benchracer1 Samba Member
Joined: September 24, 2006 Posts: 584 Location: ramona
Posted: Mon Jan 17, 2022 9:07 pm Post subject: Sanding between coats |
I put down a coat of restoration shop acrylic urethane on some fenders today just to get an idea of how the bodywork looked. I unfortunately got a small sag on one fender. I was going to knock down the sag and give the fenders a quick sanding before I put on the final 2 coats. How long should I wait before sanding and would 400 be a good grit for a quick pre paint color sand...steve |
67ctbug Samba Member
Posted: Mon Jan 17, 2022 9:19 pm Post subject: Re: Sanding between coats |
Always do whatever grit your TDS states. Not all paints are equal and what works for PPG might not work for TCP Global. Wait until they're good and dry to sand, probably 24 hours depending on the temperature. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Igpoe Samba Member
Joined: February 24, 2019 Posts: 853 Location: South Boston, VA
Posted: Wed Jan 26, 2022 2:46 am Post subject: Re: Sanding between coats |
Yes, make sure its completely dry before sanding. If I get a sag I pull off a piece of tape and gently apply it immediately and remove most of the sag. Makes it much easier to sand later! _________________ '73 super. |
toxicavenger70 Samba Member
Posted: Wed Jan 26, 2022 3:28 pm Post subject: Re: Sanding between coats |
Igpoe wrote: |
Yes, make sure its completely dry before sanding. If I get a sag I pull off a piece of tape and gently apply it immediately and remove most of the sag. Makes it much easier to sand later! |
Can you do this on a curved surface? The only way I have done this is to intentional apply more product so that the excess runs to the edge. Then use some tape to pull it off. It would be better if you didn't have to apply more to make it move to the edge. |
Igpoe Samba Member
Posted: Wed Jan 26, 2022 3:31 pm Post subject: Re: Sanding between coats |
Yes _________________ '73 super. |
Posted: Thu Jan 27, 2022 8:09 am Post subject: Re: Sanding between coats |
Thanx guys |
