Sdkfz58 Samba Member
Posted: Tue Jan 25, 2022 4:55 am Post subject: -51 Split handbrake assembly and transmission mount |
Hi everyone and thank you already for your replys.
Im currently making chassis ready for blasting and i noticed while removing handbrake parts that this one has been fitted with maybe oval style brake parts. Should it be like that or has someone changed original split style parts to newer oval style? Also there was wrong trans when i picked it up( late 60s), so im guessing that chassis trans mount is added later? Here are some photos from the chassis ( chassis number 1-0254219)
Sorry if my writing is not accurate, im from finland. |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Jan 25, 2022 9:55 am Post subject: Re: -51 Split handbrake assembly and transmission mount |
… looks like the correct hand-brake parts, with front adjusters - used to 1955 models - 1956 and later, adjusted inside the car, on the hand brake - a better design - i'm from Oklahoma - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Thu Jan 27, 2022 4:05 am Post subject: Re: -51 Split handbrake assembly and transmission mount |
Thank you for the info. I add that spring plate to my shopping list then. |
mikeandkirsti Samba Member
Posted: Thu Jan 27, 2022 4:18 am Post subject: Re: -51 Split handbrake assembly and transmission mount |
This is originally an Azur Blau Split arrived to Autola/Finland on 8 June 1951 and delivered to a Mr. J. Taavilainen. Do you have the body? |
Posted: Thu Jan 27, 2022 4:35 am Post subject: Re: -51 Split handbrake assembly and transmission mount |
mikeandkirsti wrote: |
This is originally an Azur Blau Split delivered to Autola/Finland on 8 June 1951 to a Mr. J. Taavilainen. Do you have the body? |
Yes i have. Here is some photos. it was repaired in the 80s. Well now i have to repair those repairs that didnt repair it so well.
