 SR14 Michelin XZX Reinforced radial-ply tyres. I'm not sure what it was with the original cross-ply tyres!?!
I hope to get better than this with the 1911 cc Type 4 engine (CR = 8.0:1), VW 1800 Type 2 transaxle and 215/65 R16C tyres on Mercedes C-Class alloy wheels. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
914guy Samba Member
Joined: September 08, 2008 Posts: 167 Location: Cincinnati, Ohio
Posted: Thu Dec 31, 2020 4:49 pm Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
We get 18 mpg in our 74 with a 76 2liter, going 65 to 70 during road trips. We have a Holley weber carb. About 14 mpg or so in stop and go traffic. |
tjrm63 Samba Member
Joined: November 15, 2007 Posts: 116 Location: Jersey Shore
Posted: Thu Dec 31, 2020 6:48 pm Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
Camping trip to Poconos mainly highways and some mountain roads
19 mpg at 68 mph highways fully loaded 71 bus with 1904 dual 40 webers, 79 pop top
_________________ I don’t care how much it’s worth now.
I care how much this bus makes me happy |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
tjrm63 Samba Member
Posted: Fri Jan 01, 2021 6:04 am Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
I installed the camping interior first and a year later I found a pop top and cut the hole in the roof and installed it
Slip356 Samba Member
Posted: Fri Jan 01, 2021 6:51 am Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
Robbie, you are spot on. 78 stock Westy, searching why running hot have VDO oil temp gauge. Fooling around with timing last year, set to 28 at WOT, thought I was good, but with hose back on distributor, still 28 at WOT.
Traced the vacuum hose & found the tee to the air cleaner thinge, sucked on the hose to the thinge & sure enough, didn’t hold a vacuum. Bypassed the tee to the thinge and bus really woke up and oil temps came down noticeably.
As you know Bentley has specific TOTAL advance numbers for many distributors, and mine was spot on.
How long was I driving like that, 1 mile, 10 miles, 100 miles, 1000 miles or more?
Some say you will smell gas after shutting down without the thinge working but I haven’t had that problem. |
bryancald Samba Member
Posted: Wed Jan 19, 2022 6:14 pm Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
1977 Westy Deluxe
Fresh 2.0L Fat Performance, mild cam, dual Weber 44IDF's
Stock 4 speed
27X8.5/R14 LT Grabber A/Tx tires
Freeway speeds up to 65
13-16mpg mostly freeway
Driving style: lots of hills and wind
I feel better seeing other people's fairly terrible mileage _________________ [url=http://www.vw-mplate.com/mplate2-27844.png]Click to view image[/URL] |
cellobus1 Samba Member
Joined: June 10, 2014 Posts: 284 Location: East Tennessee
Posted: Thu Jan 20, 2022 12:42 am Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
Hi, my '76 transporter (2.0 litre points FI stick) went from Cadiz, KY to Knoxville TN on a tank of gas, 262 miles. Really down to the nubs on the fuel gauge upon arrival. Speed 50-60. Divided by 14.6 = 17.9 mpg, but really depends on where true empty is on the gauge. Not sure where the reserve tank comes in vs. where the needle displays true empty. _________________ 1976 unrestored daily driver Standard bus, "Stella"
formerly, 1959 Standard bus
formerly, 1973 transporter which was 4 years old when it taught me to drive |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Tue Jan 25, 2022 3:29 am Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
bryancald wrote: |
1977 Westy Deluxe
Stock 4 speed
I feel better seeing other people's fairly terrible mileage |
40's would suffice far better than 44's on a 2L. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Calocedrus Samba Member
Joined: January 03, 2021 Posts: 21 Location: Humboldt County, CA
Posted: Tue Jan 25, 2022 12:58 pm Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
1969 Sundial Camper (straight up poptop)
1600 SP
EDIT: Stock 205t Distributor
Stock Fuel Pump
Solex h30/31
CB CW Crank 69mm
Stock balanced rods
Engle W100 Cam
Balanced AA Pistons
GEX Heads (VW)
Stock Exhaust
Thunderer 101 tires (no idea psi)
2 dogs
3 people
Stuffed with clothes, x-mas presents, beer, gear...etc...
Averaged 19.34 mpg (n=8, max=22.4, min=16.94)
I was cruising at about 60mph on flat freeway, 25 mph in 2nd gear on the grapevine and similar grades (terrifying). Also had a lot of construction along the way. I think that is where the gas mileage dropped off.
Only topped off the oil once on the 1500+ mile journey. _________________ -1969 Type 2 Sundial SP 1600 |
babysnakes Samba Member
Posted: Sat Mar 18, 2023 3:26 pm Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
'78 Westy. 2.0 solid lifter with stockish Web cam. 40 DRLAs. 185r14c Hankooks. average highway speed 65. 14 mpg. Not a happy camper, nor am I. |
Posted: Sat Mar 18, 2023 5:26 pm Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
babysnakes wrote: |
What are your jets? Brakes dragging? _________________ Learn how your vintage VW works. And why it doesn't!
SGKent Samba Member
Posted: Sat Mar 18, 2023 5:38 pm Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
babysnakes wrote: |
I'd put a A/F gauge on it and see what is going on. Are you using an 009 distributor with mechanical advance only? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Sat Mar 18, 2023 6:16 pm Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
My last 1060 mile trip towing a ‘73 Allstate trailer I netted 19.75 MPG. Mostly highway driving, with little city miles. Cruised 60-65 most of the time. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Sun Mar 19, 2023 1:18 am Post subject: Re: What's your MPG (miles per gallon) fuel gas mileage FAQ |
my 1971 westy with a 1641 and Norris bus cam nets me 23/24 mpg. with full camp gear. Iam building a 1776 now with another Norris bus cam and a two-barrel weber will see what happens. I ran this same setup in the 70's in another 71 westy and I got 23/24 mpg with it. _________________ where its cold and snowy |
